{ FS } 2005 WB Turbo RX8 GT3071R
2005 WB Turbo RX8 GT3071R - SOLD
Year: 2005
Make: Mazda
Model: RX-8
Price: $0
Mileage: 55100
Color: Winning Blue
Location (US State/Canada/Int): PA
Located in Philadelphia, PA
Price: $11,500 OR BEST OFFER. Cash please as I need to pay for a wedding.
Specs:
2005 WB RX8 Touring
Under 56k miles.
Manual
Title clean and in hand
Exterior / Interior mods:
Mazdaspeed replica front bumper - KBD
Spoiler Mart Spoiler
OEM Side Strakes/rear valences
LED interior
LED tail light bulbs (rotaryfx)
Front/Rear Rotary Accents
Lebren rear Rotary LED
Fender strakes
Pettit Racing Billet Aluminum Radio ****
Raceroots Reinforced Clutch pedal
Engine:
-SOHN Adapater Engine oil bypass - Premix tank.
-Greddy GT3071R Internally gated turbo charger
-Custom GReddy manifold, downpipe, charge piping/MazdaManiac-Garrett
-GReddy Type-RS Blow-off valve
-Custom 28"x10"x3" core air-to-air front-mounted intercooler
-ATP 5-ply blue silicone couplers
-Staged 290/380/730 Denso fuel injectors
-K&N Polished MAF Tube
-Custom CAI with Vibrant 90-degree pipe and K&N filter
-Aem 1 gallon meth injection setup
-SR motorsports Pulleys
-Agency Power Dual res midpipe
-Greddy sp2 catback
-Greddy larger capacity oil pan
-Mazport ignition and wire
-Mazmart upgraded radiator by ron davis
-Greddy oil cap (blue)
-Aluminum radiator shroud (blue)
Suspension:
-Eibach Lowering Springs
-Agency power front and rear sways
-Hawk brake pads
-Slotted rotors
-17" ENKEI RPF1 17x8 +30 with Dunlop Direzza 80% tread w/ RPF1 center caps
-Blue tuner lugs
Electronics:
-Greddy Profec E-01
-Trunk Mounted Sears Die Hard Platinum Battery
-AEM Boost Gauge ( a bit redundant because of the profec)
-Innovative Wideband AFR Guage DB series (RED)
-Center gauge pod with prosport premium gauges all sensors (Water Temp/
Oil Temp/ Oil pressure
-AccessPort Tuner
Car is tuned very conservatively with 11 flat AFRs @ 11psi (Low boost). I'm not sure how much whp that is because the last time I was at Speed1, the dyno broke on my turn. High boost and meth injection tuning hasn't been done yet but from digging up the history of the turbo, they had it at 15psi. You will probably need a bigger fuel pump to accomodate this.
Oil changed every 3000 miles with 5w30 GTX. Premixed through sohn adapter (idemitsu) and 4oz in the gas tank at every fill up.
Oil changed recently (10 miles ago), air filter cleaned, new cabin filter element, belts tightened, rechecked grounds.
Car may need new Eccentric crank shaft sensor. Throws a code if you don't start the car immediately. Otherwise, the code never comes on. I've cleaned the sensor but still the same.
Email me howard.lew@gmail.com if you're interested. Shoot me an offer as I want to get rid of it quick.
Was the GT3071R custom built by MM? Is that from his upgrade kit?
Subbing to the thread, on the off chance that you decide to part anything out.
GLWS and congrats on the future wedding!
akagc
08-11-2015 07:07 PM
