strange clunk when turning right
Old Jun 9, 2007 | 05:55 PM
Moonrover333's Avatar
My Goodness My Guinness
Angry strange clunk when turning right
ok so lately i've noticed a 1 time clunk every time i turn right. its at any speed at all. it souds like something binding or loose. i looked underneath and all seems tight. today it did it on a few left handers which is a first. it never does it under striaght accell or deceleration. it also won't do it when not rolling if you turn wheel back and forth. so basically if i'm moving forward and making a righ hander it clunks once. it sounds like its comming from the right front in the driverseat but passenger says its from front left. ANY CLUES WOULD HELP. also its louder at low speeds it seems
Old Jun 9, 2007 | 06:01 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Just for grins...............have you done anything to the car lately? First thing I would do is go make sure your lug nuts are tight. Probably are because no shimy while going straight, then you gotta start looking at things in the suspension area.
Old Jun 9, 2007 | 07:19 PM
lugs are tight and suspension seems plenty tight.
Old Jun 9, 2007 | 07:22 PM
dastallion951's Avatar
might be ur axle....?
Old Jun 9, 2007 | 07:23 PM
Check the end links. And the sway bushings
Old Jun 12, 2007 | 01:15 PM
Nubo's Avatar
Lubricious
Use a torque wrench to insure that the wheel lugs are tightened to 108 lb-ft of torque. This specification was in response to noises, especially during low speed turns.
http://www.finishlineperformance.com...2-04-1301b.pdf
Old Jun 16, 2007 | 05:05 PM
yea but at the same time nubo factory manual calls for torgue to be i believe it was 78-95 doin it too 108 will snap the stud or strip the lug nut
Old Jun 16, 2007 | 05:30 PM
jskup1's Avatar
The Chief
Yes, you may need some grease on the bushings.
Old Jun 20, 2007 | 01:59 PM
dmc27's Avatar
doin' the bull dance
had more of a barely audible clicking to mine. torqued to 108 and it's gone.
mazda wouldn't change the specs to something that would snap/strip.
Old Jun 20, 2007 | 11:41 PM
ive seen the book thats said what the torque for the lug nuts for the rx8 are gone, watch see what happens when u try n loosen ur lug nuts up when u take the wheel off..........
Old Jun 21, 2007 | 12:57 AM
wtf are you talking about????
the tsb is out there... i have been using 108 ft lbs.. for 60 k of the 70k miles on my car.....
let me know if you understand that..
Old Jun 21, 2007 | 10:50 AM
dmc27's Avatar
my mechanic must just use some sort of magic wand, then. nothing broke when the winter set was removed - they were at 108.
maybe you're confusing the issue. some have broken when knuckle-dragging jackholes neglect to use a torque wrench. but that's b/c of the knuckle-dragger, not the torque specs.
Old Jun 23, 2007 | 11:35 PM
well ive seen a book that said torque specs were 79-87.......now if theres a tsb out on it, i havent seen it but ive always gone by what the book said....ive never had an issue.
Old Jun 24, 2007 | 12:11 AM
no,
i made the whole tsb thing up.. vana.. there is no vowel in tsb...
you are right, my wheels just fell off..
Old Jun 24, 2007 | 12:33 AM
Brettus's Avatar
Boosted Kiwi
moonrover - take that dead body out of your boot .
Old Jun 29, 2007 | 09:31 PM
vIce^gRip's Avatar
Honor & Integrity
LOL...
it is OK and my dealer as well suggested a high lug torque even on my after market rims with this clunking noise way back when. In my case they got a bit happy and when it came time to remove a wheel I had broken lugs... but anyway...
I will take a stab at this issue....
Try finding a nice newly paved parking lot. Turn the wheel in any one direction... (Left or Right) and then steadily but slowly accelerate doing circles... NOT DONUTS. If you hear that clunk or feel any sort of drag then we may have found the issue.
Try turning off the DSC and then do the same thing... it probably will not occur.
Press and hold the DSC for 10 secs to completely disable the DSC (slip & Trac). Try it again... You may even spin out now, but if that clunk does not appear it is probably just the DSC doing what it thinks is its job. It is breaking your front wheel cause it thinks it will lose traction at the rate of turn you are in. that is what that clunk may very well be.
Took me weeks to figure this out when I dropped to my low profiles on 19" rims... it drove me nuts too.
Hope this may have helped.
Old Jun 30, 2007 | 03:08 AM
Originally Posted by vIce^gRip
LOL...
dan,
you are smart like tuna..
without the wheels and tire info.. this is mute.. the other idea is loose sway...
Old Jun 30, 2007 | 07:41 AM
vIce^gRip's Avatar
Honor & Integrity
Originally Posted by swoope
dan,
Yes that too... A loose or un-greased sway!
I have RB sways and after the Dragon run (us129) I must have squished all the bushing grease out... The sway also makes a grinding kinda clunk noise and if not greased will get progressively louder and more frequent.
92trbolzr
May 18, 2025 09:04 AM
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
D13
Oct 1, 2015 07:55 AM
Racingjunkie
Sep 29, 2015 05:05 PM
