{ FS } My baby...with nearly every upgrade imaginable!
Year: 2006
Make: Mazda
Model: RX-8
Price: $20000
Mileage: 53000
Color: Black
Location (US State/Canada/Int): MD
- OEM Mazdaspeed bodywork - nose, side skirts, and adjustable rear wing, rear under spoiler, and diffuser.
- Mazdaspeed carbon front shock tower bar, aluminum rear tower bar
- Bilstein PSS-9 coilover system
- Enkei RPF-1 wheels (18x8 +35 offset, silver finish)
- Bridgestone RE760 Sport tires … new @ 38k miles
- Set of 4 black painted winter wheels/tires 18x8 mounted with:
- Set of 4 Dunlop SP Winter Sport M3 225/45/18 95v
- Racing Beat dual cat-back stainless exhaust
- XS Catless midpipe [stock catted pipe included for inspection time.]
- Taylor ignition wires
- New spark plugs at 48k
- SR Motorsports underdrive pulleys
- Racing Beat cockpit gauge cluster (water temp, oil pressure, oil temp)
- Stainless steel braided brake lines, ATE Super Blue fluid
- ACT ProLite flywheel
- *NEW* RX-8 R3 “top loader” gearbox @ 43k miles
- New stock clutch, pressure plate, release bearing, pilot bearing when gearbox changed
- *NEW* RX-8 R3 limited slip differential (4.777 gear) @ 46k miles
- my Ram-Air tube mod (post #12 here: http://tinyurl.com/3wqjsr4)
- baffles/walls & nozzle removed from stock air box with K&N Drop-In,
- Radiator Fans on Low mod
- Cobb AP with MM stage3 tune for all current mods
- Avg mileage pic is because of above tune and proper use of Lug&Coast
- Slotted Discs
- Original Earth Electrical Grounding Kit
- Sohn OMP adapter and reservoir filled with Amsoil Saber Pro low-ash two-stroke for the combustion chamber. I've also been religiously pre-mixing with Lucas UCL 5.5oz per full tank.
- 5w-30 synthetic engine oil [since it is no longer being burned in engine]
- Dice iPod integration
- Titanium tweeters in the A-pillars for improved clarity
- Two years remaining before the 8/80k engine replacement factory warranty!
Why in the world would I want to sell this baby? Well, I'd rather not but the family is outgrowing it and I can't justify a third car. That being said, I'm not in a big rush, preferring to have the right buyer who will appreciate all this beauty has to offer at the suggested price.
on
unless you TRULY need the money. Do NOT sell it man. You will regret it and possibly resent your family.
With the tune and the right conditions I can get up to 28 mpg hwy utilizing excellent control of Lug&Coast approach and keeping it at the speed limit. Most of the time with combined mileage and not paying attention to perfect Lug&Coast, I average 20mpg.
on
Thats great MPG but man, where in the hell can you do that in MD/DC area.. you can't hold a constant speed anywhere around here. And those 4.77 gears sure don't help...
GLWS though man...
GLWS though man...
Thanks! Yeah that 28mpg was on a 40 mile drive from Sykesville to S. of Baltimore...lots of downhill for coasting...only way it can be done. With a tube which prevents that stupid fuel-dump for cooling, efficiency increases nicely. My round-trips from home to Fort Meade are 30 miles of half city and half hwy and with good lug&coast practices I get 22. If I'm getting into the go-pedal I'll get 19.
