Any cause to worry?
Old Jul 9, 2007 | 06:26 PM
Vasichko's Avatar
Any cause to worry?
Noticed something weird today maybe its normal maybe its not.
I was on the highway doing about 70 in 6th and let off and it felt like the car rocked forward then back. I have seen issues with the motor mounts and a TSB or Recall, are these typical symptoms.
Also, when at a redline here and there when not moving, if I shift into first I hear a thud. This normal?
Thanks for the help, and yes I did use the search button...
Old Jul 9, 2007 | 08:25 PM
RxJaye's Avatar
all standard shift cars will do that, the mounts will cause a rough idle and a hesitation around 30 after decell then immediate WOT
Old Jul 9, 2007 | 11:10 PM
Vasichko's Avatar
Originally Posted by abbid
1st gear thud is normal.
rocking back and forth is most likely the TSB for mounts, but the dealership will call it 'hesitation'.
you need to use their keywords or they wont fix it
What key words should I use???
Old Jul 10, 2007 | 02:18 AM
VOODOO8's Avatar
Hermitage Holdout
The key words are actually best recited to a Mazda service tech embedded in the following phrase: "Obiwan, is that a rocket in your pocket or is the force with you?"
Old Jul 10, 2007 | 07:51 AM
Vasichko's Avatar
LOL... Good stuff.
WranglerFan
May 31, 2022 07:51 AM
LB2739
Jul 9, 2019 02:25 AM
GM Enthusiast
Oct 19, 2015 07:31 PM
thewatcher101
Sep 18, 2015 01:48 PM
Juan Montenegro
Sep 10, 2015 06:28 PM
