RX-8's For Sale/Wanted RX-8 Private Party listings, no Dealer listings
{ FS } 2005 Mazda RX8 6-speed with 20k miles on rebuilt engine
Old 01-17-2020 | 02:10 PM
Ktlatwig's Avatar
VA 2005 Mazda RX8 6-speed with 20k miles on rebuilt engine
Year: 2005
Make: Mazda
Model: RX-8
Price: $7800
Mileage: 117000
Color: Grey
Location (US State/Canada/Int): VA
Engine rebuilt in June 2018 at 97k miles by Kevin at Rotary Resurrection in TN (so you know it was done right). 20k miles on rebuilt engine, 117k miles on car total.
$7,800 OBO
Rebuild info and many other parts replaced at the same time:
  • 2 NEW rotor housings
  • NEW OMP oil injectors/nozzles
  • NEW Exedy clutch disk
  • NEW Koyo clutch release/throwout bearing
  • NEW coolant reservoir (to fix faulty sensor)
  • OEM apex seals
  • OEM corner seals/springs
  • OEM side seals/springs
  • Atkins viton oil o-rings
  • OEM coolant seals
  • Front/rear main seal
  • Atkins thermal pellet
  • OEM main bearings
  • Pressed oil regulator
  • Oil pickup tube o-ring
  • OMP to engine o-ring
Other new/replaced parts and features:
  • NEW catalytic converter - Spring 2017 (resonator delete and gutted)
  • NEW brake rotors - Spring 2017
  • NEW BHR ignition coils and wires - Fall 2017
  • NGK laser iridium spark plugs changed every 10k miles
  • NEW front splash guards - Spring 2017
  • NEW driver door speaker relay - Fall 2017 (comes with extras)
  • NEW high torque starter - Spring 2018
  • NEW Monroe rear struts - Fall 2018
  • NEW O2 sensor (downstream) - Spring 2019
  • NEW thermostat - Spring 2019
  • Replaced amplifier - Fall 2019
  • Oil and filter changed every 3k miles
  • Taillight seals redone to fix common water leak problem
  • Comes with extra engine undertray and car cover
  • Manual transmission
  • Sunroof works
  • Rare stock navigation system
Only a few known cosmetic issues:
  • Driver side visor broken, looking for replacement
  • Latch for front middle console broken, looking for replacement
  • Standard passenger side dash crack
  • Hood paint partially faded
  • CEL is on for gutted cat
Old 02-27-2020 | 08:20 AM
Ktlatwig's Avatar
Sold!
Dynamite_Goat
09-04-2020 01:53 PM
k-Tracker
07-05-2018 12:44 PM
Matt PN
01-10-2012 10:10 PM
RotaryResurrection
70
11-27-2008 12:56 PM
Quick Reply: { FS } 2005 Mazda RX8 6-speed with 20k miles on rebuilt engine
