intercooler sprayer?
Old Feb 8, 2007 | 10:02 PM
LiL BenNy's Avatar
Bubblicious? DEF.
does anyone have the intercooler spray by cryo2 or NX? do they actually work? any input?
Old Feb 8, 2007 | 10:31 PM
Fanman's Avatar
I had it on my car when I was turboed. It did work but unless you are a hardcore drag racer it really isn't necessary. On a track it is really not practical as you need to push the button for it to spray onto the IC. Not exactly easy to do while you are driving around a corner. The CO2 system makes more sense if that is all you are using it for, as it is much cheaper to fill than NO2 system (about a $1/lb. vs. $4/lb for NO2 and it is more readily available). But the NO2 would be interesting if you could setup a system that sprays into the intake, while at the same time sprays onto the IC.
Old Feb 9, 2007 | 01:36 AM
MazdaManiac's Avatar
Most of the EMS systems on the market can be set up to spray the intercooler when you are in boost or if some preset condition like intake temp is exceeded.
I'll probably try one of these out over the summer (got an offer at SEMA from the NX folks).
Old Feb 9, 2007 | 02:19 AM
Fanman's Avatar
I never got that far into it. My system just came with the standard arming switch, and button to push when you wanted to spray the IC. I actually called DEI to see if they had something like that to spray automatically under boost or at WOT, but they said no.
Old Feb 9, 2007 | 02:23 AM
Fanman's Avatar
Here is a picture of my system :
Later on I got a second smaller spray bar to cover more area on the IC (I was running two spray bars on my IC).
Old Feb 9, 2007 | 05:24 PM
LiL BenNy's Avatar
Bubblicious? DEF.
well i saw on th DIY network vid of the cry02 on a SRT4 and they did use a WOT switch..
Old Feb 9, 2007 | 06:06 PM
Fanman's Avatar
I'm not sure it could be this :
Timer Switch
Since I have had the unit they have added a few things onto this system.
Also this :
IC Water Spayer
These weren't items they had when I first got the unit.
BTW, if you interested in it, but don't want to drop a lot of $$$ I will sell you my unit for cheap. I'm no longer turboed.
Old Feb 9, 2007 | 07:25 PM
gr8rx's Avatar
im interested, how much ? send me a PM
Old Feb 9, 2007 | 10:32 PM
whoneedspistons's Avatar
you can make one yourself... there is a write up in performance and sound... i will see if i can drum it up somewhere...
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
Fickert
Sep 9, 2015 01:21 PM
