Vendor Classifieds For our approved Vendors to post their for sale threads
TurboXS introduces Garage Line Headers
Old Mar 1, 2012 | 09:14 AM
  #76
TurboXS.com's Avatar
Former Sponsor
Its Leaving today!!! :D Check the UPS Tracking at the end of todays business.
ALL we have 3 left
Old Mar 3, 2012 | 12:12 PM
  #77
Former Sponsor
http://www.facebook.com/pages/TurboX...83125445098859
Old Mar 3, 2012 | 02:03 PM
  #78
Former Sponsor
2 LEFT all.
$250.+shipping. Shipping is not that bad honestly, HIT ME UP and get your all said and done quote for the Garage Line Headers.
Old Mar 4, 2012 | 09:18 PM
  #79
comebackqid's Avatar
getting mine Wednesday can't wait! bought some VHT for it also.
Old Mar 4, 2012 | 09:21 PM
  #80
paimon.soror's Avatar
curious, on your FB you post +15hp ... I am assuming that is with your header + midpipe + exhaust?
Old Mar 4, 2012 | 09:53 PM
  #81
bumblebeerx8's Avatar
Rear Mount GT35R
are the flange ports matched to the motor? what material are these made from 409,304,321?
Old Mar 5, 2012 | 10:42 AM
  #82
Former Sponsor
Correct
Old Mar 5, 2012 | 12:27 PM
  #83
200.mph's Avatar
FULLY SEMI AUTOMATIC
will these blot up to any exhaust? iirc the turbo xs system needed modification to a flange when using a different mid pipe or cat back
Old Mar 5, 2012 | 02:28 PM
  #84
Former Sponsor
Yes it will bolt up to any exhaust.
Old Mar 5, 2012 | 02:29 PM
  #85
Former Sponsor
3 left in house ALL.
PM me!
Old Mar 5, 2012 | 03:27 PM
  #86
Rear Mount GT35R
any anwsers to my questions? post #81
Old Mar 5, 2012 | 03:33 PM
  #87
Former Sponsor
Not individually port matched, they were built off the same jig. And they are stainless steel
Old Mar 5, 2012 | 03:51 PM
  #88
Rear Mount GT35R
what grade stainless steel?
Old Mar 5, 2012 | 08:05 PM
  #89
HiFlite999's Avatar
Let me try to answer, I have the GL header in my basement, not yet installed. First, I've been able to find only one reference as to the size of the exhaust outlet from the "irons", in a ~2007 exchange between RotaryGod and TeamRX8: Ends = 47.6 mm x 27 mm, Center = 47.6 mm x 22 mm.
The stock manifold at the mating surface is Ends = 52.5 mm x 36.5 mm, Center = 52.5 mm x 23.5 mm. The stock manifold then very nicely and smoothly turns the rectangle into a circle with a ID pipe diameter of 43 mm.
Now the GL header flange is a bit more complicated, with the mating surface and the "pipe surface" being different, with a taper milled in between. GL mating surface: ends = 51 mm x 28 mm, Center = 51 mm x 28 mm. On the pipe side: Ends = 40 mm x 37 mm, Center = 39 mm x 25 mm. The pipe ID = 41 mm. The transition from GL flange exit to pipe is very abrupt.
How to make sense of this. If one ignores the rounded corners of the rectangle, one can track the area (in square mm) of the exhaust from exhaust runner to exhaust pipe. (non-mathematical use of < and >)
Stock Ends: 1285 < 1916 > 1452
GL Ends: 1285 < 1938 > 1480 > 1320
Stock Center: 1047 < 1233 < 1452
GL Center: 1047 < 1428 > 975 < 1320
Good, bad, ugly? The CW from the past (RotaryGod) and more recent (Eric Meyer) is that the exhaust system per se is hopelessly dominated by the siamesed center port and the 90 deg bends coming out of all ports. "Tuning" headers don't work as well as it does on other cars. RG argued that the pipes and flange exits should be smaller to keep flow velocity high. Is that "975" neck down a problem? Dunno.
I chose to modify center port somewhat however. I rounded sides of the pipe edge of the center GL header flange to reduce the abrupt change (23.5 to 41 mm) into the pipe. I did a similar thing to "smooth" that transition on the end ports as well. It took about 2 hours for the center port and .5 hr each for the end ports with a Dremel #8193 stone. I didn't change the size on the mating surfaces at all.
Is it the right thing to do? Haven't a clue. Blindly increasing the flange port size however, I think is unwise. I have a stock manifold installed that was enlarged all the way out to the gasket (Ends = 68 x 42 mm, Center = 68 x 38 mm) and am pretty convinced it's the cause of a rather large high-rpm deficit in hp measured on a dyno, as well as very black spark plugs. An uncertainty is the actual exhaust runner size as I was able to find only the one reference and haven't measured it myself.
The pipes are non-magnetic which means stainless. The port flange and triangular mating flange to the midpipe are, however, quite magnetic. Also (as you may be able to see in the pic), after washing the grinding dust out with water, the flange showed light rust. Some stainless will do that, like the kind used in most OEM exhausts.
Is the GL header worth $250? Most likely, if there are no fitment issues. One thing it lets me do that's not easily done with the OEM manifold is to add a bung for an EGT gauge. Racing? Try a TeamRX8 or Eric Meyer style system for $2000. Not in my budget though!
Old Mar 6, 2012 | 02:05 PM
  #90
Former Sponsor
2 Garage Line Headers left in house.
Old Mar 7, 2012 | 12:07 PM
  #91
Former Sponsor
^^ You ALL see that. We have 2 left in house.
Garage Line Header: $250+shipping. Shipping isnt as bad you you all think. PM me for your all said and done quote.
Kind Regards,
Raj Deshmukh
Sales/Photographer
TurboXS.com
Old Mar 7, 2012 | 12:26 PM
  #92
natothegreato's Avatar
pm mw price to 65305 please! its a military base so usps would have to be used...
Old Mar 8, 2012 | 08:53 AM
  #93
Former Sponsor
^^PM'd ya :D
Old Mar 9, 2012 | 08:32 AM
  #94
Former Sponsor
2 left!!!
Old Mar 12, 2012 | 12:07 PM
  #95
Former Sponsor
1 left!!!!!!!!!!!!!!!!!!!
Old Mar 12, 2012 | 03:52 PM
  #96
snipaz2420's Avatar
the bukkake master!
someone pick this up! i love my turboxs gen coupe exhaust
Old Mar 13, 2012 | 09:58 AM
  #97
Former Sponsor
^^I watz more pics of your car!!
Old Mar 13, 2012 | 11:42 AM
  #98
snipaz2420's Avatar
the bukkake master!
pmd ya! bump for TXS
Old Mar 13, 2012 | 08:41 PM
  #99
van's Avatar
van
Is installation exactly the same as the Racing Beat Header shown HERE?
Old Mar 14, 2012 | 09:02 AM
  #100
Former Sponsor
^pretty much...
