MM Turbo upgrade 3071 or 3076 or ???
Old Nov 26, 2009 | 01:43 PM
  #51
After taking my turbo apart to find out what size it is I have concluded it is a T04e 57 trim . According to the flow maps - this turbo should be capable of around 300whp and yet I pushed it to 350whp - fck what was I thinking ? !!!!!!
Anyway - If my turbo can do that then I guess it's reasonable to assume that the 3071 can be pushed to 400
Old Nov 26, 2009 | 11:12 PM
  #52
The "end" of the flow map is not a brick wall.
As long as you don't over-spin the turbo, it will continue to do its thing long after the end of the efficiency map. It just doesn't do it as well.
That is where secondary cooling really comes to play.
Old Nov 27, 2009 | 01:04 PM
  #53
blackenedwings's Avatar
Life begins @ 30 psi
So is that the answer? The turbo is way outside its efficiency range, but its still able to do what is needed with secondary cooling?
Granted I can't imagine shoehorning a larger turbo into the location the GReddy manifold dictates but its a little disappointing to think the only way to reach 400 wheel with the kit is to run the turbo so far outside of its efficiency range.
When I first got on the RX-8 club, there were precious few people with turboed cars to begin with, and those few were shooting for the "holy grail" of 300 whp which everyone agreed would be more than enough for any street car. With the available upgrades now like the AccessPORT and BHR ignition hitting 300 whp is easy and everyone is looking at "double baller" status as the next target. I'm curious if its going to take a different kit to really start pushing the envelope.
Old Nov 27, 2009 | 01:20 PM
  #54
Originally Posted by blackenedwings
So is that the answer?... its a little disappointing to think the only way to reach 400 wheel with the kit is to run the turbo so far outside of its efficiency range.
Before I go into the specifics, let's address this psychology.
Do you think that you are hurting the turbo's feelings by asking it to go outside its 70% flow map island?
Or, do you think you are physically hurting the turbo (or some other part of the system)?
Old Nov 27, 2009 | 01:31 PM
  #55
turbos are very sensitive things ....
Old Nov 27, 2009 | 01:33 PM
  #56
Well, I guess that's a good point... but from everything I've read, the primary reason for picking a turbo is to maximize its efficiency to ward off additional heat and avoid surge. It just seems counter-intuitive to me to use a less efficient turbo and then use charge cooling to reach a target unless there is a compelling reason to use that less efficient option. If the primary reason for that is the space available I guess I understand it. I don't think the turbo is going to yell "Ouch my compressor wheel!!" if I put more boost through it...
Old Nov 27, 2009 | 01:54 PM
  #57
There is - it's called drivability .....
Old Nov 27, 2009 | 02:39 PM
  #58
DING DING DING DING!
(That, and the space constraints.)
Old Nov 27, 2009 | 03:23 PM
  #59
/\ The thing that irks me is that you could have said what you were doing a long time ago and we would all have accepted it . Why the need for all the cloak and dagger stuff ?
Old Nov 27, 2009 | 03:48 PM
  #60
Flashwing's Avatar
3-wheeler
Because being open about information like this prompts nothing more than argument and picking everything apart.
Thankfully he's not posted the dyno charts otherwise there would be an army of people claiming they were doctored.
Old Nov 27, 2009 | 03:55 PM
  #61
Flash, I have to disagree with this... most of what annoys people is obfuscation and a lot of smoke and mirrors. A simple truth is going to cause a lot less controversy than all the bs.
A good example, look at Esmeril. They were claiming 400 whp with their kit, and there were known failures with the kit and people got on them really hard until Chris posted a dyno showing what the kit could do. Sure there are still issues that people have, but it changed the environment from open hostility.
I'm not saying Jeff should post his dyno because honestly I don't give a rats *** if he hit 400 whp or not. He said he did and I believe him, but it won't change anything for me if he posts or doesn't post that. What is an issue is making such a big ******* deal over something that was a simple question:
"Does the kit hit the advertised horsepower, and if so does it do so despite operating outside the optimal efficiency."
It's a yes/no question, with no need to be blown up into a big thing with people guessing and mudslinging on various sides. If the turbo is outside its efficiency range and that is acceptable due to the space constraints and the desired spool time, great... just say so. Hinting the turbo has a different compressor wheel, or there is some kind of "magic" involved is inane.
Old Nov 27, 2009 | 05:12 PM
  #62
carbonRX8's Avatar
U-Stink-But-I-♥-U
I know it is not the only book and it is likely not the best, but a quick overview of Hartman's book could give anyone enough info to feel comfortable about these issues pretty much. I was looking over it again last night and was suprised that the 3071r is used in many examples.
Just fyi
Old Nov 27, 2009 | 08:54 PM
  #63
What smoke an mirrors? I didn't start this thread and I haven't contributed anything purposeful to it.
And since when do I owe anyone anything with regards to information?
It was free where I got it, so go get it yourself.
Old Nov 27, 2009 | 09:00 PM
  #64
Flashwing's Avatar
3-wheeler
Perhaps I am confused to the purpose of this thread. My understanding is the question being asked is what kind of turbo is MazdaManiac running in his car. What you are expressing Aaron is what kind of a turbo is included in the Greddy Upgrade that MazdaManiac provides?
If you're asking what kind of turbo comes in the upgrade that's one thing. Using Esmeril as an example would fit. In their case, Chris was making claims that their bolt on kit was capable of 400whp but there were not any dynographs to back up their claims.
Mazdamanaic has never claimed such high figures and IIRC 310whp was the advertised figure and so far I don't know a single instance where this power level was not reached.
If people are upset Jeff isn't talking about what's in his car then it's just tough. Nobody has to pull back the curtain and show the little man operating the controls.
Doh, beat me to it!
Old Nov 27, 2009 | 09:30 PM
  #65
I stated (twice!) what I was interested in with this thread... I don't care what turbo Jeff has specifically and I don't care about his dyno, I was asking specifically about the claims on the website about the product I bought. That is the only reason I think I deserved an answer. Obviously its nobody's business but Jeff what he has under his hood. I don't care if he has a ******* midget under there.
I do care that the website advertises it can hit 400 whp (so yes he does advertise that) and I'm hoping to move in that direction, but the compressor map doesn't seem to fit that target so I had a legitimate question about the turbo. I would of course be totally fine having the conversation in private, but my record in reaching Jeff is less than stellar, hence the thread.
I got the answer I needed (and assumed anyway) so you may all resume the normal RX8Club programming.
Old Nov 27, 2009 | 10:45 PM
  #66
I do no such thing.
Read again:
The turbo included in the upgrade kit is capable of flowing enough air to produce up to 475 horsepower at the crank. That is over 400 horsepower at the wheels.
However, getting there will require major upgrades to other areas of the drivetrain, including but not limited to fuel injectors, ignition coils, intake and exhaust piping, fuel pump, cooling system upgrades, transmission upgrades, differential upgrades and suspension.
It is not an unrealistic expectation to get well into the 300+ HP* range without serious modification with this kit.
The primary goal is to take the existing GReddy kit and give it continuous power to redline and add 25 to 75 HP* to the numbers people are seeing with the GReddy kit alone.
Old Nov 27, 2009 | 10:49 PM
  #67
I understand that, but as someone who has upgraded every single one of those things you list as needing major upgrades I was specifically referring to the line that says the turbo is capable of flowing enough air to produce up to 475 horsepower at the crank. It isn't a totally insane question to ask how that is possible if the compressor map is way off its efficiency island. I honestly don't understand why its such a big ******* deal? It's not an insane question to ask and I shouldn't have to pull teeth to get a simple yes or no answer.
Old Nov 27, 2009 | 11:34 PM
  #68
you are getting predictable ...... can't have that
Old Nov 27, 2009 | 11:46 PM
  #69
Mawnee's Avatar
I divide by zero
I will now be offering my Turbo kit to the public!
This kit is capable of producing 900 crank HP. That is over 700HP at the wheels. However, getting there will require major upgrades to other areas of the drivetrain, including but not limited to fuel injectors, ignition coils, intake and exhaust piping, fuel pump, ported housings, extra rotors, a different turbo, cooling system upgrades, transmission upgrades, an LS1 swap, differential upgrades and suspension.
It is not an unrealistic expectation to get well into the 250+ HP* range without serious modification with this kit.
It is possible that I may have at one time in some way perhaps hit these numbers in my own car. I will niether confirm nor deny, nor comment on said numbers. However my kit may or may not, though probably not(though you could get lucky!) contain a turbo capable of these numbers.
To place an order simply go to my website. I will gladly assist you. If you have not recieved your order within 8 years please contact me by cheerokee smoke signal while holding your left hand behind your back. Any other forms of communication will be ignored. I cannot be responsible for unexpected winds blocking your signals.
Old Nov 27, 2009 | 11:56 PM
  #70
Old Nov 28, 2009 | 12:00 AM
  #71
oh man - I almost choked on my tea reading that - classic .
Old Nov 28, 2009 | 12:17 AM
  #72
Rotr8's Avatar
whines all the way home
hahahahah holy **** thats funny, but ironically I think the person that will get the biggest kick out of is Jeff....
Old Nov 28, 2009 | 12:45 AM
  #73
^^ Indeed. lol
Old Nov 28, 2009 | 10:04 AM
  #74
carbonRX8's Avatar
U-Stink-But-I-♥-U
Tell you what. Why doesnt someone give me a 3071r and I will test it out on the new motor that I am having built and I will let you know just how much powa you can has.
hint...
hint...
Old Nov 28, 2009 | 10:17 AM
  #75
hint...
hint...
I'll probably beat ya to it carbon, I'm having a new motor built also and already have a 3071R.
Then again, I'm seriously considering an LS1 swap now so I can use Mawnee's new turbo kit... that sounds amazing! Fortunately I'm proficient at smoke signals already.
