Not starting before the 3rd-4th crank
Old Feb 2, 2007 | 07:23 PM
titaniumgr3y's Avatar
JDM-8
Exclamation Not starting before the 3rd-4th crank
It might take even 4 times to crank it before it start.
I have this problem since my 8 got flooded.
My car was starting up from the 1st or 2nd time maximum before i flooded it.
It has 25k miles on it, which is close to replace spark plugs, but i am not sure if the problem comes up from the battery or from the spark plugs.
What are the "need to be replaced sparks" symptoms ?
Old Feb 2, 2007 | 07:25 PM
rxb ike's Avatar
Take it to dealer, they might replace plugs , starter and battery for you for free under warranty . I only complained of difficult to start after cranking it twice and they took care of it.
Old Feb 3, 2007 | 04:49 AM
JDM-8
i dont think that is the starter, because it gives power the the engine,,, for the battery i wouldnt say for sure that is not the problem, thought it turns the engine... i think is the plugs...
But do the plugs do this at the end of them life? or after a flood?
Old Feb 3, 2007 | 05:32 AM
Go48's Avatar
Plugs should probably have been replaced after the flood.
There is a service bulletin on the starting problems that calls for replacement of the battery and plugs, and the install of an upgraded starter motor. If you haven't had that done, take it to the dealer along with a copy of the service bulletin. This bulletin is intended for just your situation, and it won't cost you anything other than your time.
EDIT: Go here for the service bulletin:
http://www.finishlineperformance.com...48-06-1691.pdf
EDIT 2: Oops, I didn't notice your location. The service bulletin may not apply to your car.
Old Feb 3, 2007 | 05:59 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
TG3:
In the US, the 8 hit the dealer floors in Spring/Summer 2003 as a 2004 model (I got mine in October 2003). Did they call it a 2003 model in Europe?
Old Feb 3, 2007 | 12:37 PM
Mazmart's Avatar
What did you do when the car flooded. How did you de-flood it or did you take it to the dealer?
Paul.
Old Apr 20, 2007 | 03:29 PM
JDM-8
it was problem with the battery, and my mechanic brought me a new battery, took of the sparks, the electricity, and i crank it until the gas got out of the engine. we cleaned the plugs, we put them on, crank it 2-3 times.. and started again
Old Apr 22, 2007 | 08:05 AM
rx8frank's Avatar
White RX8 R3
I have the same problem since it has been reflashed last year. I changed the plugs and I have the same thing. Now I working on changing the starter...the problem with the starter is it turn the engine too slowly; on the new starter the label should indicate N3H1 A.
Old Apr 23, 2007 | 05:43 PM
Nubo's Avatar
Lubricious
If you get a flood and do a lot of cranking trying to get it started, that is murder on most car batteries, which do not like sustained high current or deep discharge. It is not surprising that the battery could be significantly weaker after such an incident.
I recommend an AGM-type deep-cycle battery for RX-8 (or any modern car for that matter, as most cars noawadays draw current 24x7).
Old Apr 23, 2007 | 06:11 PM
missinmahseven's Avatar
Glitchy Rotary Madness
Just as a datapoint, my '05 shinka has *always* taken at least 3, but not more than six rotor sides to fire up. So anywhere from 3 to 6 "ruhs".
Never flooded. Took 3-6 from day one. Six is after heat soaking for a couple of hours after driving in hot (90*F and beyond) humid days.
*shrug*
Old Apr 23, 2007 | 06:49 PM
_Logan_'s Avatar
I thought on the newer flashes fuel only gets injected after the third crank?
Old May 20, 2007 | 08:36 AM
JDM-8
i didnt know that.
Mine, is 2003 version, i replaced the stock 75d23l battery with 80ah much bigger battery and it takes from 0.5 seconds almost crank to 2-3 maximum cranks.
Once it took more than it and i left it 8 secs cranking. It didnt work. On the second try it went on from 0 second as usually.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Pelleilee
Sep 29, 2019 10:07 AM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
poppinparker
Aug 10, 2015 09:20 AM
Kim Jong Illest
Aug 6, 2015 02:34 PM
