Stock 6 disc cd changer
Old Aug 21, 2007 | 01:04 AM
Enjorren's Avatar
Gaijin
Alright I checked the manual and it says to load more than one disc you hold down load until it beeps then hit the disc number you want to load. The problem is that mine isn't beeping when I hold load. Did some 8's come with a single disc player?
Old Aug 21, 2007 | 01:27 AM
paulmasoner's Avatar
Asshole for hire
on the LEFT side, DIRECTLY beneath the slot where you put you CD in.... it will either say MP3/CD/6 Disc or somthing of that nature... if you have a 6 disc, it will tell you. if you have a CD(single) it tells you etc etc... its right there in front of you when you're trying to put the disc in... how can you miss it
dont worrry, you're not the only one to ask this... i cant believe how many times this gets asked....
Old Aug 21, 2007 | 08:38 AM
CoMBo8's Avatar
My 8 is Sexy!
If it is not a 6 disc charger, those 2 button "DISC V" and " DISC ^" shouldnt be there at all to confuse user.
Old Aug 21, 2007 | 08:52 AM
Aero8's Avatar
It took me a bit to figure that one out too. The disc up and down are there because the main head unit is the same. on all the models. The cd player can be swapped out with a 6 disc and it will be ready to go.
Old Aug 21, 2007 | 04:41 PM
Enjorren's Avatar
Gaijin
Thanks guys.
Old Aug 21, 2007 | 07:17 PM
WikkedOne's Avatar
Deals on wheels
the disk up and down buttons are also used if you put in the MP3 player - you use those buttons to change "folders" and then the track up and down to change the file inside of that foler
Old Aug 23, 2007 | 11:10 PM
redferne's Avatar
If your looking to upgrade to a 6 disc, you might want to note that the CD changer is the same for the Mazda 3 and 6 also. I just picked up a whole Mazda 3 HU w/ 6 disc changer from e-bay for $62 shipped. Did the swap and everything works great. Now I'll be putting a Mazda 3 HU w/ a single disc back up and making some of the $ back.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
