Any idea to turn off lights automatically?
Old Dec 19, 2006 | 09:35 AM
Yusik's Avatar
My Mits. Eclipse has an useful option,- when I turned off engine and opened the door, the lights came to off too, and on when I push the key to ignition. Very useful option I used to. Any experiences to make it for our RXs?
Old Dec 26, 2006 | 08:50 PM
unreal89's Avatar
I don't mind pistons
Bump :-D
Old Dec 26, 2006 | 08:56 PM
Wire a relay into the ignition wire that only allows the lights to be on when the ignition is on.
Then when you shut off the ignition..the lights go off. And when you starrt the vehicle...with the light switch on....it will turn them back on.
Some market cars IE: Canada..have daytime running light modules that turn on the lights when the car is started......this is kinda like that...in reverse :
I'm sure you could wire the module that controls the lights in your Mitsu into the RX-8 as well. I guess Mazda didn't think that it was an important option?
Old Dec 27, 2006 | 08:54 PM
vrpirata's Avatar
I had that feature in my Mazda Tribute.... It is actually simple and should be in the RX-8.
About a year ago I did a DIY for Powered sunroof. It was to keep the sunroof powered for a couple of seconds after the key was removed. The same principle should be easily implemented for the lights. I might try to do it in the future.
Old Jan 5, 2007 | 11:38 PM
Student Driver
I wonder if this DIY could be modified to control the headlights too.
Perhaps Omicron or Magnesium will chime in... Lurch519 might know how
to do this?
I'll shoot them a PM.
Old Jan 6, 2007 | 12:04 AM
Cody Red's Avatar
always filling [the c]up
I'm just glad it makes that noise so you don't forget like an idiot. hah.
I kinda miss that feature in my '01 eclipse. oh, 8's better.
-Cody
Old Jan 7, 2007 | 01:15 PM
Student Driver
Direct from an expert "Lurch519"
Here's a copy of the PM Lurch sent me:
ok, its very easy.
remove the under dash trim
remove metal under dash piece
remove shroud around steering column (3 screws from underneath)
plug on the ignition switch, locate this, find black/yellow wire and tap into this
find white plug, closest to steering wheel, on the left, locate the yellow/red wire, there are 2, it should be the one on the left of the plug, it will go to ground when the head lights are turned on. tap into this one
locate the light green wire in this same plug, this is parking lights
get a directed 8616 relay from your local specialty retailer, should be 5 bucks, and 2 1 amp diodes
on your 8616 relay, connect the yellow and black wire together and attach to ground
cut the orange wire
take the red wire and connect it to the black/yellow ignition wire
take the brown wire, attach both diodes to this, with the stripes toward the wire. the opposite ends of the diodes will go to your headlight wire and parking light wire. test before crimping this as i just did this, but i am typing this from memory. if it doest work, try reversing the polarity on the diodes
this should be it, test by turning key on, if headlights and parking lights go on we are good.
Old Jan 8, 2007 | 07:35 PM
Omicron's Avatar
Very cool. I might have tackled this at the underhood fuse box level, but this way should work too. Now all this needs is someone to take it on. I have no time and its way too cold right now in Colorado to tackle this.
Al, you're motivated, care to tackle the "Lurch method" you just outlined, and assuming it works, make it into a formal DIY? C'mon man, get your name in lights!
I'll leave this thread in place till we see one way or another, altho since its not yet a tested DIY I'll put a pointer in the DIY forum and move the thread to the exterior forum.
Old Jan 8, 2007 | 11:27 PM
Student Driver
Thanks... but, no thanks. I'll leave this DIY up to the pro, Lurch519.
I am just passing on the info. I probably would have shot for the Fuse panel in the
engine compartment too.
Originally Posted by Omicron
Very cool. I might have tackled this at the under hood fuse box level, but this way should work too. Now all this needs is someone to take it on. I have no time and its way too cold right now in Colorado to tackle this.
Old Jan 19, 2007 | 11:40 AM
Yusik's Avatar
Lets anybody see schemes how to rewire all this stuff. Picture, diagram or layout. Underhood fuse box level is preferrable than removing under dash trims.
Old Jan 19, 2007 | 12:09 PM
Slick8's Avatar
Here's a start! Ford has an auto headlamp kit with sensor and delay.
http://www.mysporttrac.com/mysporttr...all/index.html
$77.31 at Ford Parts Direct, Part Number: F8AZ-13B218-AA
http://www.ford-parts-direct.com/pro...roductTypeID=4
Old Jan 21, 2007 | 10:18 PM
RotaryP7's Avatar
Seriously.. FML..
-Cody
Heh, happens to me all the time. I always thank the little beep it makes..
Old Jan 22, 2007 | 03:30 PM
msenzo's Avatar
RX(4+4)
I had a Peugeot with auto lights and auto wipers. Now, I forget to turn on the lights (Is it my eyes or is it dark out there?), then...behold the beep. The wipers, keep running long after the rain has stopped.
Old Jan 23, 2007 | 04:38 AM
Yusik's Avatar
This way is not suitable, sometimes I left the car in dark on the road and I should left parking lights on for not to have something to crash into me. There must be something intelligent as I have on Eclipse: I turn off engine and open the door, then lights off, but if I turn light switch off/on again manually, they stay on. This is preferrable way. There must be relay which works that way. We should ask Canadian forum? Are there any clever super-puper moderators?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
rx8wankelrotary
Aug 17, 2015 10:42 AM
MarkX
Jul 31, 2015 07:50 AM
digitalmonkey79
Jul 29, 2015 12:09 AM
