Low speed rubbing noise?
Old Apr 12, 2007 | 06:25 PM
aerospacediver's Avatar
06 rx-8 with 19k miles. Ive started to notice a rubbing noise when i pull out of parking places at very low speeds. Im pretty sure its comming from the area around my left rear tire and goes away as soon as I pass 5 or 6 mph. I cant figure out what it is and its driving me nuts. Maybe the parking brake is sticking?
Old Apr 12, 2007 | 06:39 PM
NoTears316's Avatar
Shock and Awe
Possibly brakes. Was it in storage for any period of time?
Old Apr 12, 2007 | 09:29 PM
No storage, drive it at least 10 miles a day
Old Apr 12, 2007 | 10:56 PM
Shinka/10AE's Avatar
I have noticed the same thing... I didn't know if maybe it was a wheel bearing or something like that, but every time I got done driving the rim was cool to the touch... so I, like you, am completely confused!
Old Apr 12, 2007 | 11:15 PM
DarkBrew's Avatar
Extraordinary Engineering
Could be tire noise. The RE040s will make a noise like that.
Old Apr 13, 2007 | 09:38 PM
I cant quite figure it out. I think its either a bearing or maybe the parking brake. Also I think I notice it more when my car is turning rather than driving straight.
Old Apr 22, 2007 | 11:58 PM
climacus's Avatar
It's the brake shield.
Old Apr 23, 2007 | 05:10 AM
#1Stunna's Avatar
Did you put after market rims on your car? I noticed mine did the same thing when I bought and installed my rims. If you did, and your rims are not rubbing, then this should go away soon just like it did with me.
Old Apr 23, 2007 | 05:54 AM
Smileynh's Avatar
2 Questions:
Does it only happen if you're making a slight turn, say out of a parking lot?
Does it only happen if you've driven say 30+ miles?
My car has been doing this lately. It's something to do with the differential from the searches I've done. Sadly I haven't had time to bring my car into the dealer. So owners have had luck with syntetic diff. fluids.
NH
Old May 4, 2007 | 07:57 PM
hdh748's Avatar
I have noticed this tire scrubbing noise from the rear tires only occurring when at very low speeds and then only when turning. It never happens if going straight ahead. It seems to be noise from the tires in the rear. I tend to think it is caused possibly by the limited slip differential.
I don't think it is serious, but I to would like to be certain what is happening!
Old May 7, 2007 | 06:28 AM
supergoat's Avatar
I don't "smell good".
My car does this too. I'm taking it in soon to be looked at by the dealer. Warranty!
Old May 13, 2007 | 02:27 AM
dastallion951's Avatar
ur rear tires could be rubbin against ur struts...........that could be ur issue right there, or it could be an LSD issue, u ever had the rear diff serviced..............n if so did they put a limited slip additive in it?
Old May 14, 2007 | 02:13 PM
us41300's Avatar
SanaWana
I've also had the same problem. And it only happens when I'm pulling out of a parking spot or turning into one, or sharp turns at low speeds.
I have to go to the dealer for some other problems I'm having, so I'm planning on checking with them, because it didn't do it when I first bought the car.
WingleBeast
22
May 23, 2016 09:22 PM
rotor001
Jan 16, 2016 11:27 PM
Kanthinar
Dec 21, 2015 01:24 PM
GrAfiX
Aug 24, 2015 08:08 AM
D13
Aug 22, 2015 11:42 PM
