Lost power in 1st gear.
Old Nov 10, 2006 | 12:08 PM
devildog1679's Avatar
Question Lost power in 1st gear.
I got my recall and winter tires at the same time. For some reason the car seams sluggish in first now Not sure if its me, tires, or the recall. Anyone experience this?
Old Nov 10, 2006 | 06:25 PM
corners's Avatar
An RX ate my baby
Did you check to make sure you aren't engaging traction control? Winter tires suck in the grip department.
Old Nov 10, 2006 | 08:50 PM
Grip isn't the issue, the car does not rev as quik and seems slow in first. Some peoiple on another forum said its because the copmputer needs to relearn how I drive. It may take a while for all the calibrqtions to be done by the computer. I know jackshit about cars so I'm not sure what all that meant.
Old Nov 10, 2006 | 10:10 PM
mmats69's Avatar
93.5 octane
do a pcm reset and see how that works.
with the ignition off, hold the trip reset for 5 seconds then turn it to the on postition while still holding the button. after a few more seconds it will say "test". turn key back to off.
then go back to the on position and press the brake pedal 20 times. the oil guage will sweep to max and back if you did it right. turn key back to off, then start car and drive normal.
Old Nov 10, 2006 | 10:12 PM
mysql101's Avatar
burned leading coil(s)?
Old Nov 10, 2006 | 11:48 PM
I got it thanks. Should I drive the care easy or hard while the ecu is doing its stuff?
Old Nov 10, 2006 | 11:49 PM
Not sure what they are or how I would burn them.
Old Nov 13, 2006 | 07:29 AM
NEWireless's Avatar
My 2004 w/50k mi also feels significantly more sluggish off the line after the recall work. Additionally, starting is significantly harder than before.
I complained immediately to the dealer (128 Mazda) and they said "everything was within spec".
It's been 2 months and things haven't gotten better (or worse).
Old Nov 13, 2006 | 07:40 AM
tiltmode43's Avatar
OMGITM!
Lower rpms seem to be lacking some power after the recall. Contrastingly, however, my mid-upper range has felt a definite increase in power (I'm actually pinned into the back of my seat without dropping the clutch!) This may be due to either the reflash, changing all fluids, or the combination of the 2.
Old Nov 13, 2006 | 07:46 AM
I'm getting the MS flywheel, intake, and exhaust put in this week by the dealer. I will mention to them the issues I'm having. Hopefully it can be fixed
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
GARCIAC951
Sep 10, 2015 07:17 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
