Will It Fit Thread
Rating: Thread Rating: 4 votes, 5.00 average.
Old Oct 8, 2008 | 03:59 PM
  #951
imput1234's Avatar
I ♥ Drifting!!!
Originally Posted by Big Money Pit
i have a few more questions:
i've been looking at 17" wheels. can i run a 17x10 without rolling, or do i need a 17x9.5? what would the optimal tire size be for this? can i use a 275/40/17 or 285/40/17 (for the 10")...
or should i go with a 35?
also, what spring/shock combo would lower this setup enough to look nice and handle well?
17x10 +35 will fit fine, how low are you?
Old Oct 8, 2008 | 04:31 PM
  #952
Big Money Pit's Avatar
i'm not lowered currently at all... but after that wheel and tire combo, what would look right?
Old Oct 8, 2008 | 05:00 PM
  #953
Bravery's Avatar
Chi's Finest
Originally Posted by imput1234
Any offset you want, depends you wanna be agressive, flush, safe? tires depend on offset
i would like it to look clean in a sense but agressive, ive been reading some of these and ive seen a rear 18x10 with a offset of 40 or 41 and a front 18x9 + 40 as well.
i really not knowledgable in offsets what would you recommend?
Old Oct 8, 2008 | 05:03 PM
  #954
Bravery's Avatar
Chi's Finest
what would anyone recommend, i really want a 18x10 in the rear and a 18x9 in the front
Old Oct 8, 2008 | 05:13 PM
  #955
Gyro_Bot's Avatar
Zoom Zoom
I have 19x9.5 [35 Offset] in the rear and a 19x9 [29 Offset] in the front. [265 all around]
At this offset, I had to chamber the fronts a tiny bit. The rears were perfectly fine. No fender roll needed. The fronts look really aggressive, because they "almost" stick out of the wheel wells. I would have to chamber the front wheels a little more if I were to lower the car.
I think think the set up you mentioned would look great, and you can still lower your car (based on my own wheels). Although I might suggest going with 43 Offset all around, and 10" wide front wheels and back wheels. Your car has lots of room in the front wheel wells.
I am not an authority, so do get a second opinion
Cheers!
Old Oct 8, 2008 | 08:06 PM
  #956
imput1234's Avatar
I ♥ Drifting!!!
You'll be fine, you can run 275s.
Old Oct 8, 2008 | 08:53 PM
  #957
minnesoshan's Avatar
okay my turn, I need to know if i can throw on 19'' gracing seki's on my rx8 I think they might be too skinny though heres the specs
Manufacturer: G-Racing by Giovanna
Model: Seki
Size: 18x7.5<------heres where i think i might have an issue
Offset: 45mm
Bolt Patterns:5 lug
Weight: 18.6
Size 19''
Old Oct 8, 2008 | 08:56 PM
  #958
alexisthemovie's Avatar
are they 18" or 19"? Either way they are thinner than stock... Would fit easily.
Old Oct 8, 2008 | 08:59 PM
  #959
would half an inch make a big difference in handling? ya they are 19'' the diameter is bigger than stock and they are skinnier?
Old Oct 8, 2008 | 09:09 PM
  #960
imput1234's Avatar
I ♥ Drifting!!!
stock diameter is 8" so they are smaller. It would make a difference, makes even a difference in looks.
Old Oct 8, 2008 | 09:19 PM
  #961
well i guess ill have to throw them on and see how it goes. ill take before and after pics and post them next week
Old Oct 8, 2008 | 10:15 PM
  #962
Bravery's Avatar
Chi's Finest
Cheers!
thanks and i do like that, 10 front and back. it would look nice. the offset sounds good too at 42.
if anyone else can help please do
Old Oct 12, 2008 | 05:03 AM
  #963
Blackout04RX's Avatar
Need for Speed Satisfied
I have to admit, that the numbers get a little dizzying when you read through all the posts. I get rim sizes, and tires, but the offset is throwing me off. And judging from all the posts im assuming this is an important number, so can someone enlighten me? Because the last car I had i put rims on but this number never came into issue... help anyone?
Old Oct 12, 2008 | 12:43 PM
  #964
imput1234's Avatar
I ♥ Drifting!!!
offset can be positive or negative. The stock offset on the rx8 is +50mm. Positive sticks out, and negative gets sunken in.
So just add or subtract to see where the wheel will lay, make sense?
Old Oct 12, 2008 | 02:02 PM
  #965
thecow135's Avatar
positive goes in...
Old Oct 12, 2008 | 03:32 PM
  #966
imput1234's Avatar
I ♥ Drifting!!!
Originally Posted by thecow135
positive goes in...
No, it go out. From alexisamovies previous post
+15 see how it comes out
compared with stock
Old Oct 12, 2008 | 03:43 PM
  #967
NgoRX8's Avatar
think of it this way
increasing the number will push the wheels towards the suspension.
a lower number will pull it toward the fender (or even more outward).
a negative offset will stick out much more than a positive offset.
Old Oct 12, 2008 | 03:56 PM
  #968
imput1234's Avatar
I ♥ Drifting!!!
thats what I meant, lol for some reason I was thinking of +15 or +20 are "more" positive lol
Old Oct 13, 2008 | 05:34 PM
  #969
quazmosis's Avatar
Chode
I still don't get it.
Old Oct 13, 2008 | 05:41 PM
  #970
imput1234's Avatar
I ♥ Drifting!!!
The stock offset is +50. if the +# goes lower it will go out #mm, for example a +20; add 30mm to the stock wheel to see where it will lay.
Old Oct 14, 2008 | 10:25 AM
  #971
Acoustix's Avatar
Hi guys, some advice please..
Advan RZ
18x8 + 37 front
18x9 + 25 rear
Clad with 235/40 front and 265/35 rear.
Will the above setup flush nicely? I dun mind a little camber and fender roll, but I'd like the really flushed look, bordering on aggressiveness :D
p/s: I'm lowered till about half an inch front and rear on cuscos.
Old Oct 14, 2008 | 11:21 AM
  #972
quazmosis's Avatar
Chode
I think I'm getting it. I guess if I was going to buy rims, I'd want a lighter rim than stock. About the same size as stock. I don't want to do any modification to the suspension or anything. That's possible right just to get a lighter rim?
Old Oct 14, 2008 | 02:20 PM
  #973
imput1234's Avatar
I ♥ Drifting!!!
Yea, the most common setup around here is 18x9.5 +45 RPF1, I believe 5-6lbs less on each wheel & you can run a 275 safely.
Old Oct 14, 2008 | 02:21 PM
  #974
imput1234's Avatar
I ♥ Drifting!!!
Advan RZ
18x8 + 37 front
18x9 + 25 rear
You'll have to roll the fenders. I think I'll like em.
Old Oct 14, 2008 | 06:10 PM
  #975
NgoRX8's Avatar
Offset is the position of the center hub on the wheel with respect to the entire rim. A zero offset means the hub positioned at the center of the rim.
A positive offset means that the hub is moved that many millimeters further toward the outside. A negative offset means that the hub is that many millimeters further in on the rim.
I think we can stop talking about offset now. Its just going to keep confusing people.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
