MT 5mph cruise control
Old Oct 16, 2006 | 03:43 AM
tjbourgoyne's Avatar
tjb
In slow moving traffic you can cruise at 5 mph. I let off the gas and clutch to see how close it would come to stalling but it never did and ran normal. I'm not sure if all MT cars can do this but my Protege could as well.
Old Oct 16, 2006 | 08:10 AM
silverwolf's Avatar
i dont know ho it didnt. think about when you have to do the first gear clutch work.
you let off the clutch and press the gas. if you dont, then the car shuts off. so i cant imagin a mt having both gas and clutch with no pressure and it still work at 5 mph.
Old Oct 16, 2006 | 09:07 AM
tjb
It works. Put it in first, slow down to 5mph, let off the clutch and gas and it will cruise at 5mph. I will test it again today, but I went pretty far the first time doing it.
Old Oct 16, 2006 | 09:14 AM
TomAssBender's Avatar
Skeet skeet skeet
i cant slow down to 5 mph in first. the car bucks
Old Oct 16, 2006 | 09:38 AM
gummyAvenger's Avatar
Mine cruises at 5 mph without bucking... just have to be gentle when you let off the clutch and gas. I do that when I'm stuck in Friday afternoon traffic. Also works in 2nd gear at around 13 mph if you're gentle.
Old Oct 16, 2006 | 10:34 AM
mikeschaefer's Avatar
I wanna rock! Rock!
it works, i do it all the time in traffic... that way i'm not constantly engaging/disengaging the clutch
Old Oct 16, 2006 | 10:57 AM
Asmoran's Avatar
It's easier to try it the other way around. On a flat, level surface (or even a slight downhill grade) slowly let out the clutch without giving it any gas. Very slowly.
Old Oct 16, 2006 | 12:59 PM
jzief128's Avatar
What are the Detes?
Just for a reference, I was doing this exact same thing yesterday (clutch engaged, no additional gas) in second gear, and I cruised at just about 8 mph.
Jon
Old Oct 16, 2006 | 01:21 PM
no dice's Avatar
I bomb atomically
I do the same in second. it works awesome since cruise doesnt start til 16.5 mph..
Old Oct 16, 2006 | 01:24 PM
tjb
jz i'll have to try it in 2nd. I think a lot of people don't know this. good info.
Old Oct 16, 2006 | 03:47 PM
I can launch mine off the idle (no gas pedal) and it will just glide along from there on the idle setting
I just taught my GF's 15 yr old daughter to launch a manual this way using an RX-8. Makes it much easier for her to get the clutch feel first before also learning how to manipulate the gas simultaneously. She ran her first autox, which was also her first real driving experience, the following day. She still stalled it a few times but she picked it up fast overall.
Old Oct 16, 2006 | 04:40 PM
Skeet skeet skeet
yeah, thats the first thing i did to teach myself on a MT, go to a parking lot and get the car moving without touching the gas. i'll try cruising at 5 on my way home and see what happens
Old Oct 16, 2006 | 04:43 PM
no dice's Avatar
I bomb atomically
Thats how i learned to ride on my buddies R6, and thats how i teach people to drive manuals too. It seems to be the best way to let them feel how a clutch works,
Old Oct 17, 2006 | 05:24 PM
Cam's Avatar
Cam
this space for rent
This works. Ive used it for stop and go traffic for a while. Ive tried it in 1st, 2nd and 3rd gear.
Old Oct 17, 2006 | 07:07 PM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
I found that its harder when your revs are going down, then my car bucks. Note that if I where going up to the same number of revs or keeping it steady then it would NOT buck.
Old Oct 17, 2006 | 07:12 PM
RX8rider's Avatar
Wow! I tried it out tonight and it worked. 5mph crawl in 1st and 7 in 2nd. I was always worried that the car would buck and then die so I never went that low without clutch at least partially in. Good find
Old Oct 17, 2006 | 11:19 PM
RX8rider's Avatar
Just did 11 in third..it's pretty cool!
Old Oct 17, 2006 | 11:25 PM
tiltmode43's Avatar
OMGITM!
Isn't it quite hard on the clutch to hold it in the position where you slightly move forward (half engaged)? I suppose for learning purposes only but it shpouldn't ever be used to not roll back on a hill/inch forward/etc. This is what I was taught at least...
Old Oct 18, 2006 | 03:15 PM
Cam's Avatar
Cam
this space for rent
Let the clutch out, the car wont die. It will buck (mine does) when slowing down at first, but once you reach the 5mph it will idle fine.
pjwermuth
Sep 28, 2015 11:36 PM
Wurromurro
Sep 20, 2015 05:02 PM
titaneum_grey
Sep 6, 2015 10:21 PM
stickmantijuana
Sep 4, 2015 10:31 PM
