c41250n
08-08-2007, 10:43 PM
my car is blowing light blue smoke when cold start up, I wonder what will cause it to do that? it only happens when its cold start, nothing when the car is warmed!
I still havn't done the oil restrictor yet, but I'm not sure if that is the caused tho!
I also have a oil lead from the drain plug and the oil return line! but I don't think it will cause blue smoke from my tailpipe either!
so what do you guys think is the reason?
dannobre
08-08-2007, 10:55 PM
lack of oil restrictor = oil seal bypass = smoke.....I'd bet :)
Either that or your turbo is getting loose and the seal is leaking....
c41250n
08-09-2007, 12:25 AM
im trying to, but my mechanic doesnt really know how, he tried but some how he said the nos jet wont fit.....so i dont know what to do!
i want to bring it to somewhere else to install it, but still looking around and see who can do it!
rotorocks
08-09-2007, 10:12 AM
He is not very bright is he? :lol2: it's that, or he intentionally tries too make things complicated to cause you grief and make you pay. :scratchhe
Depending on what's more acceptable given the circumstances:
He can use a different jet
He can machine the jet to a smaller size.
He can expand the internal diameter of the oil fitting slightly to get the jet to fit.
Is your oil fitting removable? It should be. Drilling would be the easiest in that case.
Take the fitting out. Measure the width of the jet and use the properly sized drill bit to widen the internal diameter of the opening.
c41250n
08-09-2007, 08:30 PM
I really don't know, all I know is he went from the driver side behind the front wheel and he had to take off the spark plugs in order to reach to the hose! I'm not even sure if he is on the right hose or not!
I really don't want to bring it back to him! I just don't think he knows rotary well enough!
anybody from nor cal knows a good shop?
rotorocks
08-09-2007, 11:39 PM
This is a turbo mod. It has nothing to do with rotary vs piston engine.
The jet goes into the oil fitting on the turbo not the other end of the oil line. Run away from that mech.
Vasichko
08-13-2007, 10:46 PM
Now does this restrictor only apply to the turbo supplied by GReddy or does this apply with all turbos?
Say a 3071R if someone used that with a Greddy kit?
