Is shock/springs install diy?
Old Oct 8, 2006 | 05:11 PM
hitman408's Avatar
I never did any kind of install before ,one of my friends said he will help with it. He says he has the tools to do it he's good with cars, but he has never done it before. Is this a install easy for novice to do or you guys recommend taking it to a pro?
Old Oct 8, 2006 | 05:26 PM
dtorre's Avatar
Ultimate ****** Goderator
umm front will be easy...but the rear will be a pain in the ***......but you can definately do it yourself if you have the tools....just make sure not to reverse the shocks and springs ...and unloading
Old Oct 8, 2006 | 05:28 PM
NgoRX8's Avatar
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-lowering-springs-install-23403/
very good diy.
i ended up following this and doing it myself. took a long time, but great experience.
Old Oct 8, 2006 | 05:37 PM
guy321's Avatar
Humpin legs and takin nam
Be careful not to shoot the spring at yourself :-o
Old Oct 8, 2006 | 05:59 PM
It's do-able. Remember to get the correct torque values and torque everything to specs. It makes a big difference with suspension components.
The rears are a PIA...but remember that you don't need to remove anything with alignment adjustments on it.........
You will need an alignment never the less...as changing the ride height will change the alignment
Good Luck
Old Oct 8, 2006 | 09:09 PM
olddragger's Avatar
be sure to have some power tools for those !@(&^%$#^& spring compressors.
OD
Old Oct 8, 2006 | 10:34 PM
hitman408's Avatar
It seems like we can do it I will show my friend the diy to see what he thinks. I also wanted get your guys opinions what shock /springs to get. This is will before the street, I was thinking of getting the mazdaspeed. It has nice drop and they stiff so I don't have get sways (unless my thinking is wrong here).
Old Oct 8, 2006 | 10:38 PM
tedious,
i did i by myself.... took a long time. but i was not in a hurry.... next time very easy....
i found the rears quicker than the fronts... and just drop the sways mounts... everything drops down fine..
JimmyBlack
273
Feb 10, 2020 10:23 PM
mitchrx8
Sep 13, 2015 08:05 AM
yankeepicker
Sep 11, 2015 05:42 PM
