Won't start
Old Apr 7, 2007 | 07:03 PM
Drizzt8's Avatar
"Here comes the Pain"
Exclamation Won't start
I know some of you have had this happen as well...I started up on Thursday morning (was parked outside)...moved it into the garage and swithced it off and went back to bed. Thursday evening car won't start..I think I may have flooded it...any deflooding suggestions worth trying or is it best to get it towed to the dealership???
Any suggestions will be appreciated
Old Apr 7, 2007 | 07:06 PM
mattvit's Avatar
you can try the deflooding but if it doesnt work, ull have no choice to send it to dealer.........i had this happen, and my plugs needed to be changed cuz of over flooding.........dude, NVER start the car, move it and shut it off thats the biggest nono with an 8 man.....always let it run to warm temp. did you get the "flooding" update from the dealer yet?
Old Apr 7, 2007 | 07:13 PM
Drizzt8's Avatar
I know I have had my 8 since 2005, and had never shut it off without the temp gauge getting to the middle...brain cramp I guess...but no, I did not get the flooding update from the dealer...tried the deflooding suggestion that was posted on the Issues and Problems bit, removed the fuse...tried to start about 10 times, then replaced the fuse and tried starting again...no luck...any other deflodding techniques out there? Thanks
Old Apr 7, 2007 | 07:21 PM
Brettus's Avatar
Boosted Kiwi
If you are still under warranty - a tow to the dealer might be in your best interests . If not pull start the car in 2nd gear . Do you know how to do that ?
DarkBrew's Avatar
Extraordinary Engineering
Dealer time!
You'll get the upgrades at the same time.
Good luck.
Old Apr 7, 2007 | 07:26 PM
Drizzt8's Avatar
Don't know how to do the 2nd gear thing Brettus?? Do you just push start while in 2nd...if that doesn't work I guess I'll have to wait til Monday to get it towed in...yep...I am still under warranty. Thanks guys
Old Apr 7, 2007 | 07:30 PM
mattvit's Avatar
dude, your car wont start......the spark plugs are covered in oil.....mine did the same thing.....had to bring it to the dealer...dont even try to de-flood it anymore. it wont help......the dealer will upgrade your car. why didnt you get the recall yet? i have a 2005 and i had it done last august.....???
Old Apr 7, 2007 | 07:34 PM
Brettus's Avatar
Boosted Kiwi
I'm assuming you have a 6spd MT because this won't work with an auto .
Hook up a tow rope to another car
foot on clutch & into 2nd gear & ignition on
tow at about 10 -15 mph
let clutch out
when car starts clutch in & wave down towing car - things can get hairy doing this for the first time so work out how it will go down in advance
Only do this if you really need your car now - as the others have said you will get the upgrades for free if you get it towed in .
Old Apr 7, 2007 | 07:35 PM
mattvit's Avatar
dude, his car wont start.....its flooded, the plugs are soked in oil/gas....they wont spark.....trust me it happend to me
let clutch out
Old Apr 7, 2007 | 07:37 PM
Brettus's Avatar
Boosted Kiwi
dude - tow starting will fix this .
Old Apr 7, 2007 | 07:41 PM
Drizzt8's Avatar
coz I did not get a recall notice...the only one I have had done so far was for the 4206F one.
Drizzt8's Avatar
What is replaced or upgraded in the 'flooding' recall??
Old Apr 7, 2007 | 07:45 PM
mattvit's Avatar
i beleive they change the ECUprograming to control the amount of fuel injected apon start up and also to take care of the flooding issue.....some thing like that. i dont know where i placed my notice, or else ide be able to tell you word for word what it says...
Old Apr 7, 2007 | 07:48 PM
Brettus's Avatar
Boosted Kiwi
flooding was not a recall - Just something they will fix if it is reported .
Plugs , starter ,battery will be replaced - if you get lucky
Old Apr 7, 2007 | 07:51 PM
Drizzt8's Avatar
Thanks for all the help guys, but methinks I'll have Mazda Roadside tow it to the dealer...I have a second car so not worth the risk with the 2nd gear technique (thanks Brettus though)...besides free upgrades are sweet!!! Oops..my 8 is lowered, would I need a trailer to get it towed??
Old Apr 7, 2007 | 07:52 PM
mattvit's Avatar
always get a flat bed, for your 8........
Old Apr 7, 2007 | 07:54 PM
Drizzt8's Avatar
Flatbed it is then....thankx guys.
Old Apr 8, 2007 | 06:05 PM
Drizzt8's Avatar
just had it towed to the dealership by Mazda Roadside..is there anything I need to tell the service dept. other than the obvious ...thankx.
Old Apr 8, 2007 | 06:09 PM
DarkBrew's Avatar
Just get them to check the recall record of the car to see if anything else has been missed.
If you have brake squeal be sure to mention that to get the brake pad 'upgrade'
Good luck!
Old Apr 8, 2007 | 06:17 PM
Drizzt8's Avatar
Thankx Brew'...appreciate that!
Old Apr 10, 2007 | 05:13 PM
Drizzt8's Avatar
Just an update...the dealership had the starter and plugs replaced...and since I encountered a mysterious "brake squeal" I got a brake repalcement as well. Thanks for all the help guys.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
Modern2Strokez
Aug 16, 2015 01:07 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
