Braille Battery Relocated
Old Jul 13, 2007 | 05:00 PM
xbeatxdownx's Avatar
Havent cleaned the engine bay yet but its not to shabby
Old Jul 13, 2007 | 05:04 PM
Fanman's Avatar
Nice, definitely looks like it saves a ton of weight. Not to mention moves the center of gravity from the front to further back on the car.
Old Jul 13, 2007 | 05:11 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
That looks nice. Is it a relocation kit? If so, where did you get it?
Old Jul 13, 2007 | 05:14 PM
alnielsen's Avatar
Wow, there is an engine under all those hoses!
Old Jul 13, 2007 | 05:35 PM
scsi's Avatar
isnt there usually a tank of fluid in front of where the battery normally is? what happened to that?
Old Jul 13, 2007 | 05:38 PM
looks pretty shabby to me, I'd be ashamed to post pics of my dirty engine laundry in public
further back, but higher ... not so good
yea where'd u relocate the wipre fluid?
Old Jul 13, 2007 | 06:01 PM
d j's Avatar
d j
hukbong himpapawid
i'jm in the process of relocating my braille batt in the same area only i'm retaining the windshield washer reservoir by using a smaller bottle and adding a prermix reservoir. that all has to wait until i get the billet mount kit from braille that's been on back order for months now
did you crimp the wires or are they soldered?
Old Jul 13, 2007 | 06:31 PM
WTF would you wait months for that; it's not that unique of a size? I believe those for the Odyssey PC680 battery will work, you would need to verify the dimensions
this is the one I used
https://www.rx8club.com/attachment.p...id=94144&stc=1
Old Jul 14, 2007 | 01:55 AM
Ha yeah I'll clean it tomorrow and get a better shot. Been lazy. But no its not a kit, I did it myself and yes it sits higher but in order to not drill more holes in the firewall I used the existing holes used to hold the washer fluid container(which I just threw it in the garage, didnt use it anyway). I think 11.5 pounds up and against the car is still better weight distribution then 37 or whatever pounds in the front of the car.
Old Jul 14, 2007 | 02:25 AM
Digital_Damage's Avatar
Did something along the same lines.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/got-tired-waiting-battey-relocation-kit-107674/
Old Jul 14, 2007 | 01:45 PM
d j's Avatar
d j
hukbong himpapawid
'cause I already paid for it and I like the open design as opposed to a boxed case plus I have the all season battery which is slightly bigger than the regular braille batt and the PC680. also I've read somewhere that you need a gap/space in between the batt and the case.
http://www.brailleauto.com/productca...3&idproduct=11
Old Jul 14, 2007 | 09:15 PM
NgoRX8's Avatar
nice conversion. hmm, i don't use my wiper fluid either... haha
Old Jul 16, 2007 | 07:51 PM
I had the Braille "all-season" battery and replaced it with a PC680 after the Braille completely failed in only 7 months and left me in a position of not being able to wait for a replacement. They are about identical. The PBC680 is a touch bigger actually, but still fit in the custom mount I made at the time for the Braille. The black box was what I used when I moved it to the trunk.
but what I showed you was only one example, there are tons of different mounts out there, including machined open ones similar to the one you ordered
and if "you already paid for it" why would I not be the least bit surprised that your CC was actually charged for something that hadn't been shipped yet, let alone several months .... LOL
but if you want to believe it's truly special then be my guest
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
