Oil Changes
Old May 6, 2006 | 10:10 AM
pcolonna's Avatar
Oil Changes
I'm a new owner of an 04 6spd. Reading the manual it states that a special tool is needed to remove the oil filter. What's the deal on this?
Old May 6, 2006 | 10:34 AM
trustbuddy's Avatar
a oil filter "F" wrench that they sell at the local autozone or pepboys.
Old May 6, 2006 | 03:11 PM
Go48's Avatar
Recommend you get the one from a Mazda parts dept since there has been at least one report of an aftermarket "F" tool not fitting.
BTW, all oil filters require a tool for removal. There are other generic oil filter removal tools that will remove the RX-8 oil filter, but the "F" size is designed to snugly fit the top of the filter. Some of the generic tools are not very easy to use in a cramped environment.
Old May 7, 2006 | 01:29 AM
Nubo's Avatar
Lubricious
http://www.finishlineperformance.com...n&key=RX8M1002
Old May 8, 2006 | 03:15 PM
pcolonna's Avatar
Thanks to all who replied.
Old May 11, 2006 | 06:27 PM
jus7o's Avatar
Cool
ey......i dont use the wrench the only time i did was to take off the oil filter that mazda put on - b'itch **** dudes must have used an impact wrench to torque it on. now i just hand tighten it.
Old May 20, 2006 | 02:11 PM
CosmosMpower's Avatar
1935 lbs. FTW!
I just bought an F wrench at autozone and while it fits over the mobil 1 new filter i bought it seems like the stock black filter with white writing on it is larger. What size wrench do you need for the stock filter?
Old May 20, 2006 | 02:18 PM
Go48's Avatar
Apparently all "F" size wrenches are not the same. I recall another post where the person had the same problem. The wrench that the dealer sell for a few dollars fits fine, snuggly but fine. Order one from Rosenthal or Trussville along with a supply of filters.
Old May 20, 2006 | 06:58 PM
1935 lbs. FTW!
I ended up getting a universal one for import cars that is spring loaded. It fits over the top and then when you turn the ratchet it bites down and turns the filter, worked like a charm. Also when I took the filter off not a single drop of oil came out, of course the car had been sitting there for at least an hour from when I first started to get the filter off and when I got back from the store and actually did.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
