Used Oil Analysis - Post Them Here
Old 02-26-2010, 11:39 AM
  #251
TX
Originally Posted by dannobre
What is your oil temp running at this time of year? Wondering if is a bit cool in the winter...leading to dilution problems in daily driving??
I had to block off the oil coolers to keep mine warm enough....
I am averaging about 170F on the return line. I did notice on the drive back when my radiator was cracked that my oil temps were about 190 on the return while keeping the coolant temps at the normal 180-190F range. So the oil cooler was working hard to cool the engine since the radiator was leaking. I think I f I was on the stock coolers i would have had to have my car towed to the house.
Old 02-26-2010, 02:00 PM
  #252
Here is ganseg's UOA
Old 02-26-2010, 03:48 PM
  #253
olddragger's Avatar
do yall think those hard working, hard squeezing rotor stationary gears is what is causing a lot of the oil breakdown?
Old 03-01-2010, 08:16 AM
  #254
Nature vs. Nurture
ganseg's Avatar
Originally Posted by 9krpmrx8
We have to get to the bottom of this fuel dilution issue.
My test showed 1.8% dilution after 2,000 miles. A friend said maybe it is cold starts. Its not the idling (alone) because i don't do that much idling. Where is the oil exposed to gas? I know in a piston engine it is the rings that separates them, but in the rotary what does?
Old 03-01-2010, 08:43 AM
  #255
Yeah I did some work to my oil lines this weekend and took some oil from the cooler and although the oil looks pretty clear after 2,000 miles I could smell gas in it .
OD, Ganseg, how many miles (I know OD and I have new motors) do you have on your injectors?
Old 03-01-2010, 11:38 AM
  #256
Nature vs. Nurture
ganseg's Avatar
My car has 40k and I have no record of a prior owner changing injectors.
Old 03-01-2010, 04:24 PM
  #257
Oh, and FYI, for all of those who say Mazda uses Castrol or their own brand. I took this pic in the rear of a Mazda Dealer shop. I went to buy Diff Fluid and when I peaked out back they had this one and another tank that was 10W-30.
Old 03-01-2010, 04:26 PM
  #258
And as I predicted, the 06's are starting to show up so it's BS that it's limited to 04's and 05's.
2006 with like 50k
Old 03-01-2010, 07:53 PM
  #259
olddragger's Avatar
how about that----i am wondering about the s2 model.
has anyone done a uoa with synthetic oil?
OD
Old 03-01-2010, 09:41 PM
  #260
My UOA is with Mobil 1 0W-40. Or do you mean Series II's?
Old 03-16-2010, 08:26 PM
  #261
Not yet famous
BRODA's Avatar
Just saw something interesting on BITOG:
btw-Blackstone's fuel numbers are found from a table based on the flash point. They do not measure the actual fuel content.
http://www.bobistheoilguy.com/forums...63#Post1683193
Old 04-20-2010, 10:23 AM
  #262
Bump.
Old 04-20-2010, 04:45 PM
  #263
PhillipM's Avatar
That's always been my opinion, the local Millers Oil rep. is seeing if it's feasable to produce this in a 5w30/40 weight:
http://www.millersoils.net/M3_cgi/mi...sport&cart_id=
But I haven't heard back yet.
Old 05-27-2010, 08:59 PM
  #264
1% evil, 99% hot gas.
wankelbolt's Avatar
Reports: First is engine, second is trans.
Blackstone continues to BS a bit. That nonsense about apex seals being the source of the higher chromium number is ridiculous. It's coming from the main bearings, like we've all seen here on track-driven RENESIS engine tear-downs. Also I think it's time to go to some thicker gunk. Maybe even that Rotella T, which Wallyworld now stocks in-depth in big jugs.
The transmission report is nice. It reflects the difference I felt when I switched from the stock dyno lube to the Red Line MT-90. Much less metal coming off the parts. Still, the transmission was reluctant to go into fourth on the track when hot. Since I switched the Swepco 201. Weird sticky stuff. Now it bitches about going into 1rst all the time! But it goes into fourth easy hot or cold. Trying to squeak some more life out of a hard-driven transmission...
Attached Thumbnails Used Oil Analysis - Post Them Here-oilreport.jpeg   Used Oil Analysis - Post Them Here-transreport.jpeg
Old 05-27-2010, 09:13 PM
  #265
Nature vs. Nurture
ganseg's Avatar
Did you have makeup oil this time? Had you run heavier oil on any of the past tests?
Old 05-28-2010, 06:49 AM
  #266
wankelbolt's Avatar
No and no.
Old 12-22-2010, 11:55 AM
  #267
Mobil1 0W-40 from another Texas member. Looks Good
http://www.flickr.com/photos/9krpmrx8/5283556134/http://www.flickr.com/photos/9krpmrx8/5283556134/ by http://www.flickr.com/people/9krpmrx8/, on Flickr
Old 12-22-2010, 12:18 PM
  #268
I drive at Red Line.
DocBeech's Avatar
I ordered a test kit, and I will post the results after this oil change.
Old 12-22-2010, 01:21 PM
  #269
Cool, I have some results to post up from a run of Rotella T6 5W-40 and Mobil1 0W-40 as well. I am just awaiting the results from my last mobil1 run so I can post them all at once.
Old 12-22-2010, 04:22 PM
  #270
DocBeech's Avatar
I think we need more information than just the compounds of the oil after the runs. Unfortunately I don't have the equipment. I will have a compression tester in the next 6 months, and I want to see if theres a difference at the rotors too.
Old 12-23-2010, 12:55 PM
  #271
REDRX3RX8's Avatar
Yeah Doc, I usually run a used oil analysis a few times during warranty to see if there's a water leak, and to get a feel for dirt ingestion.
Notice that at 5151 miles, and one years use the silicon (dirt) is 10ppm while the limit is 12, so the air filter is working ok.
If some one wants to track engine longevity, they can put in a vacuum gauge, and watch it go lower as the seals wear over a few years.
My vacuum baseline is 18.5 inches vacuum @ fast idle startup, and 16 inches fully warmed at idle.
That's at 2900ft elevation; it also gets 18 inches fully warmed at 900ft.
Old 12-23-2010, 01:12 PM
  #272
I need to get a vacuum gauge.
Old 12-23-2010, 01:25 PM
  #273
DocBeech's Avatar
You actually put a good number of miles on the oil, and the additives kind of held up. Playing around with different filters I bet you could get those dirt levels down, but it might not just be your filter. They dont seal the the gas station tank covers when they fill the tank, so that fuel gets mixed in with crap off the road. I am sure some of that is coming from the pump.
The vacuum gauge is a good idea, but I would like to be able to test compression as well.
Old 12-23-2010, 01:28 PM
  #274
wankelbolt's Avatar
3 for $10. Good quality American made vacuum gauges. Not really for dash installation, but fine for the garage:
http://www.garagejournal.com/forum/s...ad.php?t=79683
No affiliation with the guy.
Old 12-23-2010, 01:31 PM
  #275
^ On older setups yes, newer setups have plastic tanks and filters before the fuel hits the pumps. That is why I use (and have since the new motor) the new shell station by my house. I talked to a friend of my bosses who owns a construction company and three brand new Exxon Tigermarts..
Quick Reply: Used Oil Analysis - Post Them Here
