Series II Technical and Trouble shooting Discuss technical details for the Series II RX-8 and any issues or problems you are facing
Series II TSB's TECHNICAL SERVICE BULLETINS
Old Feb 20, 2011 | 11:11 PM
ASH8's Avatar
Super Moderator
This is the Complete list of ALL Series 2 (including R3) RX-8 TSB's or Technical Service Bulletins for the North American and applicable Euro, ADR (Australia) Markets...
In almost all cases these still apply to other regions and other countries...unless NA Specific.
VIN Numbers for other countries may not correspond to the information in these Bulletins, consult your local Mazda Dealer for Confirmation.
Depending on your RX-8's Production Month/Year many of these changes have already been performed by the Mazda factory during your vehicles production, never assume these details apply to your car.
Have tried to keep in Alphabetical order, however , not always possible.
Where Series 1 (2004-2008MY) and Series 2 (2009-2011MY) Bulletins overlap or are still relevant, those Bulletins have been updated and posted here.
ANY Series 2 (2009-2011MY) TSB's posted here does not mean that they automatically apply to any or all Series 1 Unless the TSB's here says so by Model Year Date (ie 2004-2009MY or Vehicle VIN Number).
There is also a thread for Mazda Official "M'Tips" (Technical How To Tips for Mazda Service Techs), some do not apply to Series 2 RX-8's, some apply to all RX-8's
Mazda RX-8 'M-Tips' - Service Techs - RX8Club.com
From a Warranty point of view this information here is no longer relevant for Series 1's with expired Mazda’s New Vehicle Limited Warranty, (Engine/Drive Train Warranty or Special Service Programs excluded)
WARRANTY PERIODS
North America
3 Year or 36,000 miles.... 'Bumper To Bumper' Warranty
5 Year or 60,000 miles.... Limited Powertrain Warranty
8 Year or 100,000 miles... Rotary Engine CORE Warranty
3 Year or 36,000 miles.... 24/7 Roadside Assistance Program
Australia & New Zealand
3 Year or Unlimited Kilometres*....'Bumper To Bumper' Warranty
6 Year or Unlimited Kilometres .... Sheet Metal-Body Perforation (Rust Through) Warranty
* 100,000 KMS for Commercial Vehicles
United Kingdom
3 Year or 60,000 miles.... 'Bumper to Bumper' Warranty
3 Year or Unlimited Mile....Paint and Surface Corrosion Warranty
12 Year .........................Anti-Perforation (Rust Through) Warranty
ONLY 2 RECALLS FOR THE SERIES II RX-8
Is the PASSENGER SIDE AIR BAG MODULE Originally Made byTakata (Japan).
(Drivers Side AIR BAG Replacement DOES NOT APPLY as all Series IIs have the NC MX-5 design Wheel and AirBag which is NOT made by Takata).
Some Regions like North America are doing the Fuel Pump on the Fuel Tank Recall with NEW Large O- RING Seals and ALL NEW Heat Insulation FOAM strips
which is install externally stuck on the outer top edge of Fuel Tank to prevent Exhaust Heat from damaging the Pump O Rings.
THERE IS ONE SPECIAL SERVICE PROGRAM (SSP) FOR (NORTH AMERICA) L.H.DRIVE
CONCERNING MANUAL CLUTCH PEDAL BRACKET S2's MADE UP TO SEPT 15, 2008 PRODUCTION.
ASH8's Avatar
Super Moderator
TSB's Continue
Old Feb 20, 2011 | 11:12 PM
ASH8's Avatar
Super Moderator
TSB's Continue.
ASH8's Avatar
Super Moderator
TSB's Continue..
Old Feb 20, 2011 | 11:13 PM
ASH8's Avatar
Super Moderator
TSB's Continue...
ASH8's Avatar
Super Moderator
TSB's Continue ....
Old Feb 20, 2011 | 11:14 PM
ASH8's Avatar
Super Moderator
TSB's Continue.....
Old Feb 20, 2011 | 11:15 PM
ASH8's Avatar
Super Moderator
more..
File Type: pdf
File Type: pdf
File Type: pdf
ASH8's Avatar
Super Moderator
Information...
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Feb 20, 2011 | 11:16 PM
ASH8's Avatar
Super Moderator
TIPS FOR BATTERY MAINTENANCE (REVISED)..while not for North American market...you might find some of the information interesting.
Also noted was the Precaution for Mazda's i-Stop System when disconnecting/connecting car battery...a 'main' and 'sub' batteries!
Quote..
Especially for vehicles equipped with i-stop, be sure to check the voltage of both “main” and “sub” batteries. As the sub battery runs the starter, no trouble occurs even if the main battery is low when starting the engine so please be aware of the necessity of main battery inspection.
Old Feb 20, 2011 | 11:48 PM
ASH8's Avatar
Super Moderator
Various
Old Feb 20, 2011 | 11:49 PM
ASH8's Avatar
Super Moderator
More TSB's
PLEASE NOTE This Coolant Warning Light Comes ON - UPDATE.pdf Repair procedure no longer applies as the Coolant Bottles listed in this TSB are NO LONGER AVAILABLE.
ONLY the expensive complete Coolant Bottle with Pressure Cap which fits all RX-8's is now sold, this is the Part Number N3H1-15-350M all you need to do is install it.
Edit: September 30th, 2013.
Old Feb 25, 2011 | 02:24 PM
ASH8's Avatar
Super Moderator
Information TSB's ...
Old Feb 27, 2011 | 07:33 PM
ASH8's Avatar
Super Moderator
Updates...
Auxilliary Port Valves for SERIES II..only 6 port engines use these.
Series 2 RX-8 North America
N3R4-13-B6X AP Valve Front
N3R5-13-B6X AP Valve Rear
Series 2 RX-8 Rest Of World
N3R1-13-B6X AP Valve Front
N3R2-13-B6X AP Valve Rear
Old Feb 27, 2011 | 10:34 PM
ASH8's Avatar
Super Moderator
Updates..
Old Jun 20, 2011 | 03:32 PM
ASH8's Avatar
Super Moderator
new
File Type: pdf
File Type: pdf
Old Aug 17, 2011 | 06:05 AM
ASH8's Avatar
Super Moderator
New ones
Old Sep 12, 2011 | 05:04 AM
ASH8's Avatar
Super Moderator
Gear Noise Changing INTO 5th to 6th.
Gear Noise Changing INTO 5th to 6th....Early Series 2's made before April 21, 2009
PLEASE NOTE: FOR WHATEVER REASON THIS 5th and 6th Gear Noise (Grinding) TSB WAS ONLY RELEASED TO AUSTRALIAN (ADR) AND EUROPE Mazda Dealers.
THE 'Parts INFORMATION' DOES APPLY TO US AND CANADA P66M Series 2 TRANSMISSIONS.
THE SYNCHRONIZER RINGS WERE UPDATED FROM THE EXACT SAME PRODUCTION DATE FOR NORTH AMERICAN S2 RX-8's.
THE 6 Speed TRANSMISSIONS ARE IDENTICAL FOR ALL WORLD MARKETS (Except 3rd and 4th Gear Ratio's for North America).
Old Feb 7, 2012 | 04:19 AM
ASH8's Avatar
Super Moderator
More..
Old Feb 7, 2012 | 04:21 AM
ASH8's Avatar
Super Moderator
And More..
File Type: pdf
File Type: pdf
Old Feb 7, 2012 | 04:26 AM
ASH8's Avatar
Super Moderator
Continued..
Old Feb 7, 2012 | 04:27 AM
ASH8's Avatar
Super Moderator
More...
File Type: pdf
File Type: pdf
Old Feb 7, 2012 | 04:28 AM
ASH8's Avatar
Super Moderator
Corrosion on Sub-Frames and Suspension Parts.
I have included this TSB here concerning a Corrosive or Rust look on black painted steel Sub-Frames and Suspension Parts under your RX-8.
While this TSB is not specifically for the RX-8 the information is the same for them.
So, do not be concerned 'IF' you have this copper/yellow/or bronze corrosion on your Black Metal Sub-Frame welds as it is normal and will not go any further..
SEE TSB.
ASH8's Avatar
Super Moderator
Revised Dashboard "poor" appearace...
PLUS....new one here...
MAZDA GUIDELINES FOR FACTORY SCHEDULED MAINTENANCE.
Old Apr 2, 2013 | 05:32 PM
ASH8's Avatar
Super Moderator
Discussion about these Series II RX-8 TSBs or this thread has been moved.... HERE
rx8ioual
Jul 12, 2016 08:33 AM
xexok
21
Mar 14, 2015 03:15 AM
Meadowlark Lemon
Aug 19, 2013 09:04 PM
Meadowlark Lemon
Jan 27, 2013 12:24 PM
ASH8
Oct 20, 2011 09:36 AM
