R-Magic sport catalyser?
Old Aug 9, 2007 | 11:30 AM
Ragazhul's Avatar
Hi Guys.
i am new in this board. i came from austria (europe).
And here we dont have many tuning shops for import cars.
Anyone know where i can bye the R-Magic Sport Catalyser very cheap? Beacause the cheapest one where i see is Japanparts.com for 900 Dollar.
And is it a very good catalyser?
I need one that have 200 Cells, because in Austria it is not legal to drive whit a 100 cell catalyser.
Thanks a lot for your help.
Old Aug 9, 2007 | 01:02 PM
stuartm's Avatar
Your mods mean squit
What about a hiflow metal cat?
Old Aug 9, 2007 | 01:29 PM
savedsol's Avatar
Carbonormous
Rotary Performance switched to a ceramic cat because the metal matrix couldn't handle the heat. The R-Magic cat is that expensive. If you want hi-flow you could just buy a $100 Magnaflo cat and have someone remove yours and weld it on.
Old Aug 9, 2007 | 01:33 PM
Nemesis8's Avatar
Bigus Rotus
I've got 35,000+ miles on my Rotary Performance Supercat to date. I guess I'm lucky!
As for the R-Magic unit, can't say where to buy it for less. Maybe PM the Japanparts.com forum member here for advice.
https://www.rx8club.com/showthread.php?t=116353
Old Aug 9, 2007 | 01:39 PM
stuartm's Avatar
I thought a metal cat could handle the heat better than a ceramic one :
Old Aug 9, 2007 | 03:06 PM
Ragazhul's Avatar
You think a metal cat isn´t better as a ceramic one?
Because the ceramic cat is always broken. And a metal one can´t brake? or is it the heat that the oxygen sensor working wrong??
Stuart, the Highflow cat ist realy cheap but i will a complet one, that i must only put it on the same place like the old one.
I don´t will welding anything on the original pipes.
Old Aug 10, 2007 | 02:15 AM
stuartm's Avatar
What do you have to weld? it's a straight bolt in cat
Old Aug 10, 2007 | 07:54 PM
R Magic's Avatar
R Magic offers one of the best sports catalyzer for the RX8, they are the best with rotaries. Japanparts.com is probably the best place to get it from, Graham Ware might even give you a %15 discount for being a forum member.
Old Aug 11, 2007 | 09:02 AM
savedsol's Avatar
Carbonormous
And your proof is..... your username told you so? You tested all of them on the market and it's in the top three? It's expensive?
Old Aug 12, 2007 | 01:44 AM
stuartm's Avatar
I beg to differ, the smb cat has a shallow taper so all the core is being used
Old Aug 13, 2007 | 03:59 PM
sticks888's Avatar
man, that r-magic high flow cat sure is pretty...i'm sure most on this forum have gone with a cheaper high flow cat (i.e. RP) instead of this. can't see how this cat would free up more HP than others since it has a resonator on it, whereas others don't.
Old Aug 13, 2007 | 04:19 PM
Red Devil's Avatar
Same here, and about closing in on 40K on my Supercat.
Old Aug 13, 2007 | 05:44 PM
Hanzoboy's Avatar
Hanzopower's
I think im gonna buy this one ...http://www.racingbeat.com/FRmazda4.htm without a cat its best for HP....the law can KSmyass. :p
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
snowrydr01
Nov 23, 2015 09:40 AM
Oct 3, 2015 09:51 AM
duworm
Oct 1, 2015 04:57 PM
