DIY: Gauge on the A pillar
Old May 14, 2005 | 03:22 PM
adrian-1's Avatar
Ex- member.
Decided to install my defi gauge to my A pillar since the velcro on the dash method wasn't stable.
Bought an attachment that Defi sells ($10) that allows the gauge to be installed onto the A pillar.
Installing an A pillar pod is similiar, except you'll have to secure the pod onto the pillar.
Several people were concerened that gauges would interfere with the side airbag when it deploys. It won't since the airbag is at the very top and it's not the inflatable portion just the connection point.
STEPS:
1. Do a test fit of where you want the gauge to be.
2. Peel away the rubber seal along the edge. Pull the pillar out and up.
3. Drill the 2 holes you marked and also another one for the wire to go through.
Attached Thumbnails DIY:  Gauge on the A pillar-img_1968.jpg   DIY:  Gauge on the A pillar-pillar.jpg   DIY:  Gauge on the A pillar-img_1967.jpg   DIY:  Gauge on the A pillar-img_1971.jpg   DIY:  Gauge on the A pillar-img_1974.jpg
Old May 14, 2005 | 03:28 PM
adrian-1's Avatar
Ex- member.
STEPS:
4. Run the wire through the hole
5. Reattach onto the a pillar and make sure it snaps in.
6. Put on gauge and tighten (careful not to drop the screw or bit in the A/C vent)
All done.
Overall impressions, it's much more stable and doesn't shake like it did on the dash. Plus it looks good.
The red led on the side is a warning led whenever the boost goes above my preset limit to warn me. It'll also flash whenever any of the other gauges go past the warning limit (still need to buy and install those.)
Attached Thumbnails DIY:  Gauge on the A pillar-img_1977.jpg   DIY:  Gauge on the A pillar-img_1979.jpg   DIY:  Gauge on the A pillar-img_1982.jpg   DIY:  Gauge on the A pillar-img_1987.jpg   DIY:  Gauge on the A pillar-img_2000.jpg
Old May 14, 2005 | 03:40 PM
adrian-1's Avatar
Ex- member.
Getting about 17-18mpg. Light on at 220 and fill up around 240 (14gal).
Old May 14, 2005 | 03:51 PM
adrian-1's Avatar
Ex- member.
I'm also in the process of getting a 3 gauge pod installed on the dash. I'll update this thread with DIY steps and also instructions on how to hookup the gauges.
It may take some time, since the gauges will not be in for about 1 month.
Also, the pod is for 52mm gauges and will have to sit at a slant, won't fit parrallel.
Attached Thumbnails DIY:  Gauge on the A pillar-img_2044ggg.jpg
Old May 14, 2005 | 11:49 PM
LiL BenNy's Avatar
Bubblicious? DEF.
not bad, very impressive.. i love the 3 gauge pod in that spot... but what other solutions are there if people have the nav... besides a pillar... thats pretty much it?
Old May 28, 2005 | 12:35 AM
LiL BenNy's Avatar
Bubblicious? DEF.
lol i get 16mpg... N/A
Old May 28, 2005 | 11:28 AM
Omicron's Avatar
Which 3 gauge pos are you using, and where did you get it? Thanks...
Old May 28, 2005 | 11:38 AM
army_rx8's Avatar
X-Sapper
i like you guage on your a-pillar more than mine....haha but ouly b/c it's for boost :p
that's the warning light by defi isn't it (their first gen one)?
Old May 28, 2005 | 12:32 PM
adrian-1's Avatar
Ex- member.
All the info on the 3 gauge pod is at this thread. Contact "fd3s777" to purchase.
yes, Defi 1st gen light. The 2nd gen is too big.
Old May 28, 2005 | 12:34 PM
army_rx8's Avatar
X-Sapper
^cool that wha ti though...have never seen a warning light in person so i didn't get one incase it looked stupid..but that looks prety bad a$$...hmm now to deciede to get jsut one and use it as a master warning..or to get 3....oooo decisions decisions.
any thoughts?
Old May 28, 2005 | 12:35 PM
those defi gauges match the stock 8 gauges perfectly! Damn you and your turbo!!
Old May 28, 2005 | 12:39 PM
army_rx8's Avatar
X-Sapper
hehe even with out the gauge i say "damn you with your turbo" b/c i wish i had one...hehehe.
Old Sep 23, 2005 | 09:36 AM
orbist's Avatar
beyond the ultraworld
OK, so I know there have been discussion about the air-bag, and yes its not got the inflation point behind the gauges, but remember there is an explosive charge that forces the cover off upon inflation. The cover will swing towards the front window, and could (depending on how the gauges are postioned) shatter the windscreen.
I guess in the event of a side impact strong enough to set them off, thats the least of your worries. Wouldn't pass the MOT test we have in the UK.
Old Sep 23, 2005 | 10:31 AM
adrian-1's Avatar
Ex- member.
Explosive charge that forces the cover off????
The attachment point is at the VERY top and there's no EXPLOSIVE charge there! Just a screw!
Take a look at the picture of this deployed SIDE AIRBAG and tell me if you see the A-pillar cover? Still on there? YES! (I know it's the psg side but it's the exact same on the drivers side.)
No idea what MOT is, nor do I care.
Attached Thumbnails DIY:  Gauge on the A pillar-100_1631-small-.jpg
Old Oct 1, 2005 | 11:20 AM
JoeMamma's Avatar
Where the air is rare
I like where you put your turbo timer. I may have to plaugerize your idea...;^)
Old Oct 1, 2005 | 12:39 PM
adrian-1's Avatar
Ex- member.
It's actually the Profec B spec II boost controller. Also, I stole the idea from somebody else.
Old Mar 18, 2006 | 11:06 AM
LiL BenNy's Avatar
Bubblicious? DEF.
did that cover over the gauge come with the gauge or did you purchase it seperately?
by anychance does anyone know where i can get a CF a pillar for 3 gauges? ive only seen the ones with 2...
Old Apr 6, 2007 | 04:39 PM
Crazy Rx-8 Driver's Avatar
XYELLR8
anymore information on the 3-guage install??
Old Nov 18, 2008 | 05:55 PM
DoubleGoose's Avatar
FS Section Sniper
yeah any info on where u wired everything? because im doing a similar install, with 3 gauges
Old Nov 19, 2008 | 04:46 PM
That install is clean... I may do that soon...
Old Nov 19, 2008 | 09:36 PM
marcux's Avatar
Yeay Boosted!
I like my pillar install
Old Nov 19, 2008 | 09:45 PM
FS Section Sniper
interesting, where did u wire everything for power, if you dont mind me asking. because i have a similar install
Old Nov 20, 2008 | 01:22 AM
that looks great, and is it a scangauge11?
could you make me one.. i have a set of spare apillars i think i can recover.
send me a pm..
Old Nov 20, 2008 | 05:55 AM
marcux's Avatar
Yeay Boosted!
Sure thing, it's actually pretty easy, I just cut off the last pod of the pillar pod and protected the lcd with some tape over it , then embedded the lcd with plasticweld first. then used some body fillar and sand shaped the pod. after I sprayed the whole thing with texturizer and painted it. let it dry, and removed the tape. came out really good. that's a 20x4 lcd module that I run off my carputer in the dash (that I also fabbed), but I'm sure I can do the same thing with a scanguage
here is some of the original stuff I modded..
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/rx8-project-nothing-like-youve-ever-seen-too-much-spare-time-lol-139984/
Old Nov 20, 2008 | 11:29 AM
FS Section Sniper
anything about where ya wired the apillar stuff?
