Oil Go Bye Bye
Old Aug 10, 2007 | 04:08 PM
Gauge's Avatar
Not Jeff Gordon
Oil Go Bye Bye
I know the 8 uses lots of oil but, I topped up my oil Monday I believe and here it is Friday and its already nearly empty..Is this normal? no oil leak.
Old Aug 10, 2007 | 04:11 PM
StealthTL's Avatar
Metatron
Doesn't sound likely....
S
mysql101's Avatar
There is no way to tell if it's normal, since you didn't specify how many miles. Saying 5 days have past means nothing.
You should install the sohn adapter if losing oil bothers you.
Old Aug 10, 2007 | 04:12 PM
Brettus's Avatar
Boosted Kiwi
that depends on how many miles you did in the meantime .........
Old Aug 10, 2007 | 04:16 PM
Gauge's Avatar
Not Jeff Gordon
I hardly drive it, thats why its odd, about 20-30 miles this week.
Old Aug 10, 2007 | 04:18 PM
mysql101's Avatar
you either have an oil leak, or you didn't measure the oil properly. There is no way you can burn over a quart in 30 miles.
sometimes one side of the dip stick will look wet, but the other side is dry (because the stick touched oil on the way out)
Old Aug 10, 2007 | 04:21 PM
Gauge's Avatar
Not Jeff Gordon
Ive measured 3 times today, same ole same. About to go again, just got back from the store and see what it shows now.
Old Aug 10, 2007 | 04:24 PM
dillsrotary's Avatar
jersey fresh
is the engine hot or cold everytime you check it?
Old Aug 10, 2007 | 04:43 PM
zoom44's Avatar
why is this in general auto?
Old Aug 15, 2007 | 10:50 PM
Gauge's Avatar
Not Jeff Gordon
Sorry about that , anyways I usually check it after Ive been out in it atleast once.
Old Aug 16, 2007 | 12:41 AM
Silver_Surfer's Avatar
I4NI
Thats alot of oil!
Old Aug 23, 2007 | 07:11 AM
eurodaytona's Avatar
I had my oil changed at the dealer on June 27,2007 at 8,829 miles and its now August 23, 2007 and the car has 10,516 miles. My wife drives the car 99% of the time so i only see it at night sitting in the garage but i do check the oil on the weekends and I have not had to add a drop since the dealer changed it. I called them up to tell them that im sure the car was over filled by the dumb *** that changed the oil but they said no, its prob fine. I got rather pissed and said well the car is under full warrenty so whatever. This was a few weeks ago and i figured id see a drop on the dip stick soon anyway, but still its full. I'll check it like 3 times just to make sure. Before i had the oil changed i would have to add 1/4 quart every 2 weeks or so to keep it topped off. Anyone have suggestions or thoughts, or what it could be doing to my engine if it was over filled? Thanks in advance
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
