{ FS } Megan Racing 32-Way Coilover System
Old Aug 13, 2011 | 08:45 PM
Dmac710's Avatar
VA Megan Racing 32-Way Coilover System
Category: Steering & Suspension
Price: $700
Location (US State/Canada/Int): VA
I have for sale the Megan Racing 32-Way Coilover System. I got them for christmas from my gf last year and have put about 8000 miles on them. They are in excellent condition and no blown shocks or anything like that.
Specs:
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in **** at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 12kg Front and 10kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
Reason for sale: I'am going to trade in my car for a hyundai genesis (ik hate me all you want) so i'am parting out my car.
My impression on them: Due to my hectic work schedule, i have not been able to actually use them at my local auto-x events :[ , but they ride really nice on the streets at setting 30. i was not able to use it on the track settings. i have included pics on how they look on my car so the buyer will know how their car will sit.
Price: 700 shipped in U.S. or 650 local pick up. I live right across from the ups store so as soon as the payment clears on paypal they will ship the same day.
Old Aug 14, 2011 | 12:32 PM
Dmac710's Avatar
work bump
Old Aug 14, 2011 | 10:03 PM
hocknscary87's Avatar
how hard are these to install and will my camber be able to go back to normal with an alignment?
Old Aug 14, 2011 | 10:30 PM
RX8inSTL's Avatar
Adam
Not too hard to install as long as you have a jack/stands and basic tools. And depending how low you go you should be able to keep your camber near factory specs.
Old Aug 14, 2011 | 11:26 PM
Dmac710's Avatar
Yes these coils are pretty basic to install with hand tools. I did them on jack stands in my garage without air tools in a few hours. Here are some DIY instructions for you to decide if they will be too difficult for you to do. Since i dropped my car kind of low i had to get an alignment so i dont wear my tires out.
http://www.hi-impact.org/ryang/modif...ock_front.html
http://www.hi-impact.org/ryang/modif...hock_rear.html
Old Aug 15, 2011 | 08:23 PM
i have a lift at work so it wouldnt be too hard, just wasn't sure if they fit as easily as stock. I've never honestly done anything to a car before I got this and I'm not gonna lie even my turboxs exhaust was a bitch, but i think thats because they didn't send me the right bolts for where the donut gasket goes
Old Aug 15, 2011 | 11:03 PM
Dmac710's Avatar
I will say they fit just as easy as the stock shocks, all the mounting holes are the same. And since you have access to a lift, it will make the install even eaiser. The hardest part for me while installing them are working on jack stands and not having enough leverage to break the bolts loose on the stockies.
Old Aug 16, 2011 | 09:42 PM
Dmac710's Avatar
They are packed up nicely and ready to ship when someone ponys up the cash :]
Old Aug 17, 2011 | 06:31 PM
Dmac710's Avatar
bump for some low milage coilovers
Old Aug 18, 2011 | 05:02 PM
Dmac710's Avatar
nobody wants to sit hellaflush?
Old Aug 19, 2011 | 01:41 PM
Dmac710's Avatar
lunch break bump!
Old Aug 20, 2011 | 07:26 AM
i'm interested in buying these, anyway you can hold on til tuesday for me to see how much my synchro replacement is gonna cost me?
Old Aug 20, 2011 | 08:13 AM
Bl1nD_RX's Avatar
Str8 Rippin
your GF is gonna whoop your *** for selling her gift :D on a side note, interesting choice with the STI wheels on an rx8
Old Aug 20, 2011 | 10:11 AM
THEelliot55's Avatar
is 700 the lowest youll go? pm me very intrestd
Old Aug 20, 2011 | 02:45 PM
Dmac710's Avatar
PM me on tuesday and i will let you know, but i think they will still be here
Old Aug 20, 2011 | 02:46 PM
Dmac710's Avatar
Haha shes cool with it, since i'am selling/trading the car in soon. so theres no point in leaving them on when i have the stocks sitting around.
Old Aug 20, 2011 | 02:47 PM
Dmac710's Avatar
pm'ed
Old Aug 20, 2011 | 02:52 PM
FastFreddy61's Avatar
Would you consider shipping them to europe ?
Old Aug 20, 2011 | 05:57 PM
Dmac710's Avatar
I can if you are willing to pay for the shipping.
Old Aug 21, 2011 | 01:20 PM
Hollowman's Avatar
iZ aCTiVe aLWayZZZz
$ 400 ?
Old Aug 21, 2011 | 01:54 PM
Krazed_Rx8's Avatar
^ Hate lowballers.
Old Aug 21, 2011 | 02:47 PM
possiably pending to me tomorrow
Old Aug 21, 2011 | 09:20 PM
Dmac710's Avatar
thanks for all the interest guys, high chance that itll be shipping to THEeliot55 tomorrow
Old Aug 22, 2011 | 09:54 AM
money sent
Old Aug 22, 2011 | 11:01 AM
Dmac710's Avatar
sold, they will be shipped in a few hours and i will pm you the tracking number
Brokegang
Jan 3, 2016 12:45 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
