Possible rough idle issue
Old Jun 7, 2007 | 02:11 PM
clarky99's Avatar
06 Rx 8 with 5000 km on it. When i come to a stop and open the clutch the rpms drop slowly and predictably to 1200 then to 1000 then they fall to approx 500 and the engine sounds like it is chugging, then they rise back to 800 for a while, then fall off to 500 again.
Its not like the rough idle video that has been posted, but rough nonetheless.
Any ideas?
Worth getting checked out or will I be wasting my time?
Old Jun 7, 2007 | 05:08 PM
corners's Avatar
An RX ate my baby
Get it checked out. Did you have the recall done?
Old Jun 7, 2007 | 05:44 PM
StealthTL's Avatar
Metatron
Cool Leak....
A small vacuum leak will do that - check the little 1/4" line that comes out under the throttle body on the drivers side, make sure it is on. Pinch it shut, see if the idle gets better, to rule out leaks further up the line.
S
ladnarf1
Apr 29, 2021 11:53 PM
rotor001
Jan 16, 2016 11:27 PM
Quiggs321
Sep 3, 2015 04:28 PM
harithac
Aug 26, 2015 09:24 AM
netrovers
Jul 20, 2015 03:32 AM
