View Full Version : HID light or halogen?
eugenewang55 03-15-2007, 09:19 PM does anyone here know ways to check either ur rx8's light is HID or not??
my friend told me that if its white then it must be HID....but since my rx8 is the touring edition and it doesn't come w/ factory leather...so i thought its not...however the light is not yellowish to me at all......and if its not HID....i saw some bulb w/ code h7 on ebay ...but they are hid bulb....can i still install those on my car...??
thx for all your helps....appreciate it
RX8SaxMan 03-15-2007, 09:29 PM If you have the touring package you have HIDs
eugenewang55 03-15-2007, 11:49 PM sry i mean sports package
CarAndDriver 03-15-2007, 11:55 PM Every 8 except the base model has HID. If you're car has a DSC switch on the left side then you have HIDs. HIDs also make a slight flash and change color slightly after you turn them on.
eugenewang55 03-17-2007, 07:57 PM well i have base model...but w/ fog lamps(the two small rounded lamb below front light; can be turned on/off independently of the main lamp) and dsc...my low bean is also significantly whiter comparing w/ the parking light....since im planning to change my bulb, just wanna make sure im having an hid...does my option come w/ HID???
thx for all the helps provided
appreciate it
dillsrotary 03-17-2007, 08:09 PM the HID bulb code is ds2 i believe, the NON hid bulb code is h7.
You should be able to tell, the HID's look way different than the non hid's. They non hids look like every other car on the road, that normal yellowish/white headlight color, the hids are alot whiter with a tad of blue/purple.
Phantom Menace 03-17-2007, 08:17 PM The HIDs make a humming sound when turned on...that and HIDs are standard on Touring and GT models...
Detrich 03-17-2007, 08:34 PM they also are self-leveling, if i'm correct. when u turn the headlights on, if u see them self-level, then they're HIDS.
mysql101 03-17-2007, 09:13 PM my hid's look blue when i first turn them on.
llzjayarzll 03-17-2007, 09:20 PM ^^ yea u got HIDs if theyre bluish at first lit, then change to regular lighter white color. halogens dont do that
eugenewang55 03-17-2007, 11:15 PM how do u tell if light is self-leveling?
dillsrotary 03-17-2007, 11:23 PM how do u tell if light is self-leveling?
you really can't, it just does it itself, i've never seen mine ajust. The driver side will always be a tad lower than the passenger side too, thats normal as well (so you don't blind on coming traffic)
Rotary Rasp 03-18-2007, 01:10 AM Park with the drivers wheel on the sidewalk and the other in the street. Then turn your lights off and then back on... You should see them move.
Rotary Rasp 03-18-2007, 01:12 AM btw, the auto leveling sensors are on the drivers front and rear wheels.
Detrich 03-18-2007, 02:26 AM exactly. u will see the beam move or shift very slightly when initially turning them on. it's subtle, so you'll want to park with your headlights pointing towards a wall or flat surface and turn on the beams when it's dark- ie so u can see the light beam.
TomAssBender 03-18-2007, 03:22 AM you really can't, it just does it itself, i've never seen mine ajust. The driver side will always be a tad lower than the passenger side too, thats normal as well (so you don't blind on coming traffic)
Ahhh and I thought my shit was fucked up! Phew. Dill is a well of knowledge.
Anyway, I know mine are HIDs cause they make the green grass appear to be this awesome color in the summer when i start it up.
stickmantijuana 03-18-2007, 10:03 AM green grass, awesome color? think u should avoid the pipes before driving. :) jk
eugenewang55 03-18-2007, 04:15 PM uahh...im still not sure abt the package i have.....can anyone here be sure that if u have foglight and dsc then the package include hid lamb...??
btw the light does make a humming sound when i first turned them on....but not sure if the its bluish enough to be identified as hid since there are all kinds of coated halogen bulb to imitate hid in markets these days.
dillsrotary 03-18-2007, 04:19 PM we've helped you about all we can eugene haha, good luck on this journey
eugenewang55 03-18-2007, 05:22 PM haha thx anyway....u guys r great
RX8SaxMan 03-18-2007, 06:29 PM uahh...im still not sure abt the package i have.....can anyone here be sure that if u have foglight and dsc then the package include hid lamb...??
YOU HAVE HID.
mysql101 03-18-2007, 09:40 PM but not sure if the its bluish enough to be identified as hid since there are all kinds of coated halogen bulb to imitate hid in markets these days.
Our HID's will appear blue for a few moments. Once it's warmed up, it will be a pure white. If the bulb was colored, it wouldn't change to white afterwards..
