For the Electrical Geniuses - Aftermarket Seats and Airbags
Old Oct 31, 2005 | 05:17 PM
ScudRunner's Avatar
On time, on target
I just read with some terror that the passenger airbag in the dashboard is one of those "smart" airbags that only activates when someone is sitting in the passenger seat. This brings up a couple of questions, since I have already bought Sparco front seats and had my rear seats reupholstered to match, and planned to install them very soon. However, I still drive the car regularly with passengers in it, and am not willing to give up the dash airbag in addition to the airbag that was in the stock seat. Now, the questions -
1. Can anyone confirm this for me? I am currently away from home and my shop manual, and will be for a month. It seems strange to me, because most of the cars I've seen with "smart" airbags have a special light to tell you when the passenger airbag is not armed.
2. If it is in fact a "smart" airbag, once I disconnect the stock seat completely, do any of you electrical geniuses think that there would be a way to fool the car into thinking that someone was sitting in the now nonexistent passenger seat and leave the airbag on all the time?
3. I know that once I take the seats out, the airbag light will be on all the time because the seat airbags will be missing. Do you think there would be a way to again fool the car into thinking they were still there and operating normally so that if the airbag light came on I would know there was a problem with the remaining fuctioning airbags? Or, is there a way to pull codes like you can with a CANSCAN for CELs so that I can check often to make sure all is well?
Thanks in advance for any help.
Old Oct 31, 2005 | 06:16 PM
Im_DANomite's Avatar
I love GOOOLD
the only thing i can think of for "fooling" the car into thinking the passenger seat is occupied is by finding out the resistance of the circuit for when the seat is "occupied". it's called a smart airbag system because of the passenger seat occupany detector. (i think this car has one) the same with the side airbag, you have to find the resistance of that circuit and find some sort of resistor to fill in that gap.
hope that made sense...cause i think i confused myself too.
Old Nov 2, 2005 | 01:54 PM
ScudRunner's Avatar
On time, on target
So, I did get Mazda to answer that no, the 04 RX-8 does not have a weight sensor in the passenger seat. So, the airbag is armed all the time. They would not, however, answer the question of whether removing the stock seats would affect the functioning of the remaining airbags in the system (front and curtain). I can't blame them, because they have to take the lawsuit-proof stance of "don't remove the stock seats."
Old Nov 2, 2005 | 04:36 PM
truemagellen's Avatar
Attracts tree branches
Check your email scud
Old Nov 2, 2005 | 04:49 PM
Gomez's Avatar
Shifty Bastard.
Airbag 101:
There are buckle switches, but these are only used to effect during frontal collisions. If a front seatbelt is unbuckled at impact then the threshold for the second stage charge is lowered. The front airbags fire at one of two rates. If the impact is "hard" then two inflators deploy the airbag and it comes out at a greater rate. "Softer" frontal impacts will only fire one inflator. If the belt is unbuckled, then the second inflator will fire at a lesser frontal impact speed (ie, the bag will come out hard during a low speed collision) therefore protecting the idiot who was too stupid to protect himself.
This will happen whether the seat was occupied or not. There is a modifier to what I have stated above, though. The RX-8 also has seat position sensors. If the seat if in a forward position (ie, the driver has short legs and is close to the wheel) then the airbag only fires one inflator.
Gomez.
Old Nov 2, 2005 | 05:07 PM
ScudRunner's Avatar
On time, on target
Gomez,
Thanks. What I can't find written down anywhere is whether or not the front airbags will function at all if the seat track sensors are removed (as I imagine they would be in a seat replacement issue). It would appear that I could wire a resistor into the wiring harness for the side airbag sensors to keep the airbag module from freaking out, but the seat track sensors are now the sticking point.
Old Nov 2, 2005 | 05:42 PM
Gomez's Avatar
Shifty Bastard.
The seat track sensors are a Hall element magnetic sensor. They operate by producing a electrical signal dependant on the amount of magnetic flux coupling that occurs when the seat is either over the metal target, or away from it. The electrical signal is sent to the airbag control module.
Without looking at the seats....I imagine you could hook up this arrangement to your new seats and seat tracks. Even if you tie wrapped the sensor to the underside of your new seat and had no target fitted....your airbags would still fire. They would just fire both inflators...ie, the airbag module is sensing you are not near the forward target, so it fires at the full rate.
Gomez.
Old Nov 2, 2005 | 05:45 PM
Gomez's Avatar
Shifty Bastard.
And since I am imparting this advice to an American, I add my standard disclaimer that you follow this course of action at your own risk.
I accept no responsibility for your dumb ***....
Old Nov 2, 2005 | 07:40 PM
ScudRunner's Avatar
On time, on target
Gomez.
That's what I like to hear. Since I keep both seats all the way back anyhow, I don't need any sissy half inflation going on. Guess I'll have to wait until I get home and take a look at the seats.
Old Nov 14, 2005 | 05:30 PM
ScudRunner's Avatar
On time, on target
If anyone is curious, the resistance range that the airbag control module is looking for from the side airbag module is 1.4-3.2 ohms. I have decided to go with a 1/2W 2.0 Ohm resistor, based on some other research that I have done. I will update whether or not what I do works as soon as I get home from my trip to NM. Also, here's what 350Z guys have available to them, those lucky punks.
Air Bag Connector
Old Nov 14, 2005 | 05:46 PM
PUR NRG's Avatar
At $60 for what is maybe $5 worth of parts and ten minutes assembly time I wouldn't consider that so lucky.
________
Best vaporizer under 300
Old Nov 14, 2005 | 07:05 PM
ScudRunner's Avatar
On time, on target
True, but there is the added benefit of "knowing" it will work, since Nissan made it. I'm still not convinced I'll be able to do this right, or that I have made all the right deductions.
Old Nov 15, 2005 | 12:16 PM
ScudRunner's Avatar
On time, on target
The 1.4-3.2 ohms value came right out of the shop manual list of possible codes associated with the airbag light. I chose 2 ohms because that is the value that the shop manual has you use to do any tests on the airbag itself.
Old Nov 18, 2005 | 01:04 PM
mazdaexe's Avatar
Any updates on fooling the SRS?
Old Nov 18, 2005 | 11:15 PM
ScudRunner's Avatar
On time, on target
Success! Just got done attaching the resistor to the airbag harness, reattached the battery, and turned the key to ON. Airbag light came on, and went out after a few seconds, just like it should. Seems to have worked like a charm.
One note, however. I have a power driver's seat. In order to get the seatbelt connector and seatbelt switch (part of the SRS system) off so that I could put them on the new seat, I pretty much had to take the entire seat apart and pull out the whole wiring harness. That sucked ***, wasn't easy to do, and the seat didn't really go back together that well (the shop manual would lead one to believe the seat just comes apart; I did not find that to be the case at all). I had planned to sell these seats to someone, but without the wiring harness, I imagine a power seat to be fairly worthless unless you just happen to like riding around in the exact positiont the seat was in before I took it out. Oh well. At least the resistor thing worked.
Old Nov 24, 2005 | 07:54 PM
Gomez's Avatar
Shifty Bastard.
Good result...well done.
Old Nov 25, 2005 | 09:53 AM
ScudRunner's Avatar
On time, on target
Thanks for all of your help, Gomez.
Old Nov 25, 2005 | 10:38 PM
Asheboro8's Avatar
How hard is this to do? And do you think someone could make a DIY Thread?
Old Oct 18, 2006 | 03:47 PM
slavearm's Avatar
Boost Junkie
I really wish there was a nice little DIY for this.
Old Oct 26, 2007 | 04:41 PM
06carbon8's Avatar
i see you used 2.0 ohm, i went to radio shack and the salesperson told me you probably meant 2k ohm. is he right, or do you mean 2.0? 2 ohm is a very low resistance, but from what i know there shouldnt be alot of resistance in an airbag circuit.
Old Oct 26, 2007 | 04:55 PM
StealthTL's Avatar
Rule #1 - Don't take advice from Radio Shack geeks.
Rule #3 - Don't take airbag wiring info from strangers on the interweb.
(There is no Rule #2.)
That is all.
S
Old Oct 27, 2007 | 01:40 AM
06carbon8's Avatar
all i'm asking for is what the resistance range for the seat airbag should be. i don't have a digital multimeter only analog.
and what harm is there in asking? the worst-cased scenario if he tells me the wrong resistance for some reason is that the light will stay on. i already have that. so i don't see a problem.
Old Oct 27, 2007 | 08:25 AM
expo1's Avatar
He's as bad as Can
Well the worst-case Scenario is you set off the Air-Bags.
Old Oct 27, 2007 | 09:04 AM
StealthTL's Avatar
My point about RadioShackGeeks is that he had NO IDEA what you needed, but was more than willing to give you advice that was, literally, 1000% wrong.
ScudRunner posted the right range of values (1.4 to 3.2 Ω) and even gave a good average (2.0 Ω) and a wattage/size (1/2 watt).....the RSG's "suggestion" of 2k is a thousand times more resistance. (so he is actually 100,000% wrong, right?)
S
Old Oct 27, 2007 | 12:26 PM
06carbon8's Avatar
oh i misunderstood you. i thought you were telling me not to accept ScudRunner's advice. i'm sorry. I totally agree with not trusting radio shack on anything more complicated than "how much is this cell phone cover?" I worked at one a few years ago and had NO prior electronics experience. i figured they hadn't changed policy hahahah.
