Location of VSS??
Old May 9, 2007 | 10:00 PM
vangos1's Avatar
Location of VSS??
Can anyone help me locate the location of the wire for the VSS...I have found it for the auto but can't find location for 6 speed manual?? can someone please help....Thanks..
Old May 9, 2007 | 10:06 PM
lurch519's Avatar
www.evoperform.com
green with red stripe, radio harness, which is convienent, as the only 2 things you would need that for are either a turbo timer or a nav system
Old May 9, 2007 | 10:23 PM
MazdaManiac's Avatar
?? The M/T doesn't have a VSS. It has speed sensors on each of the wheels that feed the Bosch stability system.
The auto has an output shaft speed sensor.
Old May 10, 2007 | 08:02 AM
lurch519's Avatar
www.evoperform.com
well, i got that info from directechs, which is directed electronicsl dealer site. i also visually verified that there is a green/red wire a behind the radio.
Old May 10, 2007 | 01:39 PM
You are right! There is a green/red wire that extends from the ABS control module to the radio, the navigation system and the headlamp auto leveling system.
Now I need to go scope that and see what actually goes down that wire.
Old May 10, 2007 | 04:35 PM
lurch519's Avatar
www.evoperform.com
lol, directechs.com rarely ever lets me down.
nferguson88
Oct 6, 2015 12:45 PM
Sato Tatsuya
Oct 5, 2015 03:09 PM
alming1132
Sep 30, 2015 11:30 AM
tommy26Germany
Sep 29, 2015 10:33 AM
