VersaTune's Shop Car Tuning Journey
Old Jan 17, 2019 | 09:56 AM
Steve@VersaTune's Avatar
RX8Club.com Sponsor
Note the 3:45AM timestamp on the dyno sheet. We've put several LONG days of dyno time into building this tune.
Old Jan 17, 2019 | 01:21 PM
titaniumgr3y's Avatar
JDM-8
steve, whats the hp and torque gains on this ?
Old Jan 17, 2019 | 01:48 PM
NotAPreppie's Avatar
Bottom of the second dyno sheet...
Old Jan 17, 2019 | 01:57 PM
JDM-8
i think thats 179 from the baseline test which was performed a few days ago. The green line, is more like 188. Nowhere writen. Hence my question.
Old Jan 17, 2019 | 02:27 PM
Original (first dyno sheet, baseline second dyno sheet):
170/120
Post tune-up (run 2 second dyno sheet, baseline third dyno sheet):
179/126
Post tune (run 2 third dyno sheet):
186/132
Steve,
Thanks for posting all of this info.
You only posted a single dyno sheet for each result but did you do multiple dyno runs at each stage to verify repeatability?
Also, still waiting with baited breath for the compression test results.
Old Jan 17, 2019 | 04:04 PM
RX8Club.com Sponsor
Steve,
We did well over a hundred pulls over several days consuming more than 15 gallons of fuel and over a quart of oil. We paid careful attention to ambient temp, intake air temp, and coolant temp so that things are repeatable. Pulls were done at 80C ECT and 20C IAT. When we came to the conclusion that any given tune was done, we did multiple pulls to confirm repeatability. We did about 10 pulls on the final tune that we published to be sure that it was repeatable. This ECU/engine is very sensitive to heat. It dumps fuel when it gets hot. It's important to keep temps under control to see consistent top performance.
Lastly, VersaTuner off-the-shelf tunes are not locked. You can open them in VersaTuner and see exactly what you have. No black boxes or smoke and mirrors. Some of the locked tunes I've opened up over the years are scary. VersaTuner gives you full transparency.
Compression test will probably happen this weekend. We wanted to get the tune published asap so that people have a turn-key solution for a stock car.
Old Jan 17, 2019 | 04:21 PM
Awesome, thanks again for sharing all of your work on this!
I'd tell you this swayed me to buy your product but I already did that in 2017, so... ¯\_(ツ)_/¯
Old Jan 17, 2019 | 05:33 PM
Originally Posted by Steve@VersaTune
I don't log percent of max calc load. It's an arbitrary value.
Max. calc load is actually a ceiling . If your logs are showing 100% max. calc load on anything but a bone stock rx8 then the tune can go lean for any one of several reasons (hot IAT being one of them). I always add a % over stock to that table so it doesn't interfere with tuning .
Old Jan 17, 2019 | 05:35 PM
RX8Club.com Sponsor
Originally Posted by Brettus
Max. calc load is actually a ceiling . If your logs are showing 100% max. calc load on anything but a bone stock rx8 then the tune can go lean . I always add a % over stock to that table so it doesn't interfere with tuning .
I adjust Max Load out of the way. That's why I don't bother logging it.
Old Jan 17, 2019 | 08:44 PM
RX8Club.com Sponsor
To give you an idea how much heat an RX-8 puts out, we used two 22" Patterson high velocity fans on the car and a 48" 18,000 cfm drum fan in the shop door to keep it cool. Each 22" fan puts out 5570 CFM.
With just one 22" fan, the ECT would be 90C or more by the end of the pull. With the second fan, it only went up a few degrees.
For comparison, I run my turbo ND Miata all day on the dyno with just one 22" fan.
Make sure you maintain your cooling system properly!
Old Jan 18, 2019 | 07:59 PM
WayneBrady's Avatar
are you guys going to make a new tune for cars with intake, exhaust? thanks!
Old Jan 18, 2019 | 08:14 PM
RX8Club.com Sponsor
That's the plan. We have a REVi intake ready to go on and a full TurboXS exhaust on order.
Old Jan 18, 2019 | 10:51 PM
WayneBrady's Avatar
right on, ill flash it whenever you upload it. thanks again!
Old Jan 19, 2019 | 10:28 PM
Chrishoky's Avatar
Any plans for including CEL deletions, OMP rates, or fan temp triggers to these tunes or is that something that the end user is going to be expected to manually modify? Also, I see intake and exhaust mentioned but how about CAT delete?
Old Jan 19, 2019 | 10:34 PM
RX8Club.com Sponsor
All of this is easily done by the end user. This tune includes slightly higher OMP rates.
VersaTuner allows full custom tuning, and all of the off-the-shelf tunes are open and unlocked. You can open an OTS tune and modify it to your liking.
Things like launch control, no-lift-shift, and CEL masking are set in Tune Customizer and are applied to all tunes you flash. OMP and fans are set in the main Tune Editor.
Old Jan 22, 2019 | 09:39 PM
605RX8's Avatar
Thanks. I'm trying to make this as repeatable as possible.
I wanted to create a healthy stock baseline to use for comparison. I have a rotary compression tester, but the lift was busy today. I'll do a compression test soon.
The VersaTuner performance tune for a 100% stock car is coming soon!
awesome option for the market
Old Jan 23, 2019 | 10:43 PM
RX8Club.com Sponsor
Compression test results. It seems a bit low for 10k miles.
Not sure how this will affect the results, but I used the leading plug holes not the trailing like the instructions clearly state right on the tester. Didn't notice till I looked at the pics. I referred to the instructions on the Racing Beat website which said to use the leading plug holes.
I'm not really anxious to burn my hands messing with a compression test on a hot engine again
Front Rotor
Rear Rotor
Old Jan 24, 2019 | 12:29 AM
Ricky SE3P's Avatar
Project Seca
If you are unhappy with those numbers, I'm willing to trade with you
Front rotor
Rear rotor
Old Jan 24, 2019 | 12:31 AM
RX8Club.com Sponsor
Ouch. That's an "opportunity" to put in a ported motor.
Old Jan 24, 2019 | 12:43 AM
Ricky SE3P's Avatar
Project Seca
I tried telling that to Bank of America, they told me maybe some other time.
So for the last 8 months shes been a driveway trophy, probably will stay that way into 2020 and hopefully it will be a different story. Staying subbed to this thread and asked the premixed fuel power output question for that reason. Just looking for a baseline, prior to any tuning/factory tune, rwhp numbers. I think it would be interesting to have those numbers of premix and no premix on factory tune, and then compare it to tuned with boltons for premix/nomix respectively to see if it really does have any significant reduction in power output to then also directly compare and weigh out the costs and benefits of premix. Would make for an extremely valuable comparison.
Old Jan 24, 2019 | 10:45 AM
Two words for you:
Mechanics gloves.
I noticed a significant reduction in compression test results with my RCT-V5(.0) when accidentally using the leading plugs switching from trailing to leading plugs. The numbers will probably improve if you perform the test again using the trailing plugs.
Old Jan 27, 2019 | 10:39 PM
RX8Club.com Sponsor
Redid the compression test. Slightly better numbers.
Old Jan 27, 2019 | 10:48 PM
RX8Club.com Sponsor
I put a scope on the coil and logged dwell time.
Idle rpm (~830) @13.90v
2000 rpm @ 13.90v
3000 rpm @ 13.90v
Corrected coil dwell scaling will be in the next release.
Old Jan 28, 2019 | 01:51 PM
  #49
Is this to display human-readable numbers in that table?
Old Jan 28, 2019 | 01:54 PM
RX8Club.com Sponsor
Yes. This is actual dwell time in milliseconds.
