HKS DLI II Ignition Amp install help!
Rating: Thread Rating: 2 votes, 1.00 average.
Old Sep 7, 2007 | 01:33 PM
jskup1's Avatar
The Chief
Can someone who has installed this with the rx8 specific harness tell me which set of wires goes to which coil. Or, if someone in Virginia Beach can read Japanese and wants to stop by for a few minutes, I'd appreciate it.
Old Sep 7, 2007 | 05:24 PM
jskup1's Avatar
The Chief
Thank you!
Old Sep 23, 2007 | 01:46 PM
mazdaexe's Avatar
Hey GTAW, I tried the ordering you said, but the car still wont start up..
any other tips? its properly grounded. LED still doesnt come on.
thanx
Old Sep 23, 2007 | 06:29 PM
mazdaexe's Avatar
i've tried taking it back out and everything works...
Old Sep 23, 2007 | 06:43 PM
Correct me if Im wrong. for a N/A setup, will this help the car in any way ?
Old Sep 23, 2007 | 08:31 PM
It ended the high speed misfires I had at the track.....good enough for me
Old Sep 23, 2007 | 08:33 PM
hmm...
Where do you *hide* the unit tho ? got any picture of it installed ?
Old Sep 23, 2007 | 10:19 PM
FE3P's Avatar
NO PSTNZ
Originally Posted by nycgps
hmm...
I mounted mine just to the left of the window washer cannister using a simple bracket... it's also close to a good engine ground!
Old Sep 23, 2007 | 11:11 PM
hmm very temping ...
isnt it that the longer the wire the more resistance you get ? Is it a better idea to route it as close to the coils as possible and just ground it to the battery ?
Old Sep 24, 2007 | 12:09 AM
FE3P's Avatar
NO PSTNZ
The Twin Power DLI II kit comes with an RX-8 vehicle specific harness. The harness comes in only one length, so it really shouldn't matter where the Twin Power is mounted.
I hope this helps!
Old Aug 11, 2008 | 07:42 PM
sfredrx8's Avatar
Rotary Power Rules
HKS Twin power installation bracket info
Where did you get the bracket? How much? I would like to relocate my HKS unit as well. Thanks.
Old Aug 20, 2008 | 11:41 PM
FE3P's Avatar
NO PSTNZ
I just made an "S" shaped bracket. Please see the attached pic.
Sorry it took so long to respond, I had to remove the bracket in order to take the pic!
Old Aug 22, 2008 | 11:23 AM
sfredrx8's Avatar
Rotary Power Rules
Thx. I got a L-shaped bracket instead. It looks perfect now...
Old Aug 22, 2008 | 01:06 PM
NgoRX8's Avatar
It looks awesome. I'd like to get me some of these one day.
Old Aug 25, 2008 | 01:54 AM
rx-81688's Avatar
is the red led on the unit sure be on at all times? on my car only some times is on, what can be wrong with it, anyone know? where i need to check?
thanks!!
Old Aug 25, 2008 | 10:07 AM
FE3P's Avatar
NO PSTNZ
thanks!!
The red LED should be on when the engine is on. It should be dim at idle and get brighter as the rpms increase. If it's not doing this, make sure the ground is connected to a good engine ground.
I hope this helps!
Old Aug 27, 2008 | 02:23 AM
rx-81688's Avatar
thanks for your fast respond! i already try that b4, on mine, if i wiggle the unit, then the led kicks on, then after some time it will go off. my car is turbo and it puts out alot of heat, do u think heat may damage my wire harness?
thanks again for your help!!!
Old Aug 27, 2008 | 07:01 PM
Works Concepts's Avatar
Former Sponsor
The heat should not damage your wire harness, as long as it is not resting on a pipe. Many FD owners have them installed with no problem, and their under hood temps are a lot higher. That is one of the features that many people like with the HKS unit is that the box and harness itself seems to hold up to the hot engine bay of rotary cars.
Old Aug 27, 2008 | 09:51 PM
arghx7's Avatar
twin powers are a mixed bag. Ever heard of the "black goo" failure? It's important to protect it from vibration and heat, they do fail.
on the rx-7 ignition system they are good for 550+rwhp though, i made 386 with one myself
Old Nov 23, 2020 | 09:34 AM
synco357's Avatar
HKS Twin Power dli II
im guessing that the wires are wired to the negative side of each coils.
Old Nov 24, 2020 | 12:52 AM
12 years later and it’s still an absolutely worthless mod on an RX8
bentiac
May 22, 2012 05:32 PM
paimon.soror
Apr 20, 2012 03:50 PM
daisuke
Jan 24, 2012 09:21 PM
kenkamm
23
Jul 30, 2007 08:34 AM
You have already rated this thread Rating: Thread Rating: 2 votes, 1.00 average.
