So whats the verdict on LEDs in clear corners?
Old Sep 5, 2007 | 03:14 PM
TeeFar's Avatar
I've heard some say its not a good idea because of the heat and some say its fine. Honestly I don't really notice any extream heat around that area on my car. I've already ordered some LED's but I just want some feedback.
http://www.superbrightleds.com/store...es/wled-x5.jpg
-WLED 5-LED Wide Angle LED bulb
12 VDC 5-LED Wedge Base bulb (194/168 type)
Super Wide Viewing Angle bulb uses 4 radially mounted LEDs aiming out the sides and one High Flux LED on top
With built-in voltage regulator -
Old Sep 5, 2007 | 04:17 PM
Aipex8's Avatar
X e p i A
I've been running LEDs in most of my 194 wedge bulb spots for a while now and have had several failures no matter what the location (my rear license plate bulb has failed the most times). Surges in voltage are probably the reason for the failures more than heat. I've added LED protectors from autolumination to all my LEDs and haven't had a failure since (knock on wood). Link to the LED protectors (scroll down):
http://autolumination.com/equalizers.htm
BTW, I have the following bulbs in my clear corners and they are bright as hell. Love em:
Old Sep 5, 2007 | 04:32 PM
LED's are perfectly fine to use in the clear corners. Heck, RotaryRasp made a set with 12 of the little bad boys in there.
Aipex, sweet lookin' bulbs. I was thinking of ordering a pair of those
Old Sep 5, 2007 | 05:24 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
24 now!
Old Sep 5, 2007 | 05:43 PM
bmxbobby2004's Avatar
Originally Posted by Rotary Rasp
24 now!
Where did you get those???????????????????????
Old Sep 5, 2007 | 05:44 PM
he made them. Rasp is the LED guru on this forum
Old Sep 5, 2007 | 05:47 PM
Kris's Avatar
I have replaced all my 194 wedges in the car with LED's and they look great. The only problem I had was the little parking lights in the head light housing, one of my LED's started to flicker (im thinking because of the heat) anyways I changed it out and its good to go again.
Old Sep 5, 2007 | 05:56 PM
Kris: I had the same issue with those lights when I had autolumination bulbs. What brand are you using?
Old Sep 5, 2007 | 06:41 PM
NgoRX8's Avatar
it happened to one side while i was using v-led bulbs. i didn't feel like spending more cash on it to take a chance so i went with regular incandescents. not sure if it's the heat or cuz of voltage flux.
Old Sep 8, 2007 | 01:12 PM
Kris's Avatar
They were V-LED
All of my bulbs are V-LED I changed my rears as well to the 7440 wedge LED's Damn there bright. I will post pics. I changed all the bulbs in the car as well.
Old Sep 9, 2007 | 10:56 AM
kris: post pics
Old Sep 9, 2007 | 10:27 PM
Kris's Avatar
I will I will, it was horrible outside today, tomorrow I will snap a few
Old Sep 10, 2007 | 02:53 PM
ac3mastuh's Avatar
Got Ings?
I had a set of LED's go out on me but then I purchased a setup from the local Japanese marketplace which had a relatively large heat sink and it seems to keep them stable now...but I also have a voltage stabilizer so that may be it but either way they've been working well for quite some time now.
Old Sep 10, 2007 | 02:56 PM
Spinning Sushi's Avatar
I <3 Sushi
I don't understand why LED produces so much heat when it uses so little energy to power them. I had an LED on for about an hour and it was still cool to the touch.
Old Sep 10, 2007 | 03:05 PM
Aipex8's Avatar
X e p i A
LEDs don't produce much heat, what can damage the LEDs is ambient heat from the engine or halogen bulbs that are too close. I just don't think the corner bulbs are close enough to a heat source to do them any harm.
Old Sep 10, 2007 | 03:17 PM
The leds you guys are talking about don't make much heat, if any. More powerful 1, 3, and 5 watt leds make tons of heat. If proper heat sinks aren't used, they'll get so hot that they'll melt.
Old Sep 10, 2007 | 10:36 PM
Kris's Avatar
Ok guys heres my sorry attempt at some type of Photography Sorry I will try and get better pics. The interior lights are real nice, when I unlock the doors or open them, the entire interior lights up a real subtle white color. Its real nice. Sorry I didnt have anyone to put the car in reverse to show the reverse indicators but I will get someone to and post some pics. The Dome light is a 12 LED Flux type festoon. all other bulbs are the 5 LED Refractors. all LED from V-LED.
DOME LIGHT:
DOOR LIGHT:
MAP LIGHT:
HEAD LIGHT ARRAY:
REAR LIGHT:
Old Sep 10, 2007 | 10:40 PM
the headlight array photo is quite nice
Old Sep 18, 2007 | 03:18 PM
Damien019's Avatar
Did you also replace your fog lights with LEDs?
If so which ones and was it hard?
Old Sep 18, 2007 | 03:33 PM
Nopstnz's Avatar
I've had 194 wedge based in my corners, courtesy, and map lights for over a year and have not had one problem. Also have an led dome light with not one problem
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
duworm
Oct 1, 2015 04:57 PM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
