Possible to remove beeping sound when in reverse gear?
Old Aug 26, 2007 | 11:58 PM
jeronlee's Avatar
For those 8s with reverse sensors installed, do you hear 2 different beeping tones when reversing your ride? Anyway to remove the default beeping sound?
Old Aug 27, 2007 | 12:22 AM
yohji's Avatar
人做到了其他人做不到的东西..我们叫他 ~~神
Just curious,The beep sound is for warning so my question.what for u install the reverse sensor without the beep sound?
Old Aug 27, 2007 | 12:33 AM
simply8's Avatar
white renesis*
even without the reverse sensor installed, there is still beeping sound when you engage in reverse gear.
why try to remove the sound? it's only a fraction of a minute that you engage reverse gear wat.....it's not like you always drive in reverse gear.
Old Aug 27, 2007 | 12:46 AM
Galen Darkmoon's Avatar
I don't remember
Stand on it till engine blows beep will stop.
Old Aug 27, 2007 | 01:49 AM
wen pin's Avatar
i always find the beeping sound useful. tells you that you have engaged the reverse gear correctly....
Old Aug 27, 2007 | 02:16 AM
winn's Avatar
Type_Stormy in my GaRage
Wen Pin.
I totally agree with you.
It helps me to differentiate between engaging the Reverse gear vs the 6th gear.
Winn
Old Aug 27, 2007 | 05:57 AM
jeronlee's Avatar
Mine is AT so no risk of engaging the wrong gear. Even without the reverse sensor, I always find the beep irritating as it reminded me of a van/lorry. I would appreciate if it's just a beep to affirm that the reverse gear is being engaged but not constant beeping that is even louder than my reverse sensor.
Guess most of the bros here r either without reverse sensor or doesn't mind the symphony of the default & sensor beep.
Old Aug 27, 2007 | 07:35 AM
Emperor's Avatar
aka Spectre
At first i mind it. As with all mods, xhos, air filter, ICE; you will get used to it after time.
Old Aug 27, 2007 | 03:08 PM
sqflyer's Avatar
Heavy Machinery Operator
Worst part about having the beeping sound in reverse when you don't have a reverse sensor is if someone else drives your car and is unaware that you do not have a reverse sensor, he/she might back into something thinking that the beeping sound is from a reverse sensor (when there is none) and will warn him/her when there is something near.
Old Aug 27, 2007 | 10:29 PM
Emperor's Avatar
aka Spectre
You have a good point.
Old Aug 27, 2007 | 11:58 PM
ngkenny's Avatar
stock standard
better to have this than to have the beeping sound when you never put on your seatbelt. that is irritating. shift car 5 meters also must put on seatbelt...pfft
Old Aug 28, 2007 | 01:00 AM
wen pin's Avatar
the trick is to move slow so tat beeping sound will not be activated....
Old Aug 28, 2007 | 03:26 AM
Emperor's Avatar
aka Spectre
Cheap way: use ear plugs.
Old Aug 28, 2007 | 03:31 AM
Rumboo's Avatar
Lurker
Hmm.. I don't have the default reverse gear beeping sound leh, only the reverse sensor beep, so I hear only one set of beeping, and only when there's something behind me.
Old Aug 28, 2007 | 11:12 AM
jeronlee's Avatar
Yours is the latest batch of 8s right? Saw your stormy blue thread...
Either Mazda received too many feedback from annoyed owners like myself so the newer version comes without the it, or perhaps your PI knows how to remove the reverse beep since they are fitting the reverse sensors for u...
Hope it's the latter so there's still a chance that i can disable the reverse beep
Old Aug 28, 2007 | 12:49 PM
wen pin's Avatar
for the record, when a reverse gear (for a 6MT) is engaged, only one beep is heard.
the reverse sensor is only heard when there is something behind the car. in any case, a good driver never totally rely on a reverse sensor......
Old Aug 28, 2007 | 08:10 PM
winn's Avatar
[QUOTE=wen pin;2032266]for the record, when a reverse gear (for a 6MT) is engaged, only one beep is heard.
QUOTE]
Happens to mine too
Old Aug 29, 2007 | 02:48 AM
sqflyer's Avatar
Thanks for the clarification about newer 6MTs. My '04 6MT doesn't beep even once when reverse gear is engaged which IMHO is much better because any kind of beep (single or continuous) may give some other driver a false idea that there is a reverse sensor installed.
Yes, a good driver never totally relies on a reverse sensor. Unfortunately, not everyone is born equal. There will always be village idiots and even good drivers will have lapses of concentration or moments of stupidity. Only thing we can do to minimise such occurances is to provide as many good inputs to the driver as possible, be it reverse sensors or reverse cameras.
Old Aug 29, 2007 | 03:03 AM
yohji's Avatar
+ 1 by the way what is the criteria to become a good driver?
Old Aug 29, 2007 | 05:51 AM
jeronlee's Avatar
No wonder nobody is complaining about the reverse cos it seems u guys are either getting a single beep or none at all.
Could it be i'm the only 4AT here that is getting a recurring beep as long as reverse gear is engaged? Guess I should swing by MG one of these days to see if they've a solution for me...
Old Aug 29, 2007 | 06:26 AM
sqflyer's Avatar
I once heard a saying, a good driver is someone who doesn't hit anything, but a truly great driver is someone who doesn't let anything hit him.
Old Aug 29, 2007 | 08:49 PM
wen pin's Avatar
yeap....spot on.
defensive driving is a valuable skill to have in singapore road condition..
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
nowakm99
Oct 9, 2015 07:10 AM
just1jack
Sep 9, 2015 04:45 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
