lower arms
Old Aug 8, 2007 | 09:41 PM
rally 8's Avatar
lower arms
has anybody seen or heard of heavy duty lower control arms for the RX8 i have had 2 lower balljoint failures-where they have pulled out of the arms
Old Aug 8, 2007 | 10:16 PM
there was a recall on 2004 model year arms for this problem, otherwise I'm not familiar with this being a problem for even racers using high grip racing tires
Old Aug 8, 2007 | 10:18 PM
LCheung's Avatar
Interesting... just heard from a friend in Hawaii that witnessed this happening to a B Stock car on R compounds.
Old Aug 8, 2007 | 10:19 PM
http://www.finishlineperformance.com...lBallJoint.pdf
well the national level drivers here in the states having been pushing their cars hard for multiple years, statistically there will lways be an odd failures of various companents, in my case transmissions though few others have had the same issue ...
Old Aug 9, 2007 | 06:32 PM
rally 8's Avatar
arms
the car is a rally car the cotrol arms take a huge amount of pounding--we compete in the rally-america prorally series-so, in 2 day race we do about 150 mile of off road stage miles--failure will happen again--that is for sure
you don't have to tell me about the trans-i replaced the stock 6sp-(it did not last long after i installed a pettit supercharger) with a 5sp G-force T5 dog box--I did some fab work on that job-it works so much better-fast shifts
for strength i have already welded plates on the cradle where the lower arm mounts, to do away with the camber/caster adjusting slots--then replaced the upper arm with a double swaged tube arm-this upper gives me a very large range of both camber/caster adjustments
looks like some more fab work ahead-went to the local racing shop picked up some rod ends, stud for the balljiont and bushing ends---friday, 4130 chromoly tube should be in
thanks
Old Aug 9, 2007 | 06:39 PM
you rally an RX-8?
Old Aug 9, 2007 | 07:04 PM
WoodsOfGreenRx8's Avatar
I've got to see pictures of this..
Old Aug 9, 2007 | 07:47 PM
expo1's Avatar
He's as bad as Can
Links to photos in https://www.rx8club.com/rx-8-racing-25/rx8-rally-car-110312/
Though you can't see the car, this video claims to be of an RX-8 on a rally, sounds like one.
Old Aug 9, 2007 | 08:29 PM
rally 8's Avatar
rally 8
it's the same car-but better-now i'm looking after the car and i have added a supercharger, G-force 5sp T5 dogbox and hotbits suspenion-with the added speed more issues with the suspenion have come up---lower arms for one
on the video the camera is mounted in the bumper--so you can't see the car
we took 2nd at 100 acre woods in our class
Old Aug 10, 2007 | 06:20 AM
expo1's Avatar
He's as bad as Can
Rally, I know you would rather be driving than posting here but it might be helpful to other 8 owners if you made separate threads about how you did your tranny swap, Supercharger & suspension mods.
Jst4fun
Apr 17, 2021 07:43 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
duworm
Oct 1, 2015 04:57 PM
