review: Braille Auto all-season battery
Old Oct 20, 2006 | 04:41 PM
d j's Avatar
d j
hukbong himpapawid
I installed the Braille Auto Devepolment B2015 all-season lightweight battery and the power protector that came in for free when I bought it. the power protector monitors battery voltage and usage with the vehicle running and when it is turned off. If it senses that the usage of the battery when the vehicle is turned off will exceed the amount of power needed to start the vehicle, it will disconnect the battery and protect it from being drained. it came 2 remote actuators to reconnect the battery in the event that it decided to disconnect the battery due to possible battery drain. also a set of wires and a fuse were included to bypass the power protector so you're alarm stays on even after it disconnected the battery.
Volts: 12 AH: 21
Pulse Cranking Amps: Over 1060!
Exterior Size L:6.8" W:3.8"H:6.1"
Weight: 15 lb
before...
after...
...so far it's holding up pretty good, I parked it outside las night and tried to start it this morning and it cranked right up.
I'm driving to Seattle, WA sometime next month. I'll find out how it really is an all-season battery.
Old Oct 20, 2006 | 05:53 PM
LionZoo's Avatar
road warrior
Nice to see the battery in there. I'm wondering, will it move around in the housing under strong g forces?
Also, how much was it?
Old Oct 20, 2006 | 06:04 PM
anyone know the weight of the stock battery?
Old Oct 20, 2006 | 06:17 PM
d j's Avatar
d j
hukbong himpapawid
I used the same hold down on my genesis light weight battery that's on my AE86 and I use for driftdays and SCCA solo 1.
...I paid $169.65 for the battery, the free power protector and shipping
deedub, the stock battery on my car was 36 lbs
Old Oct 20, 2006 | 06:24 PM
you definitely need the power drain protector in the RX-8, mine goes dead in a week or so if I don't pull the ground cable off, it often sits several weeks and has racing accessory drive pulleys that don't put out much alternator juice below 5000 rpm
Old Oct 20, 2006 | 07:31 PM
d j's Avatar
d j
hukbong himpapawid
do you have the same battery?
Old Oct 21, 2006 | 10:00 AM
dgrx8's Avatar
FN GR8
very nice!
is the power drain protector only free at this time?
or is it always thrown in the package for free?
Old Oct 21, 2006 | 11:20 AM
d j's Avatar
d j
hukbong himpapawid
Originally Posted by dgrx8
very nice!
the power protector was free for the month of september, I don't think they offer it anymore. I would check back evey once in a while 'tho...
btw, how far are you from Hurlburt Field?
Old Oct 21, 2006 | 11:35 AM
Tamas's Avatar
Registered Lunatic
Mine was sitting for three weeks this June and started immediately after that - in fact, there was no difference between before and after my vacation. So I'd say, this problem is definitely not a generic RX-8 one.
I had the car sitting for two-three weeks a few times before - never a single starting issue, and I didn't even have the new starter back then.
Old Oct 21, 2006 | 04:55 PM
dgrx8's Avatar
FN GR8
thanks for the info!
never heard of the place... i'm in miami.
why do u ask?
Old Oct 21, 2006 | 06:09 PM
d j's Avatar
d j
hukbong himpapawid
why do u ask?
nm, I was gonna ask you how far is it from Sarasota. 'cause that's where Braille Auto Development is located. I might try and get another battery and a charger when I fly over to Eglin Air Force Base next month but I found out that is almost 350 miles away
Old Oct 22, 2006 | 12:36 AM
Nubo's Avatar
Lubricious
Damn, that's tiny! AGM batteries are amazing. With only 21AH capacity though, auto cutoff is definitely a good idea.
Old Oct 22, 2006 | 06:39 PM
CCA 360 ....
With NYC's cold weather .... I cannot live with this battery.
Old Oct 22, 2006 | 07:12 PM
d j's Avatar
d j
hukbong himpapawid
Originally Posted by nycgps
CCA 360 ....
lol why do you wanna live with a battery?
that's for the 11.5 lb battery, this one has 425 CCA's. still not a lot but works for me being in CA
...I had the smaller battery on my FC when I was in WA and seemed to work fine during the winter.
Old Oct 22, 2006 | 11:35 PM
ddub's Avatar
always preoccupied.
I believe he does, yes.
https://www.rx8club.com/showpost.php...6&postcount=25
Old Nov 12, 2006 | 09:16 PM
BigOLundh's Avatar
#1 Legend
Hey... your mounting kit looks way better than the one braille sent me. I was wondering why mine was looking all wrong.
http://www.forumshawaii.net/vbb/show...&postcount=154
I'll call them on monday to see whats up. They had excellent service when i ordered it, so i'm sure they'll take care of this.
-hS
Old Nov 12, 2006 | 09:36 PM
d j's Avatar
d j
hukbong himpapawid
-hS
...I didn't order the braille mount, I just bought an adjustable battery hold down from Schuck's/Kragen.
Old Nov 13, 2006 | 02:31 AM
BigOLundh's Avatar
#1 Legend
link me!!!
is that a local shop or did you get it online? It looks like exactly what i need. Do you have the same braille battery as me, the 11 pound one?
-hS
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
bosstin87
Oct 5, 2015 06:52 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
