the seat belt is jammed, it's out of a wreck
Old Feb 18, 2007 | 11:47 AM
js.l's Avatar
thats it I bought a seat belt off a car wich had his air bags deployed , I know there is a detonation device to put tension on the belt when ever air bags are being deployed but does it make the belt unusable once it blows up? I dont know if the explosive stuff is blown or not and I don't feel like putting direct current to the connector. If it would be blown would the belt be completely blocked? Is there anyway to unlock it?
Old Feb 18, 2007 | 11:56 AM
StealthTL's Avatar
Metatron
Talking They are "used"....
Seat belts are a "use once" item - they are only good for one crash....
However, if you crack open some shotgun shells, you can re-pack those airbags, see my DIY!
S
Old Feb 18, 2007 | 12:12 PM
js.l's Avatar
and how do I get to know if it's blown?
Old Feb 18, 2007 | 01:40 PM
Check the resistance of the connectors and PM me the result...I can compare it to the value of a new one and see if it is the same.....might work.
I would expect that if the airbag deployed...the belt tensioner would have as well...and you are **** out of luck.....
alming1132
Sep 30, 2015 11:30 AM
DeltaJ802
Sep 29, 2015 01:20 PM
tommy26Germany
Sep 29, 2015 10:33 AM
