Wheel offset help!
Old Aug 7, 2007 | 05:45 AM
Soulflare's Avatar
Wheel offset help!
Hi everyone,
Not too sure about this wheel sizing so hoping you all can help provide some suggestions. I'm planning on fitting 18x8.5 +30ET front and 18x9.5 +20ET rear.
Tires planning to go 245/40/18 all around. I think based on the online calculators, these seems to be closest size without too much variance in the speedo. I'm not too sure with such low offset if it will rub in the rear... Thanks everyone in advance for your help.
Old Aug 7, 2007 | 06:42 AM
The rears will rub for sure.......the fronts will be close...
You need offsets in the +43-+45 range for the 9.5 in the rear. You could get away with +35-+50in the front with 8.5"
Old Aug 7, 2007 | 10:15 AM
MazdaJeff's Avatar
^^^ What he said.
Old Aug 7, 2007 | 11:15 AM
ac3mastuh's Avatar
Got Ings?
since the rear tire is stretched so much its probably going to be the rear wheel that will hit the fender
Old Aug 7, 2007 | 11:54 AM
NgoRX8's Avatar
yea, the rear wheel is too far out.
Old Aug 7, 2007 | 11:58 AM
Im_DANomite's Avatar
I love GOOOLD
with 8.5 you could go as low as +22 (roll fenders and stretched tires). with 9.5 you can go as low as +34 (roll fenders and stretched tires. you can also go 9.5 all around. 10.5 all around will work too. so many options, so many wheels, so many tires, so LITTLE money...
Old Aug 13, 2007 | 03:45 AM
Soulflare's Avatar
Thanks everyone !
Old Aug 13, 2007 | 07:46 AM
Whitehot's Avatar
Mr. Clean
I'm not sure what you are trying to do with staggered wheels but the same size tires front and back. That isn't going to work, especially with staggered diameter as well as width. Something like 245/35/18 in front and 275/30/19 in the back might be good.
Old Aug 13, 2007 | 08:54 AM
take a knitting class instead ...
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
