Ultimate reading incorrect rpms
Old May 15, 2007 | 09:26 AM
batmobile-rx8's Avatar
Ive been trying to tune out a lean spot in the upper rpm's but the ultimate isn't reading the right rpm's. When I use map trace and datalog the rpm's and rev it up in neutral, it pulls values from the right columns and reads the rpm's just fine. But when I go and do a 3rd gear pull to redline it only reads up to 8200-8300 and wont get the right values in the maps so its running lean. I cant figure out why it wont read it right when its under load. I searched and didnt come up with anything. Anyone have any ideas? Thanks.
Old May 15, 2007 | 10:02 AM
dastallion951's Avatar
isnt there an actuator that opens right around those rpms................???? becuz i know one opens around 4500 then one open around 7k i believe.......then another one around 8k im not too sure....... but just a suggestion
Old May 15, 2007 | 10:25 AM
Nemesis8's Avatar
Bigus Rotus
^ You need to go back SDAIS school
SSV Secondary Shuttle Valve opens around 4800 RPM
APV Auxillary Port Valve opens around 6250 RPM
VDI Variable Dynamic Intake Valve opens around 7200 RPM
I don't this has anything to do with his question though
Old May 15, 2007 | 10:43 AM
No its not a problem with the valves opening. The upgrade kit (thats what I'm using) disables them and uses a blocking plate anyway. The problem is the emanage not reading the correct rpm's under load.
Old May 16, 2007 | 04:56 PM
Just a thought that came to me today. Maybe the ultimate is reading the correct rpm's and the tach is not as precise? So I shouldn't worry about it. Anybody agree with this?
Old May 16, 2007 | 05:01 PM
Brettus's Avatar
Boosted Kiwi
tach is about 500 rpms out at peak rpms .
when you are doing 9000 tach reads 9500 .
Old May 16, 2007 | 10:30 PM
Thank you very much! That's what it's off by. Problem solved (even though it never existed)
gwailo
May 14, 2024 06:57 AM
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
WranglerFan
May 31, 2022 07:51 AM
Mane
Nov 20, 2015 12:16 PM
Tsurugi
Sep 7, 2015 08:27 PM
