[ForSale] Hurricane Drop-in Air Filter
Old Mar 5, 2007 | 09:25 PM
chua_richard's Avatar
Hi all,
I have the following used (less than a year old) Hurricane Air Filter for RX8 for sale. Selling for $80 only.
If you are interested, please contact me at chua_richard3@hotmail.com
Thanks,
Richard
Hurricane Drop-in Filter For RX8
Looking for an alternative to K&N drop-ins for your RX8?
Hurricane Air Filter Element uses Japan's highest rust proof Stainless Steel for our filter element.
The uniform microscopic holes (180 mesh) on Hurricane wire mesh ensures very consistent filtration and airflow. Thus allowing engines to breathe better as compared to the inconsistency airflow of cotton/foam filter.
With a simple Hurricane panel filter, you can expect a decent horse power gain from mid to high RPM. Acceleration is smoother and faster. The feeling is like changing to an open pod air filter.
Hurricane filter will still deliver its promised filtration without compromise under extreme temperature. The filter element is strong and will not be easily shifted even under extreme pressure.
Unlike oil-based filters, Hurricane filter causes lesser contamination to the MAF Sensor due to the absence of oil. (Note: Oil + Dust = Sticky Dirt)
Hurricane filter frames are made from specially treated rubber instead of injection molding, thus ensuring a stronger structure and longer lifespan.
FUEL SAVER
With a noticeable increase in torque and power due to an easier breathing engine, one may gain extra mileage of up to 10% just by changing to Hurricane Stainless Steel Air Filter with the same driving style
SIMPLEST IN MAINTENANCE
Hurricane Filters are the easiest to maintain. Just use water and light soap. Blow dry and its ready to use ! Cleaning is recommended during every oil change of 5,000km or 10,000km.
Benefits
More Power, Smoother Acceleration, Increase in Power due to higher air flow. Significant Mid to high end torque gain. Prolong lifespan of MAF sensor. No more contamination of
MAF sensor
Easiest to Maintain. No Oiling needed. Wash and blow dry.
Longer lasting, more durable than other leading brands. Element made from Stainless Steel, frame made from high quality treated rubber. Will not melt or warp melt under extreme heat.
Fully LTA Compliant
Fitting Hurricane air filter will not affect the structural integrity of the vehicle.
Attached Thumbnails [ForSale] Hurricane Drop-in Air Filter-hurricane2.jpg   [ForSale] Hurricane Drop-in Air Filter-hurricane1.jpg
Old Mar 7, 2007 | 09:24 AM
Thanks all, sold liao.
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Danield97
Sep 30, 2015 05:59 PM
drlubell
Sep 26, 2015 11:58 PM
