{ FS } V-LEDs White/Amber Type 1 & Blinker Fix.
Living is best Modified.
Category: Lights
Price: $40
Location (US State/Canada/Int): SC
I have Front turning signals: White + White/Amber, "Type 2" bulbs. 1157 socket.
Parking: White
Blinker: Amber and White
I also have the two bulb fix resistors that I needed (I bought spares, just in case). Two bulb fix means that one resistor will work for one bulb. You'll need the 30Ohm resistor if you want to have both blinker bulbs in LED.
Both have been opened.
Both have never been used, for the most part, they've never left the packaging. I've bought spares just in case. These are the spares.
The resistors have all (4) splice taps for easy install. I'll add in my spare splice tap as well.
Optional & No additional charge: On request, I can go ahead and add connectors to these resistors. In case you wanted to place back LED blinkers as well. I added connectors to mine, so that I could with relative ease, disconnect everything.
40 Dollars for the bulbs and the resistors.
Links:
Bulbs: http://www.v-leds.com/Exterior-LED/T...68712-1-2.html
Resistors: http://www.v-leds.com/BlinkerWarning...-p4783296.html
Pictures:
nowakm99
10-09-2015 07:10 AM
