painting the calipers
Old Dec 25, 2006 | 11:18 PM
jrtucker's Avatar
for some reason my calipers are lime green and i'm about to paint all four red. Anything i need to know about disconnected the caliper and piston?
Old Dec 25, 2006 | 11:29 PM
Don't get brake fluid on the paint
Old Dec 25, 2006 | 11:43 PM
Wilson's Avatar
Peeping over the fence
You will have to bleed the brake lines afterward. You probably know that though. Some may not.
+1 on the brake fluid on the paint. It is bad news.
Old Jan 6, 2007 | 02:50 AM
Tanaka826's Avatar
just painted my friends caliper. make sure you clean the caliper thoroughly with brake cleaner. and paint it so that it doesnt touch the disc or pads. good luck
Old Jan 6, 2007 | 09:39 AM
Thack's Avatar
You probably dont have to disconnect anything but the wheel. Left mine in tact and used a small brush and testors model paint. Dried fast and dont have to worry about parts sticking together when i have to change the brakes.
Old Jan 22, 2007 | 05:10 PM
chickenwafer's Avatar
Nope
you only have to pull the wheel and paint the caliper with a brush. Brake fluid is nasty- don't get it on you or any paint.
Old Jan 22, 2007 | 05:14 PM
buy the caliper kit at pep boys..i painted mine black and it came out well..mild gloss finish..
Old Jan 22, 2007 | 05:23 PM
You dont' need to remove the calipers!
-Get some wire coat hangers, loosen the calipers and then 'hang' the calipers from your springs. (they are quite heavy, not fun to hold them while you paint)
-Once you paint the front of it, go onto the next caliper. By the time you go around your car, the first caliper will be ready to flip around and paint the back. I know no one will see the back, but you get the idea
-If you buy the Pep Boys brake caliper Kit, buy better brushes...trust me on this, those brushes won't last through the whole process.
-Have fun, good luck.
Old Jan 22, 2007 | 05:43 PM
i never even took off the whole caliper..had it up on all four jacks and went at it...wow sounds like a sex scene for a porno..
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
GK1707
Sep 27, 2015 07:33 PM
TheRedRotor
Sep 22, 2015 05:30 AM
