K&N typhoon V.2
Old Aug 21, 2007 | 02:10 AM
tajabaho1's Avatar
Destroying Threads
K&N typhoon V.2
Hey guys, I finished installing some stuff on my car
I want to share an opinion on the K&N typhoon v.2
it sucks a big black D... don't get it for your car, DON'T DO IT! DON'T DO IT
DON'T DO IT,DON'T DO IT,DON'T DO IT,DON'T DO IT,DON'T DO IT,DON'T DO IT
I had to mod the god damn **** out of it JUST to make it as good as my stock, which included custom piping to get the bitch to the front of the air duct and ACTUALLY SUCK IN AIR!!! btw VFAD and Typhoon hates each other, so I had to remove the vfad, now I need to buy a damn RB duct, walla another 100 somethin
wait wait, thats not it!! ITS FREAKING GOD DAMN HOT!!!! HOT HOT HOT!! I had to put like 10 LAYERS OF ALUMINUM FOIL on EVERYTHING from the tip of the intake through all of the piping, and everything left and right of the place where the stock box once lay.............
to sum it up, I was a retard for buying this ****, DON"T DO IT!!!!
unless you enjoy modding ****, then its ok
Old Aug 21, 2007 | 03:01 AM
SE3PSynergy's Avatar
Has a headache.
it took me 40 minutes to remove the stock box install it without removing the VFAD... haven't had a problem since, just cleaned the filter a few times. Maybe there's something about automatics that makes this harder which I doubt but I've never looked under the hood of an auto RX-8... I haven't needed to 'mod' anything and my car has been running just fine for over 7k miles with it installed... don't blame the product if you aren't 100% proffecient on install no offense.
Old Aug 21, 2007 | 03:12 AM
tajabaho1's Avatar
Destroying Threads
uhm? ur missing da point, it took me very much less to get the stock airbox(which I am very proficient in removing thanks to DIY) I'm not saying its hard to install, the design is just a tad bit.......stupid, why can't they make the filter a bit longer and ofset it to the right a bit more? who knows!!!
Old Aug 21, 2007 | 03:25 AM
photos????
sounds more like you did something well, lets say not correct...
Old Aug 21, 2007 | 03:36 AM
Flashwing's Avatar
3-wheeler
I can't speak for other K&N Typhoon 2 system but I know I have been dissapointed with it's performance.
By actually doing some data logging, I noticed that the MAF was recording some seriously high intake temperatures at lower speeds but still high despite high cruising speeds. At idle my IAT was well above 150 degrees and only fell to 120 degrees during 70 mph cruising.
Conditions were nightime driving, 103 degrees ambient temperature and probably in the neighborhood of 40% humidity.
Clearly the intake is sucking hot air off of the engine. Other RX8 owners here in Phoenix with CAI designs only experience intake temps slightly above ambient.
I'm thinking of going back to a stock airbox and doing a drop in.
Old Aug 21, 2007 | 03:41 AM
that delta in temps is pretty good..
i get about 10 to 15deg above ambient with the revi and duct at a 70mph cruise...
after a heat soak.
Old Aug 21, 2007 | 04:01 AM
Flashwing's Avatar
3-wheeler
Oh I agree, the delta is fantastic! No doubt the reason is due to having taken out the sock and removing all the restriction material...nearly a straight shot into the engine bay.
I'm starting to think one of the better setups is a stock intake with the Revi duct.
I'm looking forward to fall/winter here in AZ...the car runs like a champ then!
Old Aug 21, 2007 | 02:21 PM
tajabaho1's Avatar
Destroying Threads
hang on, I wanna I can't post the forums messed
Old Aug 21, 2007 | 07:40 PM
PerformRX-8's Avatar
ROTARY-A-HOLIC
my MAF sensor actually stopped responding, at one point, so becareful what modifications you do. the dealer actually was really nice about it, nd fixed it under warranty.
Old Aug 22, 2007 | 07:02 AM
Hanzoboy's Avatar
Hanzopower's
yea....its sucks....air the K&N is stoopid..it is NOT better than the stock air box...NOT and now it even drinks MORE FUEL pfff
Old Aug 24, 2007 | 12:57 AM
RX OCHO's Avatar
riding in my 04 in LA
I have the K&N Typhoon V2 and all I have to say that it really...SUCKS!!!
my car is taking too much hot air, I might put my stock box and drop in a K&N
filter inside this weekend.
K&N Typhoon V2 = EBAY
Old Aug 24, 2007 | 02:26 AM
tajabaho1's Avatar
Destroying Threads
lol hey dude, I have a used K&N drop in filter, if you want, can come pick up at my house, 30$
Old Aug 25, 2007 | 12:28 AM
RX OCHO's Avatar
tajabaho, did you mod you typhoon v2 intake?
I found an air funnel and plastic hose...Just wondering if you did something similar.
Old Aug 25, 2007 | 12:47 AM
tajabaho1's Avatar
Destroying Threads
hell yea, but I fould the best and most effective way is to use lots of foils+ air funnel
Old Aug 25, 2007 | 10:56 AM
RX OCHO's Avatar
^ do you go to the LAX meet? I would like to check out your mod.
Old Aug 26, 2007 | 01:19 PM
Proxi's Avatar
duct tape works wonders
No problems here
Had my K&N Typhoon v2 on my '06 RX8 6MT for about a month now. Probably drove already around 1300 miles with that intake. Didn't notice any "major" improvements in performance compared to the stock intake - maybe except a little bit better throttle response and "a very slight" MPG increase. But I also didn't notice any problems with my RX8. Still runs the same as when I had the stock intake. No problems in the temp or power loss areas. I'm probably just lucky . The very first thing I noticed though when I installed my K&N kit was that my Mazdaspeed dual exhaust actually "growls a bit louder." But I do have my stock intake in storage - just in case.
Old Aug 26, 2007 | 03:31 PM
Mikeluvs8's Avatar
no probs here, i had it on for over 12k miles now, cleaned it once and still love it! and here in vegas we been reaching over triple digits in temp everyday no probs with heat soak or over heating.and i did notice a good amount of a power increase.
Old Aug 26, 2007 | 03:32 PM
tajabaho1's Avatar
Destroying Threads
with the foils, its actually better than the stock intakes now @.@
Old Aug 26, 2007 | 03:37 PM
Mikeluvs8's Avatar
you got pics of what you did?
Old Aug 26, 2007 | 05:02 PM
I dont have a problem with heat. my intake temp is just a bit higher than stock.
The *open* design is to get maximum air flow. K&N knows how to make intake better than any of us.
Performance , maybe couple of hp increased. nothing major. just like most intake for the 8. But K&N Version 2 has the highest top end.
I like Version 2.
Old Aug 26, 2007 | 05:24 PM
Mzdarx8's Avatar
+1 nycgps
I have it with the RB air duct. In stop & go traffic under 20mph i am sure you get some heat soak on a 90F day. My car does feel sluggish around town. But when the traffic clears and you get some cooler air in then things open up all the way to 9k!
Old Aug 26, 2007 | 05:39 PM
Hmm, there was a couple of over 90 and 100 days. but I never had any *sluggish* feel.
I might have a superduper Renesis !
Old Aug 26, 2007 | 05:46 PM
Brettus's Avatar
Boosted Kiwi
[QUOTE=Flashwing;2022981
![/QUOTE]
been saying that for ages - stock intake , k&n drop in , RB duct , remove both mesh screens .
I'd bet its as good as the revi ......
Old Aug 28, 2007 | 01:58 AM
tajabaho1's Avatar
Destroying Threads
I basically foiled the entire v.2, now it actually runs cool and I get a bit of kick at the slower rpms
although, seriously, not worth the 200 bucks
Old Aug 29, 2007 | 09:59 PM
Then in your opinion what worth 200 bucks ?
You obviously have no idea how the system actually works. K&N version 2 works fine with VFAD. Its just that you *think* its not working.
K&N set it up this way to get maximum power.
And you have an AT ...
