Another 100,000 Mile RX-8 on the Road!
Old Aug 20, 2007 | 05:57 PM
expo1's Avatar
He's as bad as Can
Talking Another 100,000 Mile RX-8 on the Road!
Just went over the 100,000-mile mark and thought a thread was in order. My 8 was an early build (5/2003) which I picked up February of 2004. During the this time I have had no major problems, enjoy my car as much as I did in 2004 even though the sales and service aspect of the dealership was sometimes aggravating. Because of this car I have about 30 hours of track time. I also found this place and try to be as helpful to others as this site has been to me. If a so-called “troublesome “ 5/03 built 8 can go 100,000 miles with no major problems I don’t see way most of them can’t. I did have a compression check done a few weeks ago and the results were not bad for a 8 with my mileage. I will try to see if I can hit 200,000 miles in 2011. I used the maintenance log feature of www.mazdausa.com to keep track of things, that is attached as a zip file. I thought some people might like to see that.
Now some random notes.
Never Flooded, Original trans, motor & starter. Never broke a visor but an A/C **** did crack fixed with Krazy Glue. Brakes only squeal when my track pads are on. My OEM rotors lasted over 95,000 & the Clutch 86,000 miles and I could have gone longer on both. If I baby it I can get over 21 MPG. I have only had 4 CEL’s; two were misfires on the track. The others were for a bad gas cap and a stuck secondary intake valve. Since I have dedicated tires for the winter and the track I am only on my second set of street tires. I am also only on my second set of street pads, I use different ones on the track. Been using Royal Purple 5w 30 since about 70,000 and Idemitsu premix since 68,000. Red Line fluids are in the trans and rear. If I think or more stuff I will edit this and any questions about having a 100,000 mile RX-8 are welcome.
More Notes:
The original CAT is still on the car. I run 89 octane name brand gas almost all the time. My original engine mounts are still on, but I do have new ones waiting just in case.
File Type: zip
Old Aug 20, 2007 | 06:09 PM
bassy's Avatar
That's awesome to hear! Congrats!
Remember to let us know when you hit 200K miles!
Old Aug 20, 2007 | 06:18 PM
munche187's Avatar
"MuNcH-E"
Congrats
Old Aug 20, 2007 | 06:20 PM
danielk015's Avatar
good **** man
Old Aug 20, 2007 | 06:22 PM
9291150's Avatar
Expo, you're one of the good guys here so beers on me if you ever make it to Kanada
Nice milestone; that's 160000kms by the way (sounds better). Not bad for a trackday toy, really surprised about the rotors keeping spec for that long. Tranny doesn't grind?
Old Aug 20, 2007 | 06:27 PM
expo1's Avatar
He's as bad as Can
Most of my miles come from my 80 mile round trip to work which is mostly highway. Can't wear the brakes if you don't use them much. I think that also goes for the trans. most of the time I am in 5th or 6th. The yearly change of the trans fluid helps too.
Old Rotor's Avatar
Great news we all enjoy your Post.
Old Aug 20, 2007 | 06:41 PM
Brettus's Avatar
Boosted Kiwi
yeah - good to hear Expo .
Old Aug 20, 2007 | 06:56 PM
rx8convert22's Avatar
Congrats! I just started my journey. I am about to do my first oil change. Any other tips for a newcomer?
Also was the fuel pump failing at 100k? I have been letting my tank go down very low so thinking perhaps I am stressing it by doing this. I am thinking of starting to fill up when I have 1/4 tank left instead.
Old Aug 20, 2007 | 07:00 PM
dbdbdb's Avatar
Congrats!!!
This is the type of news I love to read Keep rolling that 8 till you hit the big 200K.
Old Aug 20, 2007 | 07:27 PM
puch96's Avatar
congrats.. .maybe in some years from now i'll hit 100k miles also...
Old Aug 20, 2007 | 07:29 PM
DOMINION's Avatar
I don't buy Kool-Aid
Expo is the man! keep up the good work
Old Aug 20, 2007 | 07:32 PM
TeeFar's Avatar
Im always reading about the importance of redlining the engine with the RX8... do you redline yours a lot???
Just curious
Old Aug 20, 2007 | 07:52 PM
ZoomZoomH's Avatar
Mulligan User
that's one impressive 100,000 mile RX-8, considering how hard you have driven it, especially on the track!!
Old Aug 20, 2007 | 08:34 PM
expo1's Avatar
He's as bad as Can
Just curious
Not as much as I should, it is hard to do on the congested roads of New Jersey. I think that is why I had the CEL for the secondary intake valve being stuck. After that I started driving one gear lower than I normally would and more redlines entering hwys. I also used to go to the track at least 4x a year which made a big difference. Four hours on a track like Watkins Glen is like hit a speed to the RX-8. This year do to personal issues I had to cut back on the track time.
Old Aug 20, 2007 | 08:39 PM
expo1's Avatar
He's as bad as Can
Mazda recomends the pump be changed at 100,000 miles. I am doing it for that reason and last month I had a a misfire / loss of power issue on Pocono Raceway. I think I took care of the misfire issue with the PCM / E-shaft reset & the new coils. The fuel pump could have also been the issue and since I am at the miles where I should replace it why not.
Old Aug 20, 2007 | 08:42 PM
kevinus99's Avatar
as some one about to end their warranty and wondering how much longer to keep this car, this is very good news. Thanks for the post.
Old Aug 20, 2007 | 09:04 PM
DOMINION's Avatar
As long as you have the cash to keep taking care of the car when its out of warrenty
Old Aug 20, 2007 | 09:44 PM
still on original cat?????
great job btw...
Old Aug 20, 2007 | 09:51 PM
rx8speeddmon's Avatar
expo1 you give me hope.
Old Aug 20, 2007 | 09:52 PM
Silver_Surfer's Avatar
I4NI
Right on![beer]
What kinda oil did you use before 5-30RP @ 70000miles?
Old Aug 20, 2007 | 10:03 PM
Jethro Tull's Avatar
Living In The Past
This just proves that if you take care of your car, it takes care of you. Well-done sir. And thanks for posting the service history- good data there. May your beautiful car give you another 100,000 miles of faithful service and fun driving.
Old Aug 20, 2007 | 10:42 PM
cleoent's Avatar
n00b
awesome!
Old Aug 20, 2007 | 11:22 PM
stephi jane's Avatar
Hi guys!
I just bought my Rx-8. She had 90,000kms on the clock and now im about 10kms off hitting the 100,000 mark. im in the same situation at expo (although i know 100 miles is more then 100 kms. but still...)
My baby is a late delivery 03 as well. first everything - mostly. third set of tyres and still first brakes etc. there is hardly any wear on anything and there is only 1 tiny parking dint on the door. The guy who had it before me was an older gent who just drove her to work and back... all highway Ks...
its a great car and im not having any problems with her.
very happy. and loving this club
SJ
Old Aug 20, 2007 | 11:44 PM
MrCairo's Avatar
Great to hear and congrats. Thanks for all of the info - this kind of real-world data are great to hear especially to a relative RX-8 noob who sees a lot of negative posts and not enough good ones like this.
Cheers
