I can't change into gear! : ( HELP!
Old Aug 20, 2007 | 09:02 PM
MTorres895's Avatar
I was driving today when my car just freaked at a redlight. The car wouldnt go into gear, it was the strangest thing. Can someone help me on what to do from here? It's an 04 and I've never had a problem with it until today. Keep in mind that the car is stuck in neutral, doesnt shift into any gear.
Please PM me or write back here ASAP. Thanks.
Old Aug 20, 2007 | 09:10 PM
GuyWithRx8's Avatar
Low compression
what happened after that?
Old Aug 20, 2007 | 09:12 PM
>speedaddict<'s Avatar
United States Marine
Your Throw Out Bearing Probably Went Out. That Happened To Me Before. Luckily The Ppl That Installed My Clutch Installed A New One For Free.
Old Aug 20, 2007 | 09:24 PM
MTorres895's Avatar
To answer the first question, I just towed it back to my house because I dont have the money to repair it right away. Just wondering how much I'll probably be spending and what parts do you think I'm going to need, that way when I do take it to a shop I have an idea of what I'll be looking for.
My throw out bearing? Sorry dont know much about cars, just drive them heh. Can it be anything else besides that? Do you think it's my whole clutch or transmission?
Old Aug 20, 2007 | 09:44 PM
http://auto.howstuffworks.com/clutch1.htm This Site Shows You How A Clutch Works. It Also Shows What A Throw Out Bearing Does. You Dont Need A New Tranny Or A New Clutch But Since You Have To Drop The Tranny I Suggest You Just Replace The Clutch Cause Its Expensive To Drop The Tranny. Altogether It Cost Me 1000 Bucks For A new clutch And Installation
Old Aug 20, 2007 | 10:20 PM
ken-x8's Avatar
If the bearing broke so that the fork was disengaged, that could do it. As could a broken fork or pivot, or maybe the clutch pedal or bracket.
It can also be the clutch slave or master cylinder, or a broken hydraulic line. I had a BMW with a hydraulic clutch linkage that randomly would not shift. It became more frequent, and eventually I figured out it was the slave cylinder. Rebuilt that (no harder than a wheel cylinder) and all was fine.
First thing I'd do (after screaming and swearing) would be to check the clutch fluid level. Next thing would be to look at the clutch release arm (assuming it's visible - haven't crawled under my 8 yet) and have someone step on the clutch. See if it moves. If it does, then things have to come apart. If it does not move, then check the pedal and hydraulics.
Ken
Old Nov 19, 2007 | 08:43 PM
AJ's Shinka's Avatar
Enthusiast
I had this happen to me today at almost every stop and barely made it home. Did you ever get this resolved?
-AJ
Old Nov 19, 2007 | 09:00 PM
this same thing occurs when the clutch disk center hub disintegrates into pieces, has happened to quite a few RX-8 owners
takes a new clutch to repair it
Old Nov 20, 2007 | 09:40 AM
I've read a bent shifting fork can do it too.
Have you tried it since you had it towed home.
If it's something simple like this may the tow ride home jarred it loose.
That's happened to me before on another car.
Old Nov 24, 2007 | 05:20 PM
Enthusiast
Thanks for the help guys but just to let you know what it was my AFE SS. The bushing had gone out. I will be getting a new one put on by Richard whenever I get around to shipping it to him. Stock shifter is in right now =
-AJ
Old Oct 30, 2008 | 03:11 PM
theonly30's Avatar
I Had The Same Problem But I Can Only Shift When The Car Is Off. I Am Changing My Slave Cylinder First Because After Hours And Hours Of Reserach And Symptom Description To Blogers, And A Visit To The Mechanic That Was Set On Changing Entire Clutch!!! I Figured It Is Worth Changing The Slave First ($50 Is Better Than $1000 Plus).
Old Oct 30, 2008 | 03:18 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Thats what happened when my trans blew
GL
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
nowakm99
Oct 9, 2015 07:10 AM
titaneum_grey
Sep 6, 2015 10:21 PM
