Vacuum Leak
Old Nov 1, 2006 | 06:21 PM
davefzr's Avatar
Vacuum Leak
I am experiencing a vacuum leak from my engine and think my problem might be related to the Int-x uninstall. During the installation process for the Int-x, there is a step to hook up the supplied hose to the nipple on the manifold (underneath portion, right hand side above oil dip stick) to assist with measuring manifold vacuum pressure. When I uninstalled the Int-x, I didnt plug this hole and think that my issues are because of this.
Does anyone know if this hole should be plugged? Mine currently is not and at idle I can feel the vacuum coming from this area if I place my finger on it.
Thankx for the comments everyone!
Old Nov 1, 2006 | 07:27 PM
StealthTL's Avatar
Metatron
Exclamation Absolutely.....
MUST be plugged.
That large of a vacuum leak will affect both the fuel trim settings, cause rough idle, and suck in debris!
Why would you leave it open?
Cap it, if you don't have a cap, use an inch of tubing with a stubby screw in the other end. Then reset the computer to get rid of the f@ked up settings.
S
Old Nov 1, 2006 | 08:01 PM
MazdaManiac's Avatar
Why not hook up the vacuum line that is supposed to be there from the VFAD?
Old Nov 1, 2006 | 08:19 PM
davefzr's Avatar
RB products are installed on my car..
Thankx for the input guys.. I'll plug the hole.. (Novice)..... Obviously
I had the Int-X installed on my car and could not remember whether or not this needed to be plugged.. I have been running with it like that actually for the past month and have only been experiencing issues just recently.
I did happen to look at my LTFT value and it said 20%.. I knew there was something wrong at that point on a N/A car...
Should have known better but I just did not know.
Thankx again..
David.
Old Nov 1, 2006 | 08:30 PM
mysql101's Avatar
the rb intake should have come with a red vacuum nipple plug.
Old Nov 1, 2006 | 10:26 PM
davefzr's Avatar
Ohhhh yes........ Now I remember.................................. Thankx for jogging my memory.
Old Nov 2, 2006 | 08:35 PM
Umm....... red nipples!
poacherinthezoo
Aug 3, 2016 11:01 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Evan Gray
Nov 24, 2015 01:00 AM
DG07
Sep 28, 2015 10:58 AM
iwannarun
Sep 6, 2015 01:37 PM
