{WTB} Rack and Pinion (Electronic)
Old 08-20-2010, 07:03 PM
Red RX8 in Philippines
looking4's Avatar
Category: Steering & Suspension
Hello,
I want to buy a good condition rack and pinion for RX8 2006 model. Shipping to CA.
Thanks.
Old 08-21-2010, 07:09 PM
looking4's Avatar
Old 08-22-2010, 05:16 AM
dlum125's Avatar
hahah i'm looking for one of these too! not trying to thread jack, but if anyone has another one, let me know.
Old 08-22-2010, 05:22 AM
BG-8's Avatar
https://www.rx8club.com/rx-8-parts-sale-wanted-44/rx8-stock-parts-203309/
second item down
Old 08-22-2010, 07:46 AM
Surf Hard, Drive Hard
Mazurfer's Avatar
Why are you guys looking for this? I just want to be sure you really need it and it's not because either:
a.) you drove through high water and messed up the power steering connectors
b.) your coolant overflow hose dripped coolant onto the power steering connectors and messed them all up.
If you've simply lost power steering and aren't EXACTLY sure of the cause, then you better do some searches and make sure it's not just damp/corroded connectors first.
Just trying to save you money.
Old 08-22-2010, 10:53 AM
elysium19's Avatar
Yeah....99% of the time when people think (or are told) they need a new steering rack, they don't.
Search for the threads describing all the problems, and how to fix them. Or don't but it will needlessly cost you lots of $$$
gooooood luck
Old 08-22-2010, 10:54 AM
Mazurfer's Avatar
^................yeah, I just want to make sure it's not some flunky at a dealership telling them the need one before really knowing that for sure.
Old 08-22-2010, 12:23 PM
Madcivic84's Avatar
There is a Mazda TSB out for this problem, the connectors on the fan shroud have problems with continuity and there are 2 ground plates on the beam above the the fan shroud (they are the 2 10mm bolts under the battery box and airbox). Clean these grounds and check that big connector with the red and black wire, make sure they have good contact, before replacing your rack.
Old 08-22-2010, 12:40 PM
Mazurfer's Avatar
No direct TSB that I am aware of........... http://www.finishlineperformance.com....php?pageid=11
BUT.............There are plenty of threads on this with info and pictures to show them.
I just don't want them speding $1600.00 or whatever if they really don't need to do so.
There have been bad racks, but need to be sure first!
Old 08-22-2010, 01:29 PM
rotoryfan1991's Avatar
I got one perfect shape, 30k miles. pm me if anyone needs one.
Old 08-22-2010, 05:54 PM
Mazurfer's Avatar
So this means you can get all the M-Tips available for the 8.....that's good to know!
Old 08-22-2010, 06:08 PM
Madcivic84's Avatar
Yep, there are more M-Tips for the 8 then I can shake a stick at , lol.
Old 08-22-2010, 06:28 PM
Mazurfer's Avatar
Wonder how many actually came as a result of this site or others?
galognu
Rotary Swaps
138
11-16-2020 05:20 AM
02-10-2020 10:23 PM
Prescription 8
Non-Rotary Swaps
117
02-14-2018 12:07 PM
Olorin2
20
03-13-2016 11:01 AM
urbanvoodoo
09-30-2015 12:41 AM
Quick Reply: {WTB} Rack and Pinion (Electronic)
