KNIGHT SPORTS coming to town!!
Old Mar 22, 2007 | 08:16 AM
coupe07's Avatar
SC 300HP!!
Dear all,
Renowned rotay specialist "KNIGHT SPORTS" is coming to town sometime mid April 2007.
They will be doing remapping.
Light tune = $750
- Speed cut
- Fan control to lower water temp
Basic tune = $1200
- Speed cut
- Ignition timing
- Smoothen pitch graph
Light tune is more for those looking at speedcut only.
Basic tune is more for the hardcore enthusiasts, who are looking to optimise the rx8 exhaust system and their car performance.
JDM cars (ie, PI cars) no problem at all. Just standby for remapping.
However for MM cars, the unfortunate news is you have to remove ur ECU (warranty void) and send to japan to re-draw a new map. Reason being MM cars are Euro models and are de-tuned to suit euro emission. Maps are different from JDM maps and different batches have different maps. However i shld think this shldn deter the hardcore fellas.
*Malaysians and overseas RX8 owners are welcomed to enquire as well.
Exact dates to be confirmed once things are finalised.
Pls PM me early to avoid disappointment. Thank you.
Old Mar 22, 2007 | 10:25 AM
I+Z=IZ's Avatar
Wad is the difference between the stock MM ecu & the flashed one? 250 ponies?
Old Mar 22, 2007 | 11:29 AM
coupe07's Avatar
SC 300HP!!
the difference is explained above, except for the speed cut. U will not achieve 250 ponies straight off from the remap......
Old Mar 22, 2007 | 06:13 PM
muscleman's Avatar
Silver 8
Coupe7,
What do you mean by speed cut? So does a decrease in the water temp result in a cooler engine??? All these are achieved by remapping the ECU?
Old Mar 22, 2007 | 08:26 PM
sqflyer's Avatar
Heavy Machinery Operator
Answer on behalf of C7.
A1) JDM 8s are electronically limited to a speed ~187km/h, otherwise known as "speed cut". If you have not gone above 187km/h, you will not notice this.
A2) Water temp is a measurement of your coolant, thus a lower water temp means more efficient cooling for your engine.
A3) Yes.
Old Mar 22, 2007 | 10:10 PM
coupe07's Avatar
SC 300HP!!
Originally Posted by tatoo
Hi Bro Coupe....
Great...can't wait man!!
Just a question, what if we were to take a JDM 6MT ECU and put it into a MM 6MT.
Will it work to bring out the full 250HP?
Am wondering...hmmmm
Anyone tried this before???
Tatoo@
in the first place, u cannot swap a JDM ecu with a MM ecu. The car will nvr start due to immobiliser issue between 2 cars..
Its the same theory with 4AT JDM models... u can only swap if both cars do not have the immobiliser system.
Old Mar 22, 2007 | 10:13 PM
muscleman's Avatar
Silver 8
Am I right to say that once the ECU is changed or "modify", the warranty will be void?
Will it affect the FC since the engine is cooler?
Old Mar 22, 2007 | 10:19 PM
coupe07's Avatar
SC 300HP!!
Originally Posted by muscleman
Coupe7,
Speedcut, flyer has answered on my behalf.
For fan control, wat it does is, the ecu will be set to kick in ur fan earlier.... resulting in lowered temperature. For eg, maybe factory setting is for fan to kick in at say, 95deg...... this tuning sets the fan to kick in at ard 85deg... thus lower temp = better cooling for engine, as echoed from flyer's thread.
All these achievable by tuning ecu.
Old Mar 22, 2007 | 10:26 PM
coupe07's Avatar
SC 300HP!!
ur warranty is with ur PI workshop. This shld not be an issue becos:
1. PI workshops do not have the equipment to update any latest maps from mazda, which MM does, ur remapped ECU data will stay put.
2. No one will noe ur ecu has been touched before unless u tell them.
As for FC wise, cooling of engine has nothing direct to do with FC so answer is no.
Old Mar 22, 2007 | 10:28 PM
muscleman's Avatar
Silver 8
So this is one of the only way to make our rotary engine cooler. Better cooling means longer lifespan of the engine.
Old Mar 22, 2007 | 11:06 PM
sqflyer's Avatar
I don't mean to pick on your English, but "one of the only way" is a bit of a contradiction. But just to share some info... there are many ways to cool your engine. Just to list a few...
1) Bigger radiator
2) Bigger oil pan
3) Bigger/more oil cooler
4) Better coolant
5) ECU tuning
6) Battery relocation
7) Vented bonnet
Old Mar 23, 2007 | 01:56 AM
muscleman's Avatar
Silver 8
paiseh... type too fast and overlook. I mean one of the many ways...
Old Mar 23, 2007 | 02:04 AM
muscleman's Avatar
Silver 8
1) Bigger radiator
2) Bigger oil pan
4) Better coolant
5) ECU tuning
7) Vented bonnet
Is vented bonnet LTA approved?
Can MG do battery relocation?
Old Mar 23, 2007 | 02:29 AM
coupe07's Avatar
SC 300HP!!
to answer for flyer:
1. vented bonnet is nvr illegal in the first place, or not that i know of
2. battery relocation - theres is a relocation kit available. If u wan customisation job to relocate it to boot, we generally do not recommend due to various reasons... anyway lets not go into dat now.
Old Mar 23, 2007 | 05:32 AM
clarencel's Avatar
1) Bigger radiator
2) Bigger oil pan
4) Better coolant
5) ECU tuning
7) Vented bonnet
may i ask how battery relocation helps in better engine cooling? and by battery relocation, would it mean a kit like the one RE-Amemiya has?
Old Mar 23, 2007 | 07:13 AM
sqflyer's Avatar
If you wanna stay legal, you're not supposed to meddle with your ECU anyway.
Battery relocation creates space for the air to flow. Yes, RE has a battery relocation kit.
Old Mar 23, 2007 | 09:15 AM
Stephy88's Avatar
in'sti·ga'tor
Knight Sports... woooo...la la....
Old Mar 23, 2007 | 10:36 AM
lennon's Avatar
Relocation is good, but you still need a vent to disperse the hot air.....
Old Mar 23, 2007 | 10:40 AM
clarencel's Avatar
ic.. that makes sense...
any idea how much RE's batt relocation kit is?
or are there other options?
clarencel's Avatar
hence a vented hood i assume?
Old Mar 23, 2007 | 10:47 AM
lennon's Avatar
logically, air comes in, air goes out...... but the bloody weather can flood you engine bay........ Unless you're hard working enuff to take the drain cover on and off....
Old Mar 23, 2007 | 12:35 PM
Red Shinka's Avatar
Dear all,
Light tune = $750
- Speed cut
Basic tune = $1200
- Speed cut
- Ignition timing
Thank you.
I'll like to confirm a spot for the basic tune-up. Hv oredi pmed u. tks...
Old Mar 23, 2007 | 04:17 PM
Rei's Avatar
Rei
White Rotary
Yes! Finally! Knightsports is coming! My wait has not been in vain...Missed the 2
RE visit becoz I wanted to wait for Knightsports...
Bro, u got save a space for me?
Old Mar 23, 2007 | 08:44 PM
Drifter's Avatar
Yo Ivan,
Are the tuning meant for 4AT as well?
What does the these items do to your car? More HP?
-Ignition timing
-Smoothen pitch graph
Cheers ....
Old Mar 23, 2007 | 11:51 PM
artistknownasbush's Avatar
artistknownasbush
hi, mine is a MM 6MT; what is the process and how long does it take if i send my ECU over for remapping?
