Low idle
Old Jul 25, 2011 | 10:59 PM
emerodi8's Avatar
Low idle
I'm having a problem with the idle on my 2004 rx8 stick shift. It's idling very low and eventually shuts off when I'm in neutral. I have to constantly rev up to keep it from turning off when I stop.
Can anyone advise me on how to get back to normal?
Old Jul 26, 2011 | 08:14 PM
R.Buffington's Avatar
Wobbles09
Mine did that with a blown interior fuse, any extra lights on your dash?
Old Jul 27, 2011 | 12:39 AM
monchie's Avatar
I HATE SPEEDBUMPS!
^ What!?
Old Jul 27, 2011 | 12:42 AM
monchie's Avatar
I HATE SPEEDBUMPS!
How many miles on the odometer? When did the last time you did a tune-up? Also, check the status of the fuel pump too.
Old Jul 27, 2011 | 05:26 AM
emerodi8's Avatar
I recently replaced the spark plug, wires and coils. I got about 132k miles on it. How do I check the status on the fuel pump... Sorry I'm a newb
Old Jul 27, 2011 | 07:00 AM
RIWWP's Avatar
You are already better off than monchie, who recommended that, since you aren't referring to it as a 'tune up'. He is an idiot, so don't take his suggestions.
Idle problems are never fuel pump related. Unstable or low idle or idle stall is usually one of these:
1: Low compression
2: dirty MAF ($5 can of MAF cleaner at the autoparts store
3: dirty / uncalibrated e-shaft sensor (unplug, wipe it off, replug, reset ECU)
4: Ignition failure
You ruled out #4, so it's one of the others. Handle #2 and 3, and if it's still there, take it in for a compression test, your engine is probably failing.
Old Jul 27, 2011 | 08:22 AM
MariesRX8's Avatar
Mine did something similar when I first got my replacement engine. Mazda cleaned the fuel injectors and intake (throttle body?) and it was OK after that.
Old Jul 27, 2011 | 08:18 PM
Wobbles09
Originally Posted by monchie
^ What!?
Yea I accidently touched wires working on the interior and blew a fuse and the car didn't function right. Replaced a 3$ fuse and it went back to normal
Old Jul 28, 2011 | 12:52 AM
emerodi8's Avatar
1: Low compression
4: Ignition failure
Thanks! I already cleaned the MAF. So I'll try to do #2. how do I locate the e-shaft? What's the process?
Old Jul 28, 2011 | 03:37 AM
Wingznut's Avatar
Go Red Wings!
Eccentric Shaft Position Sensor Removal/Install:
http://foxed.ca/rx7manual/2003mazdar...018221W02.html
How to reset ECU:
http://www.rx8blog.com/how-to-reset-ecu-on-mazda-rx8/
I would suggest cleaning the Throttle Body and Idle Air Control valve.
Old Jul 28, 2011 | 11:04 AM
emerodi8's Avatar
How to reset ECU:
Cool thanks. Is there an easy way to clean the throttle body and the Air control valve. <------ how do I locate it?
Old Jul 28, 2011 | 05:15 PM
Bladecutter's Avatar
Rockie Mountain Newbie
If you don't know how to locate the throttle body, you probably shouldn't try to clean it, either.
BC.
Old Jul 28, 2011 | 05:44 PM
Wingznut's Avatar
Go Red Wings!
Bah, don't be hard on him... We were all newbies at one time.
Search for how to clean a throttle body, it's easy to do. I'd explain it, but my RX-8 (and my wife) are awaiting me to take her out to dinner.
Old Jul 29, 2011 | 02:52 PM
emerodi8's Avatar
Yea I'm not very familiar with all the names but I can do the job if I know exactly the parts I need to work on. Thanks for the info guys
RevMeHarder
Jun 1, 2026 02:30 PM
RAE008
Sep 19, 2015 02:24 PM
TJSiegrist
Sep 10, 2015 09:29 AM
iwannarun
Sep 6, 2015 01:37 PM
