Post Lowering Alignment Help
Old Jan 26, 2007 | 04:38 PM
eastsurf84's Avatar
Unhappy Post Lowering Alignment Help
I recently lowered my 8 with the espelir springs from Auto RnD (Thanks). Anywhoo, its been about 500 miles since the install and I went to a local chain tire store here in Phoenix. They are telling me the only thing adjustable for an alignment is my toe adjustments. However, I hear you other 8 owners talking about fully customizing all your adjustments. Is this store just whack? Also could someone please explain toe, camber and the other adjustments, and maybe the stock settings? I really didnt want to go to my Mazda dealership, because I am worried about the warranty. Should I be? Any suggestions on where to go here in Phoenix?
Old Jan 26, 2007 | 07:35 PM
They are whack Camber, caster and toe are all adjustable
Old Jan 26, 2007 | 07:42 PM
Winning 8's Avatar
Hot Pit
not many people know how to adjust the caster and camber, or too lazy.
Old Jan 26, 2007 | 07:54 PM
NgoRX8's Avatar
if they do not know, take it else where
Old Jan 26, 2007 | 08:18 PM
^^ for sure. It is an easy car to align..........
Old Jan 26, 2007 | 11:27 PM
eastsurf84's Avatar
thanks for the help. I am going to try this place called auto crafters in Tempe, AZ on the word of my buddy who used to bring his turbo/nitrous passat, and g35 to. Apparently they have rotary experience too. Ill have to see. For now...Im gonna take out the sv 650
Old Jan 28, 2007 | 10:39 AM
valpac's Avatar
Ahead of its time
Yes and no. You CAN lower a car so much that you can run out of stock adjustment. My RB springs have taken a set (rear) and my camber adjustment is at the limit. It will require after market adjustable links to return my adjustability.
http://www.tirerack.com/suspension/t...urrentpage=115
Solidtrance
22
Sep 4, 2015 12:47 PM
